[ARM Stable Update] 2021-09-28 - Firefox, Thunderbird, LibreOffice, Electron, Element and Kernels
Hello ARM community.
This is a the update of point releases it seems!
Some highlights:
  • Most of our kernels got updated
  • Firefox, LibreOffice and Thunderbird all got new point releases
  • A major update to Electron brings it to 15.0
  • Waydroid got a big change and is now split into waydroid and waydroid-image
  • The main Matrix client Element is now at 1.9.0
  • Vivaldi is updated to 4.2
  • Lots of updated packages for our Mobile offerings
  • The regular Python updates
  • And regular updates from upstream
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Tue Sep 28 23:29:13 CEST 2021)
  • arm-stable community aarch64: 604 new and 549 removed package(s)
  • arm-stable core aarch64: 48 new and 44 removed package(s)
  • arm-stable extra aarch64: 693 new and 595 removed package(s)
  • arm-stable kde-unstable aarch64: 307 new and 307 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-09-14          2021-09-28
                               anbox      0_git20210625-1      0_git20210625-2
                           bitwarden             1.28.2-4             1.28.3-1
                          callaudiod   0.1.0+4+g84ed2eb-3              0.1.1-1
                               calls               41rc-1   41.0+30+gfbb6316-1
                              chatty              0.4.0-1  0.4.0+50+gccc4176-2
                                code             1.60.0-1             1.60.2-1
                           corepaint              4.2.0-2              4.2.0-3
                        eg25-manager              0.4.0-6   0.4.0+6+g2bf6337-1
                            electron             14.0.0-1             15.0.0-1
                          electron12            12.0.18-1             12.2.0-1
                          electron13             13.3.0-1             13.5.0-1
                     element-desktop            1.8.4-0.1              1.9.0-1
                         element-web            1.8.4-0.1              1.9.0-1
         gnome-control-center-mobile             3.38.6-2               40.1-1
          gnome-initial-setup-mobile             3.38.5-1               41.0-1
               gnome-software-mobile             3.38.2-1             41.0-1.3
                            kodi-rpi              19.1-10              19.1-11
                        kodi-rpi-dev              19.1-10              19.1-11
               kodi-rpi-eventclients              19.1-10              19.1-11
        kodi-rpi-tools-texturepacker              19.1-10              19.1-11
                       libmm-pp-glib             1.18.0-1             1.18.0-2
                    matcha-gtk-theme           20210802-1           20210924-1
                              matray              1.1.0-1              1.1.1-1
                          megapixels              1.3.0-1              1.3.0-2
                            mmsd-tng                1.2-1     1.2+7+g3e0ee86-1
               mobile-config-firefox              2.2.0-1              2.2.0-2
                     modemmanager-pp             1.18.0-1             1.18.0-2
                          obs-studio             27.0.1-1             27.1.1-1
            pamac-mobile-integration           20210912-3           20210918-1
                                phoc  0.8.0+25+g228d123-1  0.8.0+47+g6132485-1
                               phosh             0.13.1-1 0.13.1+16+gc66b31e-3
            pinephone-manjaro-tweaks           20210911-1           20210928-1
              pinephone-post-install           20210612-2           20210919-2
                       python-tinydb              4.5.1-1              4.5.2-1
                           timeshift20.11.1+28+gefed117-1            21.09.1-1
                             vivaldi        4.1.2369.21-1        4.2.2406.48-1
                            waydroid           20210730-1        r38.e990576-1
                          electron14                    -             14.0.1-1
                          libgbinder                    -             1.1.12-1
                         libglibutil                    -             1.0.55-1
                      python-gbinder                    -              1.0.0-1
                      waydroid-image                    -      17.1_20210925-1
:: Different sync package(s) in repository community aarch64
                       acme-redirect              0.5.2-1              0.5.3-1
                           acme-tiny              4.1.0-2              5.0.1-1
                               acorn            1:8.4.1-1            1:8.5.0-1
                               acpid             2.0.32-2             2.0.33-1
                             alembic              1.8.2-2              1.8.3-1
                                 ali              0.7.2-1              0.7.3-1
                              anewer              0.1.5-1              0.1.6-1
                                anki             2.1.15-1                    -
                             ansible              4.5.0-1              4.6.0-1
                        ansible-core             2.11.4-1             2.11.5-1
                                 arb             2.20.0-1             2.21.0-1
                               arcus             4.10.0-1             4.11.0-1
                             arduino           1:1.8.15-1           1:1.8.16-1
                         arduino-cli             0.18.3-1             0.19.0-1
                                asar              3.0.3-1              3.1.0-1
                            asciidoc              9.1.0-1              9.1.1-2
                               atftp              0.7.4-1              0.7.5-1
                               aubio              0.4.9-9             0.4.9-10
                auto-multiple-choice             1.4.0-10              1.5.0-1
                    autoconf-archive       1:2021.02.19-1       1:2021.02.19-2
                             awesome                4.3-2                4.3-3
                           babel-cli             7.15.4-1             7.15.7-1
                          babel-core             7.15.4-1             7.15.5-1
                         baidupcs-go              3.8.2-1              3.8.3-1
                              batctl             2021.2-1             2021.3-1
                                 bcc             0.21.0-1             0.22.0-1
                           bcc-tools             0.21.0-1             0.22.0-1
                           bctoolbox             5.0.18-1             5.0.26-1
                             binwalk              2.3.2-1              2.3.3-1
                         bitcoin-cli             0.21.1-2               22.0-1
                      bitcoin-daemon             0.21.1-2               22.0-1
                          bitcoin-qt             0.21.1-2               22.0-1
                          bitcoin-tx             0.21.1-2               22.0-1
                             blender          17:2.93.4-2          17:2.93.4-3
                              bottom              0.6.3-2              0.6.4-2
                                buho              2.0.0-1              2.0.0-2
                             buildah             1.22.3-1             1.23.0-1
                               bzrtp             5.0.18-1             5.0.26-1
                            cairosvg              2.1.3-5                    -
                         cargo-audit             0.15.0-1             0.15.2-1
                             cargo-c              0.9.2-1              0.9.4-1
                          cargo-edit              0.7.0-2              0.8.0-1
                      cargo-generate              0.8.0-1             0.10.1-1
                         cargo-udeps             0.1.22-1             0.1.23-1
                         cargo-watch              8.0.0-1              8.1.1-1
                           catatonit              0.1.5-2              0.1.6-1
                              ccache                4.4-1              4.4.1-1
                      certbot-apache             1.18.0-1             1.19.0-1
              certbot-dns-cloudflare             1.18.0-1             1.19.0-1
                certbot-dns-cloudxns             1.18.0-1             1.19.0-1
            certbot-dns-digitalocean             1.18.0-1             1.19.0-1
                certbot-dns-dnsimple             1.18.0-1             1.19.0-1
             certbot-dns-dnsmadeeasy             1.18.0-1             1.19.0-1
                  certbot-dns-gehirn             1.18.0-1             1.19.0-1
                  certbot-dns-google             1.18.0-1             1.19.0-1
                  certbot-dns-linode             1.18.0-1             1.19.0-1
                  certbot-dns-luadns             1.18.0-1             1.19.0-1
                   certbot-dns-nsone             1.18.0-1             1.19.0-1
                     certbot-dns-ovh             1.18.0-1             1.19.0-1
                 certbot-dns-route53             1.18.0-1             1.19.0-1
             certbot-dns-sakuracloud             1.18.0-1             1.19.0-1
                       certbot-nginx             1.18.0-1             1.19.0-1
                             chezmoi              2.3.0-1              2.5.0-1
                                cimg              2.9.8-1              2.9.9-1
                               clash              1.7.0-1              1.7.1-1
                             clojure         1.10.3.943-2         1.10.3.986-1
                              cobalt             0.16.5-1             0.17.1-1
                             cockpit                252-1                253-1
                         cockpit-pcp                252-1                253-1
                              codec2            1:1.0.0-1            1:1.0.1-1
                        coffeescript              2.5.1-1              2.6.0-1
                        communicator              2.0.0-2              2.0.0-3
                              conmon           1:2.0.29-1           1:2.0.30-1
                   containers-common             0.43.2-2             0.46.0-1
                              cosign              1.1.0-1              1.2.1-1
                                criu               3.15-2               3.16-1
                                crun                1.0-1                1.1-1
                    cura-binary-data             4.10.0-1             4.11.0-1
            cura-resources-materials             4.10.0-1             4.11.0-1
                          curaengine             4.10.0-1             4.11.0-1
                         dark-reader             4.9.34-1           4.9.37.1-1
                                dart             2.14.1-1             2.14.2-1
                                deno             1.13.2-1             1.14.0-1
                            dfu-util               0.10-3               0.11-2
                          diffoscope                183-1                185-1
                      dns-over-https              2.2.5-1              2.3.0-1
                      dnscrypt-proxy              2.1.0-1              2.1.1-1
                             dnsperf              2.7.0-1              2.7.1-1
                  dovecot-fts-xapian             1.4.12-2             1.4.13-1
                           drumstick              2.3.1-1              2.4.0-1
                              drupal              9.2.0-1              9.2.6-1
                             dua-cli             2.14.3-1             2.14.7-1
                                dust              0.6.2-1              0.7.5-1
                      efm-langserver             0.0.36-1             0.0.37-1
                              erlang             24.0.4-2             24.1.0-1
                          erlang-nox             24.0.4-1             24.1.0-1
                     erlang-unixodbc             24.0.4-2             24.1.0-1
                              facter            3.14.16-5            3.14.18-1
                               fastd                 19-1                 22-1
                fcitx5-pinyin-zhwiki   1:0.2.3.20210823-1   1:0.2.3.20210923-1
                           fetchmail             6.4.21-1             6.4.22-1
                           filezilla             3.55.1-1             3.55.1-2
                                 fio               3.27-1               3.28-1
                 firefox-dark-reader             4.9.34-1           4.9.37.1-1
                      firefox-stylus             1.5.19-1             1.5.22-1
                          flawfinder             2.0.18-1             2.0.19-1
                             fluxctl             1.24.0-1             1.24.1-1
                          frotz-dumb               2.51-1               2.53-1
                       frotz-ncurses               2.51-1               2.53-1
                           frotz-sdl               2.51-1               2.53-1
                               fwupd              1.6.3-1              1.6.4-1
                       geany-plugins               1.37-3               1.37-4
                              gensio              2.2.8-1              2.2.9-1
                                giac           1.7.0.29-1           1.7.0.33-1
                               giada             0.18.1-1             0.18.2-1
                           git-cliff              0.2.6-1              0.3.0-1
                             git-lfs             2.13.3-2              3.0.0-1
                               gitui             0.16.2-1             0.17.1-2
                            glewlwyd              2.5.3-2              2.5.4-1
                     gnome-subtitles                1.6-2                1.7-1
                            go-tools            4:0.1.5-1            4:0.1.6-1
                           gocryptfs                2.1-1              2.2.0-1
                        goimapnotify              2.3.2-1              2.3.3-1
                               gping              1.2.3-1              1.2.5-1
                                gpsd               3.23-1             3.23.1-1
                          grub-btrfs                4.9-1             4.10.1-1
                           gscan2pdf             2.12.2-1             2.12.3-1
                gst-editing-services             1.18.4-1             1.18.5-1
                              harvid              0.8.3-1              0.8.3-2
                              hcloud             1.28.0-1             1.28.1-1
                         hcxdumptool              6.2.0-1              6.2.4-1
                            hcxtools              6.2.0-1              6.2.4-1
                                helm              3.6.3-1              3.7.0-1
                            helmfile            0.140.0-1            0.140.1-1
                      home-assistant           2021.9.3-1           2021.9.6-1
                            htmlhint             0.15.1-1             0.15.2-1
                                hugo             0.87.0-1             0.88.1-1
                           i2c-tools                4.2-3                4.3-1
                      ibus-libpinyin             1.12.0-1             1.12.1-1
                            index-fm              2.0.0-1              2.0.0-2
                            innernet              1.4.1-1              1.5.0-1
                       inotify-tools          3.20.11.0-1           3.21.9.5-1
                               irker               2.19-1               2.20-1
                                 iwd               1.17-1               1.18-1
                jedi-language-server             0.34.2-1             0.34.3-1
                             jenkins              2.311-1              2.313-1
                              jgmenu              4.3.0-1              4.4.0-1
                       jitterentropy              3.2.0-1              3.3.0-1
                                josm              18118-1              18193-1
                               jruby           9.2.19.0-1            9.3.0.0-1
                   jupyter-nbclassic              0.3.1-1              0.3.2-1
              jupyter-server-mathjax              0.2.3-1              0.2.3-2
                          jupyterlab             3.1.11-1             3.1.14-1
                  jupyterlab-widgets              1.0.1-1              1.0.2-1
                             kak-lsp             11.0.0-2             11.0.1-1
                              kcptun           20210624-1           20210922-1
                             keepass             2.48.1-1               2.49-1
                             kompose             1.23.0-1             1.24.0-1
                              kotlin             1.5.30-1             1.5.31-1
                              kstars            1:3.5.4-1            1:3.5.5-1
                         kube-linter              0.2.3-1              0.2.4-1
                             kubeone              1.2.3-1              1.3.0-1
                                 kup              0.9.1-1              0.9.1-2
                            kylin-nm              3.0.1-1              3.0.2-1
                          latte-dock             0.10.1-1             0.10.2-1
                            laz-perf            2:1.3.0-1            2:2.1.0-1
                           leiningen              2.9.6-1              2.9.7-1
                              lhapdf              6.3.0-3              6.4.0-1
                      libcurl-compat             7.78.0-1             7.79.1-1
                      libcurl-gnutls             7.78.0-1             7.79.1-1
                        libfilezilla             0.31.1-1             0.32.0-1
                       libimagequant             2.15.1-1             2.16.0-1
                             libindi              1.9.1-1              1.9.2-1
                              libolm              3.2.4-1              3.2.6-1
                         libopenshot             0.2.5-10              0.2.7-1
                   libopenshot-audio              0.2.0-1              0.2.2-1
                           libpinyin              2.6.0-1              2.6.1-1
                         libquotient              0.6.8-1              0.6.9-1
                          libsavitar             4.10.0-1             4.11.0-1
                             libseat              0.5.0-2                    -
                       libserialport              0.1.1-4              0.1.1-5
                             libtpms              0.8.5-2              0.8.7-1
                             libvips             8.11.3-1             8.11.4-1
                        lksctp-tools             1.0.17-3             1.0.19-1
                        lucky-commit              2.0.5-1              2.0.5-2
                    maliit-framework              2.0.0-2              2.1.1-1
                     maliit-keyboard              2.0.0-2              2.1.0-1
                              marked              3.0.3-1              3.0.4-1
                         mate-themes            3.22.22-1            3.22.23-1
               matrix-appservice-irc             0.30.0-1             0.31.0-1
                      matrix-synapse             1.41.1-1             1.43.0-1
                           maui-clip              2.0.0-1              2.0.0-2
                           maui-nota              2.0.0-1              2.0.0-2
                            maui-pix              2.0.0-1              2.0.0-2
                          maui-shelf              2.0.0-1              2.0.0-2
                        maui-station              2.0.0-1              2.0.0-2
                             mauikit              2.0.1-1              2.0.2-1
                mauikit-filebrowsing              2.0.1-1              2.0.2-1
                       mediastreamer             5.0.18-1             5.0.26-1
                         meilisearch             0.21.1-1             0.22.0-1
                             mellite              3.6.0-1              3.7.0-1
                            miniflux             2.0.32-2             2.0.33-1
                            minikube             1.23.0-1             1.23.1-1
                            minitube                3.9-1              3.9.1-1
                           mitmproxy              7.0.2-1              7.0.3-1
                            molecule              3.4.0-1              3.5.1-1
                     molecule-docker              0.3.3-2              1.0.2-1
                     molecule-podman              0.3.0-2              1.0.1-1
                               monit             5.28.1-1             5.29.0-1
                           mosquitto             2.0.11-1             2.0.12-1
                                 mpv           1:0.33.1-2           1:0.33.1-3
                             neochat              1.2.0-3              1.2.0-4
                              neovim              0.5.0-1              0.5.1-1
                            newsboat               2.24-2               2.25-1
             nextcloud-app-bookmarks            1:4.4.1-1           1:10.0.0-1
              nextcloud-app-contacts              4.0.2-1              4.0.3-1
                  nextcloud-app-deck            1:1.5.2-1            1:1.5.3-1
                nextcloud-app-spreed           1:12.1.1-1           1:12.2.0-1
                    nextcloud-client            1:3.3.0-1            1:3.3.4-2
     nextcloud-client-cloudproviders            1:3.3.0-1            1:3.3.4-2
                              nikola              8.1.3-1              8.1.3-2
                            node-gyp              8.1.0-2              8.2.0-1
                              nodejs             16.9.1-1            16.10.0-1
                               nomad              1.1.4-1              1.1.5-1
             nomad-driver-containerd              0.9.1-1              0.9.2-1
                             notmuch             0.32.3-1             0.33.1-1
                        notmuch-mutt             0.32.3-1             0.33.1-1
                     notmuch-runtime             0.32.3-1             0.33.1-1
                         notmuch-vim             0.32.3-1             0.33.1-1
                                 npm             7.23.0-1             7.24.1-1
                             nushell             0.35.0-3             0.37.0-1
                            onefetch             2.10.2-1             2.10.2-2
                          open-iscsi              2.1.4-1              2.1.5-1
                             openbox              3.6.1-7              3.6.1-8
                            openlibm              0.7.5-1              0.8.0-1
                            openshot              2.5.1-4              2.6.1-2
                          opensubdiv              3.4.4-5              3.4.4-6
                      opentimelineio               0.13-1               0.13-2
                        operator-sdk             1.11.0-1             1.12.0-1
                       optional-lite              3.4.0-1              3.5.0-1
                                ortp             5.0.18-1             5.0.26-1
                   otf-cascadia-code            2106.17-1            2108.26-1
                     owncloud-client         2.9.0.5150-1         2.9.0.5150-2
                             pam-u2f              1.1.1-1              1.2.0-1
                                 pan              0.146-3              0.147-1
                                 pcp              5.3.2-1              5.3.3-1
                             pcp-gui              5.3.2-1              5.3.3-1
                   pcp-pmda-activemq              5.3.2-1              5.3.3-1
                        pcp-pmda-bcc              5.3.2-1              5.3.3-1
                      pcp-pmda-bind2              5.3.2-1              5.3.3-1
                   pcp-pmda-bpftrace              5.3.2-1              5.3.3-1
                    pcp-pmda-libvirt              5.3.2-1              5.3.3-1
                      pcp-pmda-mysql              5.3.2-1              5.3.3-1
                      pcp-pmda-nginx              5.3.2-1              5.3.3-1
                 pcp-pmda-nutcracker              5.3.2-1              5.3.3-1
                pcp-pmda-openmetrics              5.3.2-1              5.3.3-1
                     pcp-pmda-podman              5.3.2-1              5.3.3-1
                 pcp-pmda-postgresql              5.3.2-1              5.3.3-1
                       pcp-pmda-snmp              5.3.2-1              5.3.3-1
                                pdal              2.3.0-2              2.3.0-3
                      perl-alien-sdl             1.446-11             1.446-12
                         perl-dbd-pg              3.9.0-1              3.9.1-1
                   perl-email-sender           1.300031-8              2.500-1
              perl-proc-processtable               0.59-3               0.60-1
                       perl-sys-virt              7.5.0-1              7.7.0-1
                perl-test-mockmodule            0.176.0-3            0.177.0-1
                    perl-test-simple           1.302186-1           1.302187-1
                  perl-text-template               1.59-2               1.60-1
                   perl-yaml-libyaml               0.75-6               0.83-1
                  phrase-pinyin-data             0.10.5-1             0.11.0-1
                         pinyin-data             0.10.2-1             0.11.0-1
                           playerctl              2.3.1-1              2.4.1-1
                                 pm2              5.1.1-1              5.1.2-1
                            pngquant             2.15.1-1             2.16.0-1
                        postfixadmin             3.3.10-1             3.3.10-2
                             postgis              3.1.3-1              3.1.4-1
                           postorius              1.3.4-2              1.3.5-1
                            prettier              2.3.2-1              2.4.1-1
                               pueue              1.0.1-2              1.0.3-1
                              pulumi             3.11.0-1             3.13.0-1
                               pyenv              2.0.6-1              2.0.7-2
                             pyright            1.1.166-1            1.1.171-1
                      python-aiogram             2.14.3-1               2.15-1
                      python-astroid              2.7.3-1              2.8.0-1
                        python-aubio              0.4.9-9             0.4.9-10
                          python-bcc             0.21.0-1             0.22.0-1
                       python-bidict             0.21.2-2             0.21.3-1
                      python-breathe             4.30.0-2             4.31.0-1
                        python-build              0.6.0-1              0.7.0-1
                       python-calmjs              3.4.1-3              3.4.1-4
                     python-cfn-lint             0.54.0-1             0.54.2-1
                       python-cogapp              3.0.0-5              3.1.0-1
                       python-cvxopt              1.2.6-1              1.2.7-1
                          python-ddt              1.4.2-1              1.4.3-1
                       python-debian             0.1.40-2             0.1.41-1
                python-debtcollector              2.2.0-3              2.3.0-1
                    python-decorator              5.0.9-1              5.1.0-1
               python-django-appconf              1.0.4-4              1.0.5-1
          python-django-crispy-forms             1.12.0-1             1.13.0-1
               python-django-environ              0.4.5-5              0.7.0-1
                python-django-filter              2.4.0-2               21.1-1
              python-django-haystack                3.0-4              3.1.1-1
              python-django-mailman3              1.3.5-2              1.3.7-1
                    python-dnspython           1:1.16.0-3            1:2.1.0-1
                         python-doit             0.33.1-3             0.33.1-4
                  python-elementpath              2.2.3-2              2.3.1-1
                     python-eventlet             0.31.1-1             0.32.0-1
                        python-faker             8.12.1-2             8.13.2-1
                python-feedgenerator              1.9.1-3              1.9.2-1
                     python-filetype              1.0.7-3              1.0.8-1
                     python-flexmock             0.10.9-1            0.10.10-1
                    python-fonttools             4.26.2-3             4.27.1-1
                   python-frozendict              2.0.6-1            1:2.0.6-1
                    python-gitpython             3.1.18-1             3.1.24-1
     python-google-api-python-client             2.19.1-1             2.22.0-1
                  python-google-auth             1.33.0-1             1.33.1-1
                     python-identify             2.2.14-1             2.2.15-1
                       python-imdbpy          2021.4.18-1          2021.4.18-3
                      python-inflect              5.3.0-1              5.3.0-2
                  python-itemadapter              0.3.0-1              0.4.0-1
                python-jaeger-client              4.7.0-1              4.8.0-1
             python-jsonrpclib-pelix              0.4.2-1              0.4.3-1
           python-jsonschema-objects             0.3.14-1             0.3.15-1
            python-jupyter_packaging             0.10.4-1             0.10.6-1
            python-jupyterlab_server              2.8.1-1              2.8.2-1
                python-keystoneauth1              4.3.1-2              4.4.0-1
               python-keystoneclient              4.2.0-1              4.3.0-1
               python-lazr.delegates              2.0.4-5              2.0.4-6
                    python-libcharon             4.10.0-1             4.11.0-1
                   python-lsp-server              1.2.1-2              1.2.1-3
                python-mailmanclient              3.3.2-1              3.3.3-1
                      python-markups              3.1.1-1              3.1.2-1
                   python-matrix-nio             0.18.6-1             0.18.7-1
                    python-maxminddb              2.0.3-3              2.1.0-1
                    python-mechanize            1:0.4.5-4            1:0.4.6-1
               python-more-itertools              8.8.0-1             8.10.0-1
                         python-moto              2.2.6-1              2.2.7-1
                      python-mutagen             1.45.1-3             1.45.1-4
                python-mypy-protobuf                2.9-1                    -
                      python-natsort              7.1.1-1              7.1.1-2
                     python-networkx              2.6.2-1              2.6.3-1
                python-neutronclient              7.5.0-1              7.6.0-1
             python-nose-progressive              1.5.2-5              1.5.2-6
                        python-nose2             0.10.0-1             0.10.0-2
                          python-olm              3.2.4-1              3.2.6-1
                     python-openmdao             3.11.0-1             3.12.0-1
              python-openstackclient              5.5.0-1              5.6.0-1
                     python-oslotest              4.4.1-4              4.5.0-1
                       python-pandas              1.3.2-1              1.3.3-1
                       python-pefile          2021.5.24-1           2021.9.3-1
                       python-pg8000             1.21.1-1             1.21.2-1
                 python-phonenumbers            8.12.31-1            8.12.33-1
                      python-pikepdf              3.0.0-1              3.1.0-1
                       python-pillow              8.3.1-1              8.3.2-1
                       python-poetry              1.1.8-1             1.1.10-1
                         python-pook              1.0.1-4              1.0.2-1
                  python-progressbar             3.53.1-5             3.53.3-1
                 python-pycryptodome             3.10.1-1             3.10.4-1
                       python-pygit2              1.6.1-1              1.6.1-2
                       python-pyglet             1.5.18-1             1.5.20-1
                      python-pyliblo             0.10.0-7             0.10.0-8
                      python-pymupdf            1.18.17-1            1.18.19-1
                   python-pynitrokey            0.4.3.1-1              0.4.4-1
                  python-pytest-mock              3.1.1-1              3.6.1-1
              python-pytest-randomly              3.8.0-1              3.9.0-1
         python-pytest-rerunfailures               10.1-1               10.2-1
              python-pytest-services              2.2.1-3              2.2.1-4
                python-pytest-socket              0.4.0-1              0.4.1-1
                 python-pytest-xdist              2.3.0-2              2.4.0-1
              python-pytest-xprocess             0.16.0-1             0.18.1-1
                      python-pythran       0.9.12.post1-1             0.10.0-1
                    python-pywayland              0.4.6-1              0.4.7-1
                    python-pywlroots             0.14.3-1             0.14.6-1
                       python-qasync             0.20.0-1             0.22.0-1
                        python-qiniu              7.4.1-1              7.5.0-1
                    python-rapidjson                1.1-1                1.3-1
                        python-regex           2021.7.6-1          2021.8.28-1
                         python-rich             10.9.0-1            10.11.0-1
                  python-ruamel-yaml            0.17.15-1            0.17.16-1
                         python-sane              2.8.3-6              2.9.1-1
                 python-scikit-learn             0.24.2-2                1.0-1
                      python-selinux              0.2.1-4              0.2.1-5
               python-setuptools-scm              6.3.1-1              6.3.2-1
                       python-sphinx              4.1.2-1              4.2.0-1
             python-sphinx_rtd_theme              0.5.2-1              1.0.0-1
         python-sphinxcontrib-bibtex              2.3.0-1              2.4.1-1
                     python-sqlparse              0.4.1-3              0.4.2-1
                       python-stestr              3.2.0-2              3.2.1-1
               python-subprocess-tee              0.3.2-1              0.3.4-1
                     python-tabulate              0.8.9-1              0.8.9-2
                 python-testfixtures             6.18.1-1             6.18.2-1
                       python-thrift             0.14.0-1             0.14.1-1
                          python-tox             3.24.3-1             3.24.4-1
                         python-tqdm             4.62.2-1             4.62.3-1
                    python-traitlets              5.0.5-2              5.1.0-1
                        python-ujson              4.1.0-1              4.2.0-1
                   python-validators             0.18.1-3             0.18.2-1
                   python-voluptuous             0.12.1-1             0.12.2-1
                     python-watchdog             0.10.6-1             0.10.7-1
                python2-pycryptodome             3.10.1-1             3.10.4-1
                         python2-tox             3.24.3-1             3.24.4-1
                                qcad           3.26.4.7-1           3.26.4.8-1
                                qgis             3.20.2-1             3.20.3-1
                               qtile             0.18.0-2             0.18.1-2
                                r10k             3.10.0-1             3.11.0-1
                            radicale              3.0.6-3              3.0.6-4
                              rclone             1.56.0-1             1.56.1-1
                          rebuilderd             0.13.0-1             0.14.2-1
                          rime-emoji     0.0.0.20210427-1     0.0.0.20210909-1
                  rime-pinyin-zhwiki   1:0.2.3.20210823-1   1:0.2.3.20210923-1
                          rosegarden              21.06-1            21.06.1-1
                        ruby-faraday              1.7.0-1              1.8.0-1
                          ruby-hocon              1.3.1-3              1.3.1-4
                         ruby-rugged              1.1.1-1              1.2.0-1
                        ruby27-hocon              1.3.1-2              1.3.1-3
                       rust-analyzer           20210906-1           20210920-1
                           scenarist        0.7.2.rc12a-1         0.7.2.rc13-1
                             scribus              1.5.7-3              1.5.7-5
                                 sdl            1.2.15-141.2.15+387+gfbfcca32-1
                          serverless             2.57.0-1             2.60.0-1
                             shutter               0.98-1               0.99-1
                                sile             0.11.1-3             0.12.0-4
                            skaffold             1.31.0-1             1.32.0-1
                           skk-jisyo           20210822-1           20210926-1
                              slimit              0.8.1-5              0.8.1-6
                               smb4k              3.1.0-1              3.1.1-1
                             snapper              0.9.0-2              0.9.1-1
                           sniffglue             0.13.0-1             0.13.1-1
                            soapysdr              0.8.0-1              0.8.1-1
                    sonic-visualiser                4.3-2                4.4-1
                            sqlx-cli              0.5.5-2              0.5.7-1
                                sslh             1.22.b-1             1.22.c-1
                                sssd              2.5.2-1              2.5.2-2
                            starship             0.57.0-1             0.58.0-2
                             step-ca             0.17.2-1             0.17.3-1
                            step-cli             0.17.2-1             0.17.4-1
                          streamlink              2.3.0-1              2.4.0-1
                       subdownloader              2.1.0-5              2.1.0-6
                              swappy              1.3.1-1              1.4.0-1
                               sweep              0.9.3-5              0.9.3-6
                               swtpm              0.6.0-1              0.6.1-1
                           syncthing             1.18.1-1             1.18.2-1
                  syncthing-relaysrv             1.18.1-1             1.18.2-1
                           tailscale             1.14.2-1             1.14.4-1
                               tclap              1.2.2-2              1.2.3-1
                    telegram-desktop              3.0.1-1              3.1.1-1
                           terraform              1.0.6-1              1.0.7-1
                           texstudio              3.1.2-1              4.0.0-1
                              thrift             0.14.2-1             0.15.0-1
             thunderbird-dark-reader             4.9.34-1           4.9.37.1-1
                              tinygo             0.19.0-1             0.20.0-1
                             tinyxml              2.6.2-7              2.6.2-8
                               tmuxp              1.9.2-1              1.9.2-2
                             todoman              4.0.0-1              4.0.0-2
                         ttc-iosevka             10.1.1-2             10.3.0-1
                    ttc-iosevka-aile             10.1.1-2             10.3.0-1
                   ttc-iosevka-curly             10.1.1-2             10.3.0-1
              ttc-iosevka-curly-slab             10.1.1-2             10.3.0-1
                  ttc-iosevka-etoile             10.1.1-2             10.3.0-1
                    ttc-iosevka-slab             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss01             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss02             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss03             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss04             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss05             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss06             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss07             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss08             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss09             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss10             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss11             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss12             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss13             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss14             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss15             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss16             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss17             10.1.1-2             10.3.0-1
                    ttc-iosevka-ss18             10.1.1-2             10.3.0-1
                   ttf-cascadia-code            2106.17-1            2108.26-1
                   ttf-sarasa-gothic             0.34.2-1             0.34.3-1
                          typescript              4.4.2-1              4.4.3-1
                 ukui-biometric-auth              1.2.1-1              1.2.2-1
                          ukui-media              3.0.1-1            3.0.3.1-1
                          ukui-panel            3.0.3.1-1              3.0.5-1
                    ukui-screensaver              3.0.1-1              3.0.2-1
                        ukui-sidebar              3.0.1-1              3.1.1-1
                             uranium             4.10.0-2             4.11.0-1
                    uutils-coreutils              0.0.7-1              0.0.7-2
                               v2ray             4.41.1-1             4.42.2-1
         v2ray-domain-list-community     20210910080130-1     20210927113941-1
                         v2ray-geoip       202109090028-1       202109230028-1
                            valabind              1.8.0-1              1.8.0-2
                                vals             0.10.3-2             0.14.0-1
                     vaultwarden-web             2.21.1-1             2.23.0-1
                           verilator              4.210-2              4.212-1
                        vim-fugitive                3.4-1                3.4-2
                        vim-nerdtree            6.10.11-1            6.10.12-1
                           vultr-cli              2.8.2-1              2.8.3-1
                               vvave              2.0.0-1              2.0.0-2
                             wavemon              0.9.3-1              0.9.4-1
                             web-ext              6.3.0-1              6.4.0-1
                             weechat                3.2-1              3.2.1-1
                             wlroots             0.14.1-1             0.14.1-2
                 woff2-cascadia-code            2106.17-1            2108.26-1
                          xdiskusage               1.54-1               1.60-1
            xfce4-whiskermenu-plugin              2.5.3-1              2.6.0-1
                                  xh             0.12.0-1             0.13.0-1
                               xonsh             0.10.0-1             0.10.1-1
                          xtrabackup          8.0.25_17-1          8.0.26_18-1
                               yosys               0.9-14               0.10-1
                        zerotier-one              1.6.5-2              1.6.6-1
                                 zim             0.73.5-1             0.74.1-1
                                 fst                    -            0.120.0-1
                          goreleaser                    -            0.180.0-1
                                  ko                    -              0.9.1-1
                           promscale                    -              0.6.0-1
               python-ansible-compat                    -              0.5.0-1
                        python-cbor2                    -              5.4.1-2
                         python-fire                    -              0.4.0-1
                     python-keycloak                    -             0.26.1-1
                        python-nkdfu                    -                0.1-1
                      python-ufolib2                    -             0.11.4-1
                    rebuilderd-tools                    -             0.14.2-1
                             rhvoice                    -              1.4.2-3
rhvoice-language-brazilian-portuguese                    -              1.4.2-3
            rhvoice-language-english                    -              1.4.2-3
          rhvoice-language-esperanto                    -              1.4.2-3
           rhvoice-language-georgian                    -              1.4.2-3
             rhvoice-language-kyrgyz                    -              1.4.2-3
         rhvoice-language-macedonian                    -              1.4.2-3
            rhvoice-language-russian                    -              1.4.2-3
              rhvoice-language-tatar                    -              1.4.2-3
          rhvoice-language-ukrainian                    -              1.4.2-3
                  rhvoice-voice-alan                    -              1.4.2-3
             rhvoice-voice-aleksandr                    -              1.4.2-3
          rhvoice-voice-aleksandr-hq                    -              1.4.2-3
                rhvoice-voice-anatol                    -              1.4.2-3
                  rhvoice-voice-anna                    -              1.4.2-3
                 rhvoice-voice-arina                    -              1.4.2-3
               rhvoice-voice-artemiy                    -              1.4.2-3
                rhvoice-voice-azamat                    -              1.4.2-3
                   rhvoice-voice-bdl                    -              1.4.2-3
                   rhvoice-voice-clb                    -              1.4.2-3
                 rhvoice-voice-elena                    -              1.4.2-3
           rhvoice-voice-evgeniy-eng                    -              1.4.2-3
           rhvoice-voice-evgeniy-rus                    -              1.4.2-3
                 rhvoice-voice-irina                    -              1.4.2-3
                  rhvoice-voice-kiko                    -              1.4.2-3
          rhvoice-voice-leticia-f123                    -              1.4.2-3
               rhvoice-voice-natalia                    -              1.4.2-3
                 rhvoice-voice-natia                    -              1.4.2-3
                rhvoice-voice-nazgul                    -              1.4.2-3
                 rhvoice-voice-pavel                    -              1.4.2-3
                   rhvoice-voice-slt                    -              1.4.2-3
              rhvoice-voice-spomenka                    -              1.4.2-3
                rhvoice-voice-talgat                    -              1.4.2-3
              rhvoice-voice-victoria                    -              1.4.2-3
             rhvoice-voice-volodymyr                    -              1.4.2-3
                 rhvoice-voice-yuriy                    -              1.4.2-3
                            ruby-jwt                    -              2.2.3-1
                          ruby-scanf                    -              1.0.0-1
                               seatd                    -              0.6.2-1
                             shotgun                    -              2.2.1-1
                   ssh-key-confirmer                    -                0.1-1
                    timescaledb-tune                    -             0.11.3-1
                    ttf-iosevka-nerd                    -              2.1.0-1
:: Different overlay package(s) in repository core aarch64
                       fakeroot-qemu             1.25.3-1               1.26-1
                               linux             5.14.2-1             5.14.8-1
                       linux-headers             5.14.2-1             5.14.8-1
                     linux-pinephone             5.14.2-2             5.14.8-2
             linux-pinephone-headers             5.14.2-2             5.14.8-2
                      linux-quartz64           5.14.0-0.7           5.15.0-0.2
              linux-quartz64-headers           5.14.0-0.7           5.15.0-0.2
                            linux-rc           5.14.rc7-5           5.15.rc3-1
                    linux-rc-headers           5.14.rc7-5           5.15.rc3-1
                          linux-rpi4            5.10.63-1            5.10.63-2
                  linux-rpi4-headers            5.10.63-1            5.10.63-2
                     manjaro-keyring           20210807-2           20210910-2
                              pacman              6.0.1-5              6.0.1-6
                        pacman-debug              6.0.1-5              6.0.1-6
              raspberrypi-bootloader           20210908-1           20210923-1
            raspberrypi-bootloader-x           20210908-1           20210923-1
                     uboot-pinephone            2021.07-1            2021.07-2
                               glib2                    -           2.70.0-1.1
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20210818.c46b8c3-1   20210919.d526e04-1
                               audit              3.0.4-1              3.0.5-1
                         btrfs-progs             5.13.1-1             5.14.1-1
                           coreutils               8.32-1                9.0-1
                          cryptsetup              2.4.0-1              2.4.1-1
                                curl             7.78.0-1             7.79.1-1
                            fakeroot             1.25.3-2               1.26-1
                                file               5.40-5               5.40-6
                               glib2             2.68.4-1             2.70.0-1
                          glib2-docs             2.68.4-1             2.70.0-1
                                grep                3.6-1                3.7-1
                            iana-etc           20210728-1           20210903-1
                           inetutils                2.1-1                2.2-1
                              libcap               2.56-1               2.58-1
                             libedit       20210714_3.1-1       20210910_3.1-1
                          libnghttp2             1.44.0-1             1.45.0-1
                           libxcrypt             4.4.25-1             4.4.26-1
                               links               2.23-1               2.24-2
                      linux-firmware   20210818.c46b8c3-1   20210919.d526e04-1
                              netctl               1.25-1               1.26-1
                             openssh              8.7p1-1              8.8p1-1
                                 pam              1.5.1-1              1.5.2-1
                             pkgconf              1.7.3-1              1.8.0-1
                        python-audit              3.0.4-1              3.0.5-1
                                sudo           1.9.7.p2-1           1.9.8.p2-1
                              tzdata              2021a-2              2021b-1
                                  xz              5.2.5-1              5.2.5-2
                              brotli                    -              1.0.9-4
                     brotli-testdata                    -              1.0.9-4
                       python-brotli                    -              1.0.9-4
:: Different overlay package(s) in repository extra aarch64
                           calamares             3.2.40-1             3.2.44-1
                             firefox               92.0-1                    -
                    firefox-i18n-ach               92.0-1           92.0.1-1.1
                     firefox-i18n-af               92.0-1           92.0.1-1.1
                     firefox-i18n-an               92.0-1           92.0.1-1.1
                     firefox-i18n-ar               92.0-1           92.0.1-1.1
                    firefox-i18n-ast               92.0-1           92.0.1-1.1
                     firefox-i18n-az               92.0-1           92.0.1-1.1
                     firefox-i18n-be               92.0-1           92.0.1-1.1
                     firefox-i18n-bg               92.0-1           92.0.1-1.1
                     firefox-i18n-bn               92.0-1           92.0.1-1.1
                     firefox-i18n-br               92.0-1           92.0.1-1.1
                     firefox-i18n-bs               92.0-1           92.0.1-1.1
                     firefox-i18n-ca               92.0-1           92.0.1-1.1
                    firefox-i18n-cak               92.0-1           92.0.1-1.1
                     firefox-i18n-cs               92.0-1           92.0.1-1.1
                     firefox-i18n-cy               92.0-1           92.0.1-1.1
                     firefox-i18n-da               92.0-1           92.0.1-1.1
                     firefox-i18n-de               92.0-1           92.0.1-1.1
                    firefox-i18n-dsb               92.0-1           92.0.1-1.1
                     firefox-i18n-el               92.0-1           92.0.1-1.1
                  firefox-i18n-en-ca               92.0-1           92.0.1-1.1
                  firefox-i18n-en-gb               92.0-1           92.0.1-1.1
                  firefox-i18n-en-us               92.0-1           92.0.1-1.1
                     firefox-i18n-eo               92.0-1           92.0.1-1.1
                  firefox-i18n-es-ar               92.0-1           92.0.1-1.1
                  firefox-i18n-es-cl               92.0-1           92.0.1-1.1
                  firefox-i18n-es-es               92.0-1           92.0.1-1.1
                  firefox-i18n-es-mx               92.0-1           92.0.1-1.1
                     firefox-i18n-et               92.0-1           92.0.1-1.1
                     firefox-i18n-eu               92.0-1           92.0.1-1.1
                     firefox-i18n-fa               92.0-1           92.0.1-1.1
                     firefox-i18n-ff               92.0-1           92.0.1-1.1
                     firefox-i18n-fi               92.0-1           92.0.1-1.1
                     firefox-i18n-fr               92.0-1           92.0.1-1.1
                  firefox-i18n-fy-nl               92.0-1           92.0.1-1.1
                  firefox-i18n-ga-ie               92.0-1           92.0.1-1.1
                     firefox-i18n-gd               92.0-1           92.0.1-1.1
                     firefox-i18n-gl               92.0-1           92.0.1-1.1
                     firefox-i18n-gn               92.0-1           92.0.1-1.1
                  firefox-i18n-gu-in               92.0-1           92.0.1-1.1
                     firefox-i18n-he               92.0-1           92.0.1-1.1
                  firefox-i18n-hi-in               92.0-1           92.0.1-1.1
                     firefox-i18n-hr               92.0-1           92.0.1-1.1
                    firefox-i18n-hsb               92.0-1           92.0.1-1.1
                     firefox-i18n-hu               92.0-1           92.0.1-1.1
                  firefox-i18n-hy-am               92.0-1           92.0.1-1.1
                     firefox-i18n-ia               92.0-1           92.0.1-1.1
                     firefox-i18n-id               92.0-1           92.0.1-1.1
                     firefox-i18n-is               92.0-1           92.0.1-1.1
                     firefox-i18n-it               92.0-1           92.0.1-1.1
                     firefox-i18n-ja               92.0-1           92.0.1-1.1
                     firefox-i18n-ka               92.0-1           92.0.1-1.1
                    firefox-i18n-kab               92.0-1           92.0.1-1.1
                     firefox-i18n-kk               92.0-1           92.0.1-1.1
                     firefox-i18n-km               92.0-1           92.0.1-1.1
                     firefox-i18n-kn               92.0-1           92.0.1-1.1
                     firefox-i18n-ko               92.0-1           92.0.1-1.1
                    firefox-i18n-lij               92.0-1           92.0.1-1.1
                     firefox-i18n-lt               92.0-1           92.0.1-1.1
                     firefox-i18n-lv               92.0-1           92.0.1-1.1
                     firefox-i18n-mk               92.0-1           92.0.1-1.1
                     firefox-i18n-mr               92.0-1           92.0.1-1.1
                     firefox-i18n-ms               92.0-1           92.0.1-1.1
                     firefox-i18n-my               92.0-1           92.0.1-1.1
                  firefox-i18n-nb-no               92.0-1           92.0.1-1.1
                  firefox-i18n-ne-np               92.0-1           92.0.1-1.1
                     firefox-i18n-nl               92.0-1           92.0.1-1.1
                  firefox-i18n-nn-no               92.0-1           92.0.1-1.1
                     firefox-i18n-oc               92.0-1           92.0.1-1.1
                  firefox-i18n-pa-in               92.0-1           92.0.1-1.1
                     firefox-i18n-pl               92.0-1           92.0.1-1.1
                  firefox-i18n-pt-br               92.0-1           92.0.1-1.1
                  firefox-i18n-pt-pt               92.0-1           92.0.1-1.1
                     firefox-i18n-rm               92.0-1           92.0.1-1.1
                     firefox-i18n-ro               92.0-1           92.0.1-1.1
                     firefox-i18n-ru               92.0-1           92.0.1-1.1
                     firefox-i18n-si               92.0-1           92.0.1-1.1
                     firefox-i18n-sk               92.0-1           92.0.1-1.1
                     firefox-i18n-sl               92.0-1           92.0.1-1.1
                    firefox-i18n-son               92.0-1           92.0.1-1.1
                     firefox-i18n-sq               92.0-1           92.0.1-1.1
                     firefox-i18n-sr               92.0-1           92.0.1-1.1
                  firefox-i18n-sv-se               92.0-1           92.0.1-1.1
                     firefox-i18n-ta               92.0-1           92.0.1-1.1
                     firefox-i18n-te               92.0-1           92.0.1-1.1
                     firefox-i18n-th               92.0-1           92.0.1-1.1
                     firefox-i18n-tr               92.0-1           92.0.1-1.1
                     firefox-i18n-uk               92.0-1           92.0.1-1.1
                     firefox-i18n-ur               92.0-1           92.0.1-1.1
                     firefox-i18n-uz               92.0-1           92.0.1-1.1
                     firefox-i18n-vi               92.0-1           92.0.1-1.1
                     firefox-i18n-xh               92.0-1           92.0.1-1.1
                  firefox-i18n-zh-cn               92.0-1           92.0.1-1.1
                  firefox-i18n-zh-tw               92.0-1           92.0.1-1.1
                            mesa-git21.3.0_devel.144490.43c4f5eb63e-121.3.0_devel.145040.6f9f350622b-1
                   qqc2-breeze-style             5.22.5-1           5.22.5-1.1
:: Different sync package(s) in repository extra aarch64
                        alertmanager             0.23.0-1             0.23.0-2
                  alsa-card-profiles           1:0.3.35-1           1:0.3.37-1
                              apache             2.4.48-1             2.4.49-1
            archlinux-appstream-data           20210902-1           20210921-1
                              attica             5.85.0-1             5.86.0-1
                               baloo             5.85.0-1             5.86.0-1
                              basket              2.49b-4              2.49b-5
                         bdf-unifont            13.0.06-1            14.0.01-1
                               bftpd                5.7-1                6.0-1
                                bind            9.16.20-1            9.16.21-1
                            bluez-qt             5.85.0-1             5.86.0-1
                             brasero3.12.2+106+g46b9d116-1             3.12.3-1
                        breeze-icons             5.85.0-1             5.86.0-1
                              brltty                6.3-4                6.4-1
                              brotli              1.0.9-4                    -
                     brotli-testdata              1.0.9-4                    -
                            c-client             2007f-11             2007f-13
                            calligra             3.2.1-20             3.2.1-21
                     cantarell-fonts            1:0.301-1            1:0.303-1
                            chromium       93.0.4577.63-1       94.0.4606.61-1
                          cifs-utils               6.13-3               6.14-1
                              clamav            0.103.3-1            0.104.0-1
                               cmake             3.21.2-2             3.21.3-1
                               cmark             0.30.1-1             0.30.2-1
                            composer              2.1.6-1              2.1.8-1
                            devtools           20210202-2           20210202-3
                            discover             5.22.5-1             5.22.5-2
                                dkms              2.8.6-1              2.8.6-2
                             dnsmasq               2.85-1               2.86-1
                         egl-wayland              1.1.7-1              1.1.8-1
                                 ell               0.43-1               0.44-1
                             ethtool             1:5.13-1             1:5.14-1
                 extra-cmake-modules             5.85.0-1             5.86.0-1
                                 feh              3.7.1-1              3.7.2-1
                                fftw              3.3.9-1             3.3.10-1
                               finch             2.14.6-2             2.14.7-1
                          fluidsynth              2.2.2-1              2.2.3-1
                             fluxbox              1.3.7-61.3.7+205+g1d19662c-1
                frameworkintegration             5.85.0-1             5.86.0-1
                           freetype2             2.11.0-3             2.11.0-4
                     freetype2-demos             2.11.0-3             2.11.0-4
                      freetype2-docs             2.11.0-3             2.11.0-4
                                  gd              2.3.2-4              2.3.3-2
                                 gdb               10.2-2               11.1-1
                          gdb-common               10.2-2               11.1-1
                      geoip-database           20210824-1           20210921-1
                geoip-database-extra           20210824-1           20210921-1
                            ghostpcl             9.54.0-2             9.54.0-3
                         ghostscript             9.54.0-2             9.54.0-3
                            ghostxps             9.54.0-2             9.54.0-3
                                gimp            2.10.26-1            2.10.28-1
                     glib-networking           1:2.68.2-1           1:2.70.0-1
                                  gn    0.1910.39a87c0b-1    0.1934.69ec4fca-1
               gobject-introspection             1.68.0-1             1.70.0-1
       gobject-introspection-runtime             1.68.0-1             1.70.0-1
           gsettings-desktop-schemas               40.0-3               41.0-1
                               gssdp              1.2.3-1            1.4.0.1-1
                           gst-libav             1.18.4-1             1.18.5-1
                      gst-plugin-gtk             1.18.4-2             1.18.5-1
                   gst-plugin-opencv            1.18.4-11             1.18.5-1
                 gst-plugin-pipewire           1:0.3.35-1           1:0.3.37-1
                    gst-plugin-qmlgl             1.18.4-2             1.18.5-1
                      gst-plugin-wpe            1.18.4-11             1.18.5-1
                     gst-plugins-bad            1.18.4-11             1.18.5-1
                gst-plugins-bad-libs            1.18.4-11             1.18.5-1
                    gst-plugins-base             1.18.4-1             1.18.5-1
               gst-plugins-base-libs             1.18.4-1             1.18.5-1
                    gst-plugins-good             1.18.4-2             1.18.5-1
                    gst-plugins-ugly             1.18.4-2             1.18.5-1
                          gst-python             1.18.4-1             1.18.5-1
                           gstreamer             1.18.4-1             1.18.5-1
                      gstreamer-docs             1.18.4-1             1.18.5-1
                     gstreamer-vaapi             1.18.4-1             1.18.5-1
                                gtk3          1:3.24.30-21:3.24.30+62+g8d04980f38-2
                          gtk3-demos          1:3.24.30-21:3.24.30+62+g8d04980f38-2
                           gtk3-docs          1:3.24.30-21:3.24.30+62+g8d04980f38-2
                           gtkmm-4.0              4.2.0-2              4.4.0-1
                      gtkmm-4.0-docs              4.2.0-2              4.4.0-1
                                gvim           8.2.3412-1           8.2.3441-1
                            harfbuzz              2.9.1-1              3.0.0-1
                        harfbuzz-icu              2.9.1-1              3.0.0-1
                             haveged             1.9.14-1             1.9.14-2
                                htop              3.0.5-1              3.1.0-1
                         imagemagick            7.1.0.6-1            7.1.0.8-1
                     imagemagick-doc            7.1.0.6-1            7.1.0.8-1
                                imap             2007f-11             2007f-13
                            inkscape                1.1-6              1.1.1-1
                            jemalloc            1:5.2.1-3            1:5.2.1-5
                        jsonrpc-glib             3.38.0-1             3.40.0-1
                         kactivities             5.85.0-1             5.86.0-1
                   kactivities-stats             5.85.0-1             5.86.0-1
                             kapidox             5.85.0-1             5.86.0-1
                            karchive             5.85.0-1             5.86.0-1
                               kauth             5.85.0-1             5.86.0-1
                          kbookmarks             5.85.0-1             5.86.0-1
                       kcalendarcore             5.85.0-1             5.86.0-1
                            kcmutils             5.85.0-1             5.86.0-1
                             kcodecs             5.85.0-1             5.86.0-1
                         kcompletion             5.85.0-1             5.86.0-1
                             kconfig             5.85.0-1             5.86.0-1
                      kconfigwidgets             5.85.0-1             5.86.0-1
                           kcontacts           1:5.85.0-1           1:5.86.0-1
                         kcoreaddons             5.85.0-1             5.86.0-1
                              kcrash             5.85.0-1             5.86.0-1
                                kdav           1:5.85.0-1           1:5.86.0-1
                         kdbusaddons             5.85.0-1             5.86.0-1
                        kdeclarative             5.85.0-1             5.86.0-1
                                kded             5.85.0-1             5.86.0-1
                     kdelibs4support             5.85.0-1             5.86.0-1
                     kdesignerplugin             5.85.0-1             5.86.0-1
                               kdesu             5.85.0-1             5.86.0-1
                           kdewebkit             5.85.0-1             5.86.0-1
                              kdnssd             5.85.0-1             5.86.0-1
                           kdoctools             5.85.0-1             5.86.0-1
                          kemoticons             5.85.0-1             5.86.0-1
                       kfilemetadata             5.85.0-1             5.86.0-1
                        kglobalaccel             5.85.0-1             5.86.0-1
                          kguiaddons             5.85.0-1             5.86.0-1
                           kholidays           1:5.85.0-1           1:5.86.0-1
                               khtml             5.85.0-1             5.86.0-1
                               ki18n             5.85.0-1             5.86.0-1
                         kiconthemes             5.85.0-1             5.86.0-1
                           kidletime             5.85.0-1             5.86.0-1
                     kimageannotator              0.5.1-1              0.5.2-1
                       kimageformats             5.85.0-1             5.86.0-1
                               kinit             5.85.0-1             5.86.0-1
                                 kio             5.85.0-1             5.86.0-1
                           kirigami2             5.85.0-1             5.86.0-1
                         kitemmodels             5.85.0-1             5.86.0-1
                          kitemviews             5.85.0-1             5.86.0-1
                         kjobwidgets             5.85.0-1             5.86.0-1
                                 kjs             5.85.0-1             5.86.0-1
                            kjsembed             5.85.0-1             5.86.0-1
                        kmediaplayer             5.85.0-1             5.86.0-1
                           knewstuff             5.85.0-1             5.86.0-2
                      knotifications             5.85.0-1             5.86.0-1
                       knotifyconfig             5.85.0-1             5.86.0-1
                           konqueror            21.08.1-1            21.08.1-2
                            kpackage             5.85.0-1             5.86.0-1
                              kparts             5.85.0-1             5.86.0-1
                             kpeople             5.85.0-1             5.86.0-1
                           kplotting             5.85.0-1             5.86.0-1
                                kpty             5.85.0-1             5.86.0-1
                        kquickcharts             5.85.0-1             5.86.0-1
                               kross             5.85.0-1             5.86.0-1
                             krunner             5.85.0-1             5.86.0-1
                            kservice             5.85.0-1             5.86.0-1
                         ktexteditor             5.85.0-1             5.86.0-2
                        ktextwidgets             5.85.0-1             5.86.0-1
                     kunitconversion             5.85.0-1             5.86.0-1
                             kwallet             5.85.0-1             5.86.0-1
                            kwayland             5.85.0-1             5.86.0-1
                      kwidgetsaddons             5.85.0-1             5.86.0-1
                       kwindowsystem             5.85.0-1             5.86.0-1
                             kxmlgui             5.85.0-1             5.86.0-1
                       kxmlrpcclient             5.85.0-1             5.86.0-1
                              ladspa               1.16-1               1.17-1
                                 ldb            2:2.3.0-1            2:2.4.0-1
                              libass             0.15.1-1             0.15.2-1
                       libatomic_ops             7.6.10-2             7.6.12-1
                         libblockdev               2.25-2               2.26-1
                              libbpf              0.4.0-1              0.5.0-1
                             libexif             0.6.22-1             0.6.23-1
                            libfido2              1.7.0-2              1.8.0-1
                             libgit2            1:1.1.1-1            1:1.2.0-1
                        libgit2-glib           0.99.0.1-5           0.99.0.1-6
                            libglvnd              1.3.3-1              1.3.4-1
                            libinput             1.18.1-1             1.19.1-1
                          libmm-glib            1.16.10-1             1.18.2-1
                              libmtp             1.1.18-1             1.1.19-1
                           libnotify              0.7.9-1              0.7.9-2
                           libpurple             2.14.6-2             2.14.7-1
                             libraqm              0.7.1-1              0.7.2-1
                   libreoffice-fresh              7.2.0-2              7.2.1-2
                libreoffice-fresh-af              7.2.0-1              7.2.1-1
                libreoffice-fresh-am              7.2.0-1              7.2.1-1
                libreoffice-fresh-ar              7.2.0-1              7.2.1-1
                libreoffice-fresh-as              7.2.0-1              7.2.1-1
               libreoffice-fresh-ast              7.2.0-1              7.2.1-1
                libreoffice-fresh-be              7.2.0-1              7.2.1-1
                libreoffice-fresh-bg              7.2.0-1              7.2.1-1
                libreoffice-fresh-bn              7.2.0-1              7.2.1-1
             libreoffice-fresh-bn-in              7.2.0-1              7.2.1-1
                libreoffice-fresh-bo              7.2.0-1              7.2.1-1
                libreoffice-fresh-br              7.2.0-1              7.2.1-1
               libreoffice-fresh-brx              7.2.0-1              7.2.1-1
                libreoffice-fresh-bs              7.2.0-1              7.2.1-1
                libreoffice-fresh-ca              7.2.0-1              7.2.1-1
       libreoffice-fresh-ca-valencia              7.2.0-1              7.2.1-1
               libreoffice-fresh-ckb              7.2.0-1              7.2.1-1
                libreoffice-fresh-cs              7.2.0-1              7.2.1-1
                libreoffice-fresh-cy              7.2.0-1              7.2.1-1
                libreoffice-fresh-da              7.2.0-1              7.2.1-1
                libreoffice-fresh-de              7.2.0-1              7.2.1-1
               libreoffice-fresh-dgo              7.2.0-1              7.2.1-1
               libreoffice-fresh-dsb              7.2.0-1              7.2.1-1
                libreoffice-fresh-dz              7.2.0-1              7.2.1-1
                libreoffice-fresh-el              7.2.0-1              7.2.1-1
             libreoffice-fresh-en-gb              7.2.0-1              7.2.1-1
             libreoffice-fresh-en-za              7.2.0-1              7.2.1-1
                libreoffice-fresh-eo              7.2.0-1              7.2.1-1
                libreoffice-fresh-es              7.2.0-1              7.2.1-1
                libreoffice-fresh-et              7.2.0-1              7.2.1-1
                libreoffice-fresh-eu              7.2.0-1              7.2.1-1
                libreoffice-fresh-fa              7.2.0-1              7.2.1-1
                libreoffice-fresh-fi              7.2.0-1              7.2.1-1
                libreoffice-fresh-fr              7.2.0-1              7.2.1-1
               libreoffice-fresh-fur              7.2.0-1              7.2.1-1
                libreoffice-fresh-fy              7.2.0-1              7.2.1-1
                libreoffice-fresh-ga              7.2.0-1              7.2.1-1
                libreoffice-fresh-gd              7.2.0-1              7.2.1-1
                libreoffice-fresh-gl              7.2.0-1              7.2.1-1
                libreoffice-fresh-gu              7.2.0-1              7.2.1-1
               libreoffice-fresh-gug              7.2.0-1              7.2.1-1
                libreoffice-fresh-he              7.2.0-1              7.2.1-1
                libreoffice-fresh-hi              7.2.0-1              7.2.1-1
                libreoffice-fresh-hr              7.2.0-1              7.2.1-1
               libreoffice-fresh-hsb              7.2.0-1              7.2.1-1
                libreoffice-fresh-hu              7.2.0-1              7.2.1-1
                libreoffice-fresh-id              7.2.0-1              7.2.1-1
                libreoffice-fresh-is              7.2.0-1              7.2.1-1
                libreoffice-fresh-it              7.2.0-1              7.2.1-1
                libreoffice-fresh-ja              7.2.0-1              7.2.1-1
                libreoffice-fresh-ka              7.2.0-1              7.2.1-1
               libreoffice-fresh-kab              7.2.0-1              7.2.1-1
                libreoffice-fresh-kk              7.2.0-1              7.2.1-1
                libreoffice-fresh-km              7.2.0-1              7.2.1-1
          libreoffice-fresh-kmr-latn              7.2.0-1              7.2.1-1
                libreoffice-fresh-kn              7.2.0-1              7.2.1-1
                libreoffice-fresh-ko              7.2.0-1              7.2.1-1
               libreoffice-fresh-kok              7.2.0-1              7.2.1-1
                libreoffice-fresh-ks              7.2.0-1              7.2.1-1
                libreoffice-fresh-lb              7.2.0-1              7.2.1-1
                libreoffice-fresh-lo              7.2.0-1              7.2.1-1
                libreoffice-fresh-lt              7.2.0-1              7.2.1-1
                libreoffice-fresh-lv              7.2.0-1              7.2.1-1
               libreoffice-fresh-mai              7.2.0-1              7.2.1-1
                libreoffice-fresh-mk              7.2.0-1              7.2.1-1
                libreoffice-fresh-ml              7.2.0-1              7.2.1-1
                libreoffice-fresh-mn              7.2.0-1              7.2.1-1
               libreoffice-fresh-mni              7.2.0-1              7.2.1-1
                libreoffice-fresh-mr              7.2.0-1              7.2.1-1
                libreoffice-fresh-my              7.2.0-1              7.2.1-1
                libreoffice-fresh-nb              7.2.0-1              7.2.1-1
                libreoffice-fresh-ne              7.2.0-1              7.2.1-1
                libreoffice-fresh-nl              7.2.0-1              7.2.1-1
                libreoffice-fresh-nn              7.2.0-1              7.2.1-1
                libreoffice-fresh-nr              7.2.0-1              7.2.1-1
               libreoffice-fresh-nso              7.2.0-1              7.2.1-1
                libreoffice-fresh-oc              7.2.0-1              7.2.1-1
                libreoffice-fresh-om              7.2.0-1              7.2.1-1
                libreoffice-fresh-or              7.2.0-1              7.2.1-1
             libreoffice-fresh-pa-in              7.2.0-1              7.2.1-1
                libreoffice-fresh-pl              7.2.0-1              7.2.1-1
                libreoffice-fresh-pt              7.2.0-1              7.2.1-1
             libreoffice-fresh-pt-br              7.2.0-1              7.2.1-1
                libreoffice-fresh-ro              7.2.0-1              7.2.1-1
                libreoffice-fresh-ru              7.2.0-1              7.2.1-1
                libreoffice-fresh-rw              7.2.0-1              7.2.1-1
             libreoffice-fresh-sa-in              7.2.0-1              7.2.1-1
               libreoffice-fresh-sat              7.2.0-1              7.2.1-1
                libreoffice-fresh-sd              7.2.0-1              7.2.1-1
               libreoffice-fresh-sdk              7.2.0-2              7.2.1-2
                libreoffice-fresh-si              7.2.0-1              7.2.1-1
               libreoffice-fresh-sid              7.2.0-1              7.2.1-1
                libreoffice-fresh-sk              7.2.0-1              7.2.1-1
                libreoffice-fresh-sl              7.2.0-1              7.2.1-1
                libreoffice-fresh-sq              7.2.0-1              7.2.1-1
                libreoffice-fresh-sr              7.2.0-1              7.2.1-1
           libreoffice-fresh-sr-latn              7.2.0-1              7.2.1-1
                libreoffice-fresh-ss              7.2.0-1              7.2.1-1
                libreoffice-fresh-st              7.2.0-1              7.2.1-1
                libreoffice-fresh-sv              7.2.0-1              7.2.1-1
             libreoffice-fresh-sw-tz              7.2.0-1              7.2.1-1
               libreoffice-fresh-szl              7.2.0-1              7.2.1-1
                libreoffice-fresh-ta              7.2.0-1              7.2.1-1
                libreoffice-fresh-te              7.2.0-1              7.2.1-1
                libreoffice-fresh-tg              7.2.0-1              7.2.1-1
                libreoffice-fresh-th              7.2.0-1              7.2.1-1
                libreoffice-fresh-tn              7.2.0-1              7.2.1-1
                libreoffice-fresh-tr              7.2.0-1              7.2.1-1
                libreoffice-fresh-ts              7.2.0-1              7.2.1-1
                libreoffice-fresh-tt              7.2.0-1              7.2.1-1
                libreoffice-fresh-ug              7.2.0-1              7.2.1-1
                libreoffice-fresh-uk              7.2.0-1              7.2.1-1
                libreoffice-fresh-uz              7.2.0-1              7.2.1-1
                libreoffice-fresh-ve              7.2.0-1              7.2.1-1
               libreoffice-fresh-vec              7.2.0-1              7.2.1-1
                libreoffice-fresh-vi              7.2.0-1              7.2.1-1
                libreoffice-fresh-xh              7.2.0-1              7.2.1-1
             libreoffice-fresh-zh-cn              7.2.0-1              7.2.1-1
             libreoffice-fresh-zh-tw              7.2.0-1              7.2.1-1
                libreoffice-fresh-zu              7.2.0-1              7.2.1-1
                             librsvg           2:2.50.7-1           2:2.52.0-1
                        libsidplayfp              2.2.2-1              2.3.0-1
                             libsoup             2.74.0-1             2.74.0-2
                              libtar             1.2.20-5             1.2.20-6
                   libva-mesa-driver           21.2.1-1.1             21.2.2-1
                             libwebp              1.2.1-1              1.2.1-2
                               libxi             1.7.10-3                1.8-1
                        libxkbcommon              1.3.0-1              1.3.1-1
                    libxkbcommon-doc              1.3.0-1              1.3.1-1
                    libxkbcommon-x11              1.3.0-1              1.3.1-1
                           mercurial              5.9.1-1              5.9.1-2
                                mesa           21.2.1-1.1             21.2.2-1
                          mesa-vdpau           21.2.1-1.1             21.2.2-1
                      mkvtoolnix-cli             61.0.0-1             61.0.0-2
                      mkvtoolnix-gui             61.0.0-1             61.0.0-2
                        modemmanager            1.16.10-1             1.18.2-1
                     modemmanager-qt             5.85.0-1             5.86.0-1
                            mousepad              0.5.6-1              0.5.7-1
                               msmtp             1.8.15-1             1.8.16-1
                           msmtp-mta             1.8.15-1             1.8.16-1
                                mutt              2.1.2-1              2.1.3-1
                                neon             0.31.2-1             0.32.1-1
                   networkmanager-qt             5.85.0-1             5.86.0-1
                            nitrogen              1.6.1-3              1.6.1-4
                         opencl-mesa           21.2.1-1.1             21.2.2-1
                        oxygen-icons           1:5.85.0-1           1:5.86.0-1
                    oxygen-icons-svg           1:5.85.0-1           1:5.86.0-1
                               pango           1:1.48.9-2          1:1.48.10-1
                          pango-docs           1:1.48.9-2          1:1.48.10-1
              perl-crypt-openssl-rsa               0.31-6               0.32-1
                  perl-io-socket-ssl              2.071-1              2.072-1
                         perl-libwww               6.56-1               6.57-1
                                 php             8.0.10-1             8.0.11-1
                          php-apache             8.0.10-1             8.0.11-1
                             php-cgi             8.0.10-1             8.0.11-1
                           php-dblib             8.0.10-1             8.0.11-1
                           php-embed             8.0.10-1             8.0.11-1
                         php-enchant             8.0.10-1             8.0.11-1
                             php-fpm             8.0.10-1             8.0.11-1
                              php-gd             8.0.10-1             8.0.11-1
                            php-imap             8.0.10-1             8.0.11-1
                            php-intl             8.0.10-1             8.0.11-1
                            php-odbc             8.0.10-1             8.0.11-1
                           php-pgsql             8.0.10-1             8.0.11-1
                          php-phpdbg             8.0.10-1             8.0.11-1
                          php-pspell             8.0.10-1             8.0.11-1
                            php-snmp             8.0.10-1             8.0.11-1
                          php-sodium             8.0.10-1             8.0.11-1
                          php-sqlite             8.0.10-1             8.0.11-1
                            php-tidy             8.0.10-1             8.0.11-1
                             php-xsl             8.0.10-1             8.0.11-1
                                php7             7.4.23-1             7.4.24-1
                         php7-apache             7.4.23-1             7.4.24-1
                            php7-cgi             7.4.23-1             7.4.24-1
                          php7-dblib             7.4.23-1             7.4.24-1
                          php7-embed             7.4.23-1             7.4.24-1
                        php7-enchant             7.4.23-1             7.4.24-1
                            php7-fpm             7.4.23-1             7.4.24-1
                             php7-gd             7.4.23-1             7.4.24-1
                           php7-imap             7.4.23-1             7.4.24-1
                           php7-intl             7.4.23-1             7.4.24-1
                           php7-odbc             7.4.23-1             7.4.24-1
                          php7-pgsql             7.4.23-1             7.4.24-1
                         php7-phpdbg             7.4.23-1             7.4.24-1
                         php7-pspell             7.4.23-1             7.4.24-1
                           php7-snmp             7.4.23-1             7.4.24-1
                         php7-sodium             7.4.23-1             7.4.24-1
                         php7-sqlite             7.4.23-1             7.4.24-1
                           php7-tidy             7.4.23-1             7.4.24-1
                            php7-xsl             7.4.23-1             7.4.24-1
                              pidgin             2.14.6-2             2.14.7-1
                       pipewire-alsa           1:0.3.35-1           1:0.3.37-1
                       pipewire-docs           1:0.3.35-1           1:0.3.37-1
                       pipewire-jack           1:0.3.35-1           1:0.3.37-1
              pipewire-media-session           1:0.3.35-1           1:0.3.37-1
                      pipewire-pulse           1:0.3.35-1           1:0.3.37-1
                   pipewire-zeroconf           1:0.3.35-1           1:0.3.37-1
                    plasma-framework             5.85.0-2             5.86.0-1
                              prison             5.85.0-1             5.86.0-1
                          prometheus             2.29.2-1             2.30.0-1
                            pstoedit               3.75-5               3.76-1
                             purpose             5.85.0-1             5.86.0-1
                       python-brotli              1.0.9-4                    -
                        python-numpy             1.20.3-1             1.21.2-1
                       python-pycurl           7.43.0.6-4             7.44.1-1
                    python-pytest-qt              3.3.0-4              4.0.2-1
                   python-virtualenv             20.7.2-1             20.8.0-1
                  python2-virtualenv             20.7.2-1             20.8.0-1
                             qca-qt5              2.3.3-1              2.3.4-1
                             qca-qt6              2.3.3-1              2.3.4-1
                                qemu              6.1.0-1              6.1.0-2
                     qemu-arch-extra              6.1.0-1              6.1.0-2
                  qemu-block-gluster              6.1.0-1              6.1.0-2
                    qemu-block-iscsi              6.1.0-1              6.1.0-2
                    qemu-guest-agent              6.1.0-1              6.1.0-2
                       qemu-headless              6.1.0-1              6.1.0-2
            qemu-headless-arch-extra              6.1.0-1              6.1.0-2
                  qqc2-desktop-style             5.85.0-1             5.86.0-1
                            qt5-base    5.15.2+kde+r222-2    5.15.2+kde+r227-1
                     qt5-declarative     5.15.2+kde+r30-1     5.15.2+kde+r31-1
                 qt5-virtualkeyboard             5.15.2-1      5.15.2+kde+r4-1
                         qt5-wayland     5.15.2+kde+r30-1     5.15.2+kde+r31-1
                       qt5-webengine             5.15.6-1             5.15.6-2
             qt5-xcb-private-headers    5.15.2+kde+r222-2    5.15.2+kde+r227-1
                                qtav             1.13.0-1             1.13.0-2
                           qtcreator              5.0.0-3              5.0.1-1
                               samba             4.14.7-2             4.15.0-1
                                sddm             0.19.0-6             0.19.0-7
                          sdl2_mixer              2.0.4-6              2.0.4-7
                           smbclient             4.14.7-2             4.15.0-1
                               solid             5.85.0-1             5.86.0-1
                              sonnet             5.85.0-1             5.86.0-1
                         syndication             5.85.0-1             5.86.0-1
                 syntax-highlighting             5.85.0-1             5.86.0-1
                        threadweaver             5.85.0-1             5.86.0-1
                              thunar             4.16.8-1            4.16.10-1
                         thunderbird             91.1.0-2             91.1.1-1
                 thunderbird-i18n-af             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ar             91.1.0-2             91.1.1-1
                thunderbird-i18n-ast             91.1.0-2             91.1.1-1
                 thunderbird-i18n-be             91.1.0-2             91.1.1-1
                 thunderbird-i18n-bg             91.1.0-2             91.1.1-1
                 thunderbird-i18n-br             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ca             91.1.0-2             91.1.1-1
                thunderbird-i18n-cak             91.1.0-2             91.1.1-1
                 thunderbird-i18n-cs             91.1.0-2             91.1.1-1
                 thunderbird-i18n-cy             91.1.0-2             91.1.1-1
                 thunderbird-i18n-da             91.1.0-2             91.1.1-1
                 thunderbird-i18n-de             91.1.0-2             91.1.1-1
                thunderbird-i18n-dsb             91.1.0-2             91.1.1-1
                 thunderbird-i18n-el             91.1.0-2             91.1.1-1
              thunderbird-i18n-en-gb             91.1.0-2             91.1.1-1
              thunderbird-i18n-en-us             91.1.0-2             91.1.1-1
              thunderbird-i18n-es-ar             91.1.0-2             91.1.1-1
              thunderbird-i18n-es-es             91.1.0-2             91.1.1-1
                 thunderbird-i18n-et             91.1.0-2             91.1.1-1
                 thunderbird-i18n-eu             91.1.0-2             91.1.1-1
                 thunderbird-i18n-fi             91.1.0-2             91.1.1-1
                 thunderbird-i18n-fr             91.1.0-2             91.1.1-1
              thunderbird-i18n-fy-nl             91.1.0-2             91.1.1-1
              thunderbird-i18n-ga-ie             91.1.0-2             91.1.1-1
                 thunderbird-i18n-gd             91.1.0-2             91.1.1-1
                 thunderbird-i18n-gl             91.1.0-2             91.1.1-1
                 thunderbird-i18n-he             91.1.0-2             91.1.1-1
                 thunderbird-i18n-hr             91.1.0-2             91.1.1-1
                thunderbird-i18n-hsb             91.1.0-2             91.1.1-1
                 thunderbird-i18n-hu             91.1.0-2             91.1.1-1
              thunderbird-i18n-hy-am             91.1.0-2             91.1.1-1
                 thunderbird-i18n-id             91.1.0-2             91.1.1-1
                 thunderbird-i18n-is             91.1.0-2             91.1.1-1
                 thunderbird-i18n-it             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ja             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ka             91.1.0-2             91.1.1-1
                thunderbird-i18n-kab             91.1.0-2             91.1.1-1
                 thunderbird-i18n-kk             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ko             91.1.0-2             91.1.1-1
                 thunderbird-i18n-lt             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ms             91.1.0-2             91.1.1-1
              thunderbird-i18n-nb-no             91.1.0-2             91.1.1-1
                 thunderbird-i18n-nl             91.1.0-2             91.1.1-1
              thunderbird-i18n-nn-no             91.1.0-2             91.1.1-1
              thunderbird-i18n-pa-in             91.1.0-2             91.1.1-1
                 thunderbird-i18n-pl             91.1.0-2             91.1.1-1
              thunderbird-i18n-pt-br             91.1.0-2             91.1.1-1
              thunderbird-i18n-pt-pt             91.1.0-2             91.1.1-1
                 thunderbird-i18n-rm             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ro             91.1.0-2             91.1.1-1
                 thunderbird-i18n-ru             91.1.0-2             91.1.1-1
                 thunderbird-i18n-sk             91.1.0-2             91.1.1-1
                 thunderbird-i18n-sl             91.1.0-2             91.1.1-1
                 thunderbird-i18n-sq             91.1.0-2             91.1.1-1
                 thunderbird-i18n-sr             91.1.0-2             91.1.1-1
              thunderbird-i18n-sv-se             91.1.0-2             91.1.1-1
                 thunderbird-i18n-th             91.1.0-2             91.1.1-1
                 thunderbird-i18n-tr             91.1.0-2             91.1.1-1
                 thunderbird-i18n-uk             91.1.0-2             91.1.1-1
                 thunderbird-i18n-uz             91.1.0-2             91.1.1-1
                 thunderbird-i18n-vi             91.1.0-2             91.1.1-1
              thunderbird-i18n-zh-cn             91.1.0-2             91.1.1-1
              thunderbird-i18n-zh-tw             91.1.0-2             91.1.1-1
                             tomcat8             8.5.70-1             8.5.71-1
                            tracker3              3.1.2-1              3.2.0-2
                     tracker3-miners              3.1.2-2 3.2.0+6+gfffef2772-1
          unicode-character-database             13.0.0-1             14.0.0-1
                                vala             0.52.5-1             0.54.1-1
                             varnish              6.6.1-2              7.0.0-1
                         vim-runtime           8.2.3412-1           8.2.3441-1
                     vulkan-broadcom           21.2.1-1.1             21.2.2-1
                   vulkan-icd-loader            1.2.190-1            1.2.191-1
                  vulkan-mesa-layers           21.2.1-1.1             21.2.2-1
                     vulkan-panfrost           21.2.1-1.1             21.2.2-1
                       vulkan-radeon           21.2.1-1.1             21.2.2-1
                       vulkan-swrast           21.2.1-1.1             21.2.2-1
                   wayland-protocols               1.22-1               1.23-1
                          webkit2gtk             2.32.3-1             2.32.4-1
                     wireguard-tools       1.0.20210424-1       1.0.20210914-1
                           wpewebkit             2.32.3-1             2.32.4-1
                  xdg-desktop-portal              1.8.1-1             1.10.1-1
              xdg-desktop-portal-gtk              1.8.0-1             1.10.0-1
                 xf86-input-libinput              1.1.0-1              1.2.0-1
                    xkeyboard-config               2.33-1               2.33-2
                           xorgproto             2021.4-1             2021.5-1
                               xterm                368-1                369-1
                             firefox                    -           92.0.1-1.1
                    firefox-i18n-ach                    -             92.0.1-1
                     firefox-i18n-af                    -             92.0.1-1
                     firefox-i18n-an                    -             92.0.1-1
                     firefox-i18n-ar                    -             92.0.1-1
                    firefox-i18n-ast                    -             92.0.1-1
                     firefox-i18n-az                    -             92.0.1-1
                     firefox-i18n-be                    -             92.0.1-1
                     firefox-i18n-bg                    -             92.0.1-1
                     firefox-i18n-bn                    -             92.0.1-1
                     firefox-i18n-br                    -             92.0.1-1
                     firefox-i18n-bs                    -             92.0.1-1
                     firefox-i18n-ca                    -             92.0.1-1
            firefox-i18n-ca-valencia                    -             92.0.1-1
                    firefox-i18n-cak                    -             92.0.1-1
                     firefox-i18n-cs                    -             92.0.1-1
                     firefox-i18n-cy                    -             92.0.1-1
                     firefox-i18n-da                    -             92.0.1-1
                     firefox-i18n-de                    -             92.0.1-1
                    firefox-i18n-dsb                    -             92.0.1-1
                     firefox-i18n-el                    -             92.0.1-1
                  firefox-i18n-en-ca                    -             92.0.1-1
                  firefox-i18n-en-gb                    -             92.0.1-1
                  firefox-i18n-en-us                    -             92.0.1-1
                     firefox-i18n-eo                    -             92.0.1-1
                  firefox-i18n-es-ar                    -             92.0.1-1
                  firefox-i18n-es-cl                    -             92.0.1-1
                  firefox-i18n-es-es                    -             92.0.1-1
                  firefox-i18n-es-mx                    -             92.0.1-1
                     firefox-i18n-et                    -             92.0.1-1
                     firefox-i18n-eu                    -             92.0.1-1
                     firefox-i18n-fa                    -             92.0.1-1
                     firefox-i18n-ff                    -             92.0.1-1
                     firefox-i18n-fi                    -             92.0.1-1
                     firefox-i18n-fr                    -             92.0.1-1
                  firefox-i18n-fy-nl                    -             92.0.1-1
                  firefox-i18n-ga-ie                    -             92.0.1-1
                     firefox-i18n-gd                    -             92.0.1-1
                     firefox-i18n-gl                    -             92.0.1-1
                     firefox-i18n-gn                    -             92.0.1-1
                  firefox-i18n-gu-in                    -             92.0.1-1
                     firefox-i18n-he                    -             92.0.1-1
                  firefox-i18n-hi-in                    -             92.0.1-1
                     firefox-i18n-hr                    -             92.0.1-1
                    firefox-i18n-hsb                    -             92.0.1-1
                     firefox-i18n-hu                    -             92.0.1-1
                  firefox-i18n-hy-am                    -             92.0.1-1
                     firefox-i18n-ia                    -             92.0.1-1
                     firefox-i18n-id                    -             92.0.1-1
                     firefox-i18n-is                    -             92.0.1-1
                     firefox-i18n-it                    -             92.0.1-1
                     firefox-i18n-ja                    -             92.0.1-1
                     firefox-i18n-ka                    -             92.0.1-1
                    firefox-i18n-kab                    -             92.0.1-1
                     firefox-i18n-kk                    -             92.0.1-1
                     firefox-i18n-km                    -             92.0.1-1
                     firefox-i18n-kn                    -             92.0.1-1
                     firefox-i18n-ko                    -             92.0.1-1
                    firefox-i18n-lij                    -             92.0.1-1
                     firefox-i18n-lt                    -             92.0.1-1
                     firefox-i18n-lv                    -             92.0.1-1
                     firefox-i18n-mk                    -             92.0.1-1
                     firefox-i18n-mr                    -             92.0.1-1
                     firefox-i18n-ms                    -             92.0.1-1
                     firefox-i18n-my                    -             92.0.1-1
                  firefox-i18n-nb-no                    -             92.0.1-1
                  firefox-i18n-ne-np                    -             92.0.1-1
                     firefox-i18n-nl                    -             92.0.1-1
                  firefox-i18n-nn-no                    -             92.0.1-1
                     firefox-i18n-oc                    -             92.0.1-1
                  firefox-i18n-pa-in                    -             92.0.1-1
                     firefox-i18n-pl                    -             92.0.1-1
                  firefox-i18n-pt-br                    -             92.0.1-1
                  firefox-i18n-pt-pt                    -             92.0.1-1
                     firefox-i18n-rm                    -             92.0.1-1
                     firefox-i18n-ro                    -             92.0.1-1
                     firefox-i18n-ru                    -             92.0.1-1
                     firefox-i18n-si                    -             92.0.1-1
                     firefox-i18n-sk                    -             92.0.1-1
                     firefox-i18n-sl                    -             92.0.1-1
                    firefox-i18n-son                    -             92.0.1-1
                     firefox-i18n-sq                    -             92.0.1-1
                     firefox-i18n-sr                    -             92.0.1-1
                  firefox-i18n-sv-se                    -             92.0.1-1
                     firefox-i18n-ta                    -             92.0.1-1
                     firefox-i18n-te                    -             92.0.1-1
                     firefox-i18n-th                    -             92.0.1-1
                     firefox-i18n-tl                    -             92.0.1-1
                     firefox-i18n-tr                    -             92.0.1-1
                    firefox-i18n-trs                    -             92.0.1-1
                     firefox-i18n-uk                    -             92.0.1-1
                     firefox-i18n-ur                    -             92.0.1-1
                     firefox-i18n-uz                    -             92.0.1-1
                     firefox-i18n-vi                    -             92.0.1-1
                     firefox-i18n-xh                    -             92.0.1-1
                  firefox-i18n-zh-cn                    -             92.0.1-1
                  firefox-i18n-zh-tw                    -             92.0.1-1
                          gssdp-docs                    -            1.4.0.1-1
                            libsoup3                    -              3.0.0-2
               power-profiles-daemon                    -              0.9.0-4
                       tracker3-docs                    -              3.2.0-2
                       wayland-utils                    -              1.0.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.08.1.r12575.g7cc57d6a2-121.08.1.r12604.gd7d907e67-1
                    akonadi-calendar21.08.1.r1984.g1192e6d-121.08.1.r1990.g8eecf47-1
              akonadi-calendar-tools21.08.1.r898.gc804ef5-121.08.1.r907.gfde30f6-1
                    akonadi-contacts21.08.1.r3061.g94013a3a-121.08.1.r3067.g2ba39cb9-1
               akonadi-import-wizard21.08.1.r1739.gf5e8060-121.08.1.r1758.gedec9c8-1
                        akonadi-mime21.08.1.r1648.g3dd0baa-121.08.1.r1654.gd440a08-1
                       akonadi-notes21.08.1.r1025.g2552b56-121.08.1.r1029.g3b6fc2d-1
                      akonadi-search21.08.1.r1126.gf440581-121.08.1.r1130.gf22f09a-1
                      akonadiconsole21.08.1.r1526.g89dc082-121.08.1.r1533.g64cf187-1
                           akregator21.08.1.r6222.g6f6395e6-121.08.1.r6228.gfbf4fabc-1
                           alligator  21.08.r1.g38dca0b-1  21.08.r2.g7c0b49e-1
                           angelfish  21.08.r9.gf8e31f6-1 21.08.r20.g1ebd161-1
                                 ark21.08.1.r4612.g552afb85-121.08.1.r4614.gc0a94112-1
                              attica5.85.0.r834.g0dbf2b6-15.86.0.r836.g04bd6dc-1
                               baloo5.85.0.r3008.g8909640a-15.86.0.r3008.g8909640a-1
                       baloo-widgets21.08.1.r703.g37f30d9-121.08.1.r704.g1b2ab3a-1
                             blinken21.08.1.r631.g91d0068-121.08.1.r635.g1b32fef-1
                           bluedevil1:5.22.5.r2280.gde1e0734-11:5.22.5.r2288.g33fe33f0-1
                            bluez-qt5.85.0.r679.gba3af75-15.86.0.r679.gba3af75-1
                              bomber21.08.1.r525.g558fa34-121.08.1.r527.gfff4ec7-1
                              breeze5.22.5.r2242.g3082f37f-15.22.5.r2276.g59605fd9-1
                          breeze-gtk5.22.5.r422.g4db54ea-15.22.5.r427.g4e3d0c7-1
                        breeze-icons5.85.0.r1789.g9089f648-15.86.0.r1792.g264bb9a5-1
                                buho  2.0.0.r5.g343a468-1  2.0.0.r7.g185655a-1
                     calendarsupport21.08.1.r33.gbd875a6-121.08.1.r40.gc588b5f-1
                           calindori  21.08.r0.gf739058-1  21.08.r2.g5217d44-1
                            discover5.22.5.r8298.g48ee793f-15.22.5.r8336.g11e72936-1
                             dolphin21.08.1.r6705.gde7c7ca27-121.08.1.r6709.gd3f427a6d-1
                     dolphin-plugins21.08.1.r604.gffad27d-121.08.1.r606.gffcc33d-1
                              dragon21.08.1.r1011.gaeba124-121.08.1.r1012.g1f1d89c-1
                             drkonqi5.22.5.r684.gace905b0-15.22.5.r698.gf31ee17e-1
                               elisa21.08.1.r2768.g0dd33183-121.08.1.r2777.g92b5ca8c-1
                          eventviews21.08.1.r37.g755eaa6-121.08.1.r49.g623caea-1
                 extra-cmake-modules5.85.0.r3365.g4282b34-15.86.0.r3370.g3df459c-1
                frameworkintegration5.85.0.r598.g0a57fd9-15.86.0.r598.g0a57fd9-1
                           granatier21.08.1.r930.gc86a329-121.08.1.r932.g186d30f-1
                     grantlee-editor21.08.1.r770.g421e4df-121.08.1.r774.g4470014-1
                       grantleetheme21.08.1.r344.g22b988b-121.08.1.r348.g15e5d95-1
                            gwenview21.08.1.r6662.g33d6203c-121.08.1.r6679.g9d753ca3-1
                     incidenceeditor21.08.1.r768.gf7a43aa-121.08.1.r774.ga820ee5-1
                            index-fm 2.0.0.r13.g9cb6e72-1 2.0.0.r24.gb4f358a-1
                           itinerary21.08.1.r1449.gb408488-121.08.1.r1460.g21893b1-1
                                 k3b1:21.08.1.r6674.g08de2191e-11:21.08.1.r6677.gae173289a-1
               kaccounts-integration21.08.1.r1218.g3a0486d-121.08.1.r1224.gea8f0d8-1
                         kactivities5.85.0.r1363.g207c2dc-15.86.0.r1363.g207c2dc-1
                   kactivities-stats5.85.0.r372.g195fbd2-15.86.0.r372.g195fbd2-1
                        kaddressbook21.08.1.r6040.g62ccc2ec-121.08.1.r6050.g018281b8-1
                              kalarm21.08.1.r6463.g0af8aa34-121.08.1.r6466.g82369401-1
                           kalarmcal21.08.1.r1145.g4deaf3c-121.08.1.r1148.gfe25b13-1
                              kamera21.08.1.r665.gd8ad7f5-121.08.1.r666.g28de32a-1
                             kapidox5.85.0.r553.g8ac0bf3-15.86.0.r553.g8ac0bf3-1
                              kapman21.08.1.r606.g4c5d88b-121.08.1.r608.gdcad1c6-1
                            karchive5.85.0.r507.g858a749-15.86.0.r507.g858a749-1
                               kasts  21.08.r7.g938a517-1 21.08.r29.g06e8d8d-1
                                kate21.08.1.r18345.g2636bb3a9-121.08.1.r18372.gba4d4ccc0-1
                             katomic21.08.1.r920.g7b5c821-121.08.1.r921.g482ba5a-1
                               kauth5.85.0.r449.ga6a0c5a-15.86.0.r449.ga6a0c5a-1
                             kbackup21.08.1.r394.gddcd002-121.08.1.r395.gf140c80-1
                           kblackbox21.08.1.r727.g865ff49-121.08.1.r728.g90fc514-1
                          kbookmarks5.85.0.r422.g7d0378a-15.86.0.r422.g7d0378a-1
                           kbreakout21.08.1.r865.g9e21fa5-121.08.1.r867.ge54c382-1
                              kbruch21.08.1.r817.gfed951b-121.08.1.r818.g8f9399b-1
                         kcachegrind21.08.1.r1152.gbe3f69d-121.08.1.r1156.g9579e5d-1
                  kcachegrind-common21.08.1.r1152.gbe3f69d-121.08.1.r1156.g9579e5d-1
                               kcalc21.08.1.r1522.g1524f0a-121.08.1.r1537.gee7a3ab-1
                       kcalendarcore5.85.0.r1239.g10cfe8918-15.86.0.r1241.gbd6b9749f-1
                           kcalutils21.08.1.r871.g7ffcc18f3-121.08.1.r887.gdb9db0bdb-1
                         kcharselect21.08.1.r476.g428e547-121.08.1.r477.g2b0ce35-1
                              kclock  21.08.r3.g3d800cf-1  21.08.r8.g48d1d79-1
                            kcmutils5.85.0.r548.g5e7c27f-15.86.0.r550.g1e9c4fe-1
                             kcodecs5.85.0.r386.g5e7feae-15.86.0.r388.gbf88853-1
                         kcompletion5.85.0.r457.g04f8bcb-15.86.0.r459.g764f6bd-1
                             kconfig5.85.0.r863.g7827501-15.86.0.r866.g5617e6d-1
                      kconfigwidgets5.85.0.r621.g652be62-15.86.0.r621.g652be62-1
                           kcontacts1:5.85.0.r3254.g7ff774b3-11:5.86.0.r3254.g7ff774b3-1
                         kcoreaddons5.85.0.r1292.g49d1ce7f-15.86.0.r1298.g61ce6c7b-1
                              kcrash5.85.0.r409.gf0a9e01-15.86.0.r409.gf0a9e01-1
                               kcron21.08.1.r778.gec9a965-121.08.1.r780.g884a2d1-1
                                kdav1:5.85.0.r1300.gbb550f6-11:5.86.0.r1301.g4e4571a-1
                         kdbusaddons5.85.0.r380.g54bc427-15.86.0.r381.gd645ec3-1
                       kde-cli-tools5.22.5.r1862.g927db99-15.22.5.r1865.g75e9d72-1
                      kde-gtk-config5.22.5.r910.g31496c4-15.22.5.r913.gb36ccaf-1
                      kdebugsettings21.08.1.r848.gabcfb20-121.08.1.r853.g9a398a3-1
                        kdeclarative5.85.0.r922.gbfe8ca1-15.86.0.r925.gfc38a94-1
                          kdeconnect21.08.1.r3321.gdb697c56-121.08.1.r3333.gee85a5d5-1
                         kdecoration5.22.5.r269.gbd1fc8d-15.22.5.r273.g343cade-1
                                kded5.85.0.r418.gb278fc4-15.86.0.r419.g6731b81-1
            kdegraphics-thumbnailers21.08.1.r236.g918502e-121.08.1.r237.g2c062c3-1
                     kdelibs4support5.85.0.r1037.g34b4edc2-15.86.0.r1037.g34b4edc2-1
              kdenetwork-filesharing21.08.1.r892.gc00b69f-121.08.1.r894.g73404b4-1
                            kdenlive21.08.0.r14776.gf44f74d7d-121.08.1.r14973.g293f0edd6-1
                       kdepim-addons21.08.1.r4330.g432ec4f4-121.08.1.r4345.g1b86d024-1
                      kdepim-runtime21.08.1.r15275.g6ef03229b-121.08.1.r15314.g7643c5915-1
                    kdeplasma-addons5.22.5.r8583.g350b81a81-15.22.5.r8589.g6cc2388c8-1
                     kdesignerplugin5.85.0.r336.g9733059-15.86.0.r336.g9733059-1
                               kdesu5.85.0.r476.ge88b633-15.86.0.r476.ge88b633-1
                           kdewebkit5.85.0.r283.g787f1a3-15.86.0.r283.g787f1a3-1
                                 kdf21.08.1.r801.gc53ce1a-121.08.1.r804.g608d3f6-1
                            kdiamond21.08.1.r671.g0e63a0f-121.08.1.r672.gf4459d8-1
                              kdnssd5.85.0.r326.g695a135-15.86.0.r326.g695a135-1
                           kdoctools5.85.0.r629.gfbd4377-15.86.0.r629.gfbd4377-1
                      keditbookmarks21.08.1.r2747.ge96a0c3cc-121.08.1.r2748.gb8b636c66-1
                          kemoticons5.85.0.r387.g1c526eb-15.86.0.r387.g1c526eb-1
                       kfilemetadata5.85.0.r809.gec8cde7-15.86.0.r809.gec8cde7-1
                             kfloppy21.08.1.r757.g486bdef-121.08.1.r759.gc62b879-1
                             kgamma55.22.5.r457.g45f405d-15.22.5.r459.g57abda6-1
                                kget21.08.1.r3121.g8d673262-121.08.1.r3123.g6c7c70c1-1
                        kglobalaccel5.85.0.r468.gc5ee700-15.86.0.r469.ge928938-1
                          kguiaddons5.85.0.r391.ga846d64-15.86.0.r392.g22c428e-1
                            khangman21.08.1.r1565.ga82efb3-121.08.1.r1566.g58a1700-1
                  khealthcertificate        r73.5d4e42e-1        r81.8c5253b-1
                         khelpcenter21.08.1.r2678.gebc327a7-121.08.1.r2679.gaa802c99-1
                           kholidays1:5.85.0.r959.g3a5164e-11:5.86.0.r961.gb1500cd-1
                            khotkeys5.22.5.r2092.gfe5c2a8-15.22.5.r2095.g3bfd01f-1
                               khtml5.85.0.r558.g5756c1e-15.86.0.r558.g5756c1e-1
                               ki18n5.85.0.r480.g8a8d70c-15.86.0.r480.g8a8d70c-1
                         kiconthemes5.85.0.r544.gf721a67-15.86.0.r544.gf721a67-1
                 kidentitymanagement21.08.1.r3821.g4a32d4d5-121.08.1.r3825.g321702d3-1
                           kidletime5.85.0.r318.geb71712-15.86.0.r318.geb71712-1
                            killbots21.08.1.r738.gee08736-121.08.1.r740.g8a2b782-1
                       kimageformats5.85.0.r359.g45cd128-15.86.0.r360.g6458c9a-1
                               kimap21.08.1.r1112.g5f3509e-121.08.1.r1118.g066cc22-1
                         kinfocenter5.22.5.r1922.g003f003-15.22.5.r1934.g874d5d2-1
                               kinit5.85.0.r413.ga0c6715-15.86.0.r414.g11a0ffc-1
                                 kio5.85.0.r4965.gae2f5eb9-15.86.0.r5003.g402abea0-1
                          kio-extras21.08.1.r7115.g90d10ae7-121.08.1.r7125.g98855307-1
                          kio-gdrive21.08.1.r568.g7607e00-121.08.1.r569.gfaab51e-1
                           kirigami25.85.0.r2886.g07abb970-15.86.0.r2907.g2a3a3889-1
                         kitemmodels5.85.0.r559.gfa3b693-15.86.0.r559.gfa3b693-1
                          kitemviews5.85.0.r341.g39dc29e-15.86.0.r342.g30e9515-1
                               kiten21.08.1.r1147.gf71fae4-121.08.1.r1148.g3eeccd9-1
                          kitinerary21.08.1.r1934.g1864c3e-121.08.1.r1961.g81b7c2a-1
                         kjobwidgets5.85.0.r379.ge71984a-15.86.0.r379.ge71984a-1
                                 kjs5.85.0.r337.g2cf609d-15.86.0.r337.g2cf609d-1
                            kjsembed5.85.0.r306.gaaf5dd2-15.86.0.r306.gaaf5dd2-1
                        kjumpingcube21.08.1.r788.g458b5ce-121.08.1.r789.g53fde8d-1
                               kldap21.08.1.r885.g599501c-121.08.1.r889.g944a745-1
                           kleopatra21.08.1.r5991.gba72eade-121.08.1.r6001.g777c179b-1
                            klettres21.08.1.r915.gabb53f5-121.08.1.r916.gd84f133-1
                            klickety21.08.1.r637.gc086690-121.08.1.r638.g30e0336-1
                              klines21.08.1.r769.g33a870b-121.08.1.r771.gb28676e-1
                               kmail21.08.1.r25957.g3fd1720a9-121.08.1.r25983.g0e0da7785-1
                kmail-account-wizard21.08.1.r816.g9cadf59-121.08.1.r824.g30e4c9a-1
                      kmailtransport21.08.1.r1656.g08cf010-121.08.1.r1666.gf4dda58-1
                               kmbox21.08.1.r541.gf32ef3c-121.08.1.r545.g316e720-1
                        kmediaplayer5.85.0.r297.g7315fa5-15.86.0.r297.g7315fa5-1
                           kmenuedit5.22.5.r971.g4b52f0c-15.22.5.r973.g7dd69ed-1
                               kmime21.08.1.r1458.g103179b-121.08.1.r1461.g071aeac-1
                              kmines21.08.1.r1722.gb8a94d6-121.08.1.r1724.g7fa5e75-1
                                kmix21.08.1.r2382.g304af5fc-121.08.1.r2383.g0ef1805b-1
                        knavalbattle21.08.1.r1390.g1fcbe9d-121.08.1.r1392.g34e09c4-1
                            knetwalk21.08.1.r659.gf294dfd-121.08.1.r660.g83c5aa5-1
                           knewstuff5.85.0.r1204.g5c08bbb3-15.86.0.r1219.g44b5113d-1
                             knights21.08.1.r1050.gbc8f3d2-121.08.1.r1051.g6cfa479-1
                              knotes21.08.1.r3516.g6cf6d5b7-121.08.1.r3522.g8b0d1ff7-1
                      knotifications5.85.0.r680.g471bd77-15.86.0.r682.gf0ce72d-1
                       knotifyconfig5.85.0.r355.gee646b9-15.86.0.r355.gee646b9-1
                                koko  21.08.r4.g4437b03-1 21.08.r16.gfabe235-1
                                kolf21.08.1.r1443.g6ea5e84-121.08.1.r1444.g7dc7698-1
                         kolourpaint21.08.1.r2363.gcfe3d636-121.08.1.r2364.g85bdf6d6-1
                           konqueror21.08.1.r14936.g80c20b528-121.08.1.r14955.g1414698ee-1
                             konsole21.08.1.r7941.gab25bd0a-121.08.1.r7960.g8489c8e1-1
                             kontact21.08.1.r5382.gdeba0f99-121.08.1.r5389.g4f3b1b85-1
                    kontactinterface21.08.1.r633.g73a7a65-121.08.1.r636.g9d836e9-1
                              kopete20.12.2.r16394.g1decd7b40-121.08.1.r16399.gec24d08f0-1
                          korganizer21.08.1.r11497.g85fb36087-121.08.1.r11511.g815cfcee2-1
                       kosmindoormap21.08.1.r647.g14f654a-121.08.1.r657.g56c4904-1
                            kpackage5.85.0.r699.g3e01da3-15.86.0.r699.g3e01da3-1
                              kparts5.85.0.r527.gcb16108-15.86.0.r528.gfa6ae49-1
                             kpeople5.85.0.r1346.g96ddb92-15.86.0.r1346.g96ddb92-1
                         kpeoplesink       r74.g69c548a-1       r75.gb79c4af-1
                        kpeoplevcard   0.1.r14.gc6a135a-1   0.1.r15.g0d12452-1
                        kpimtextedit21.08.1.r1409.g490343b-121.08.1.r1453.ge4d8ae4-1
                             kpkpass21.08.1.r239.gfd23c58-121.08.1.r242.g9dd3732-1
                           kplotting5.85.0.r296.g3060059-15.86.0.r296.g3060059-1
                                kpty5.85.0.r343.g75750f0-15.86.0.r343.g75750f0-1
                    kpublictransport21.08.1.r1836.gc41cbf5e-121.08.1.r1843.g89b48a76-1
                        kquickcharts5.85.0.r480.g627c40f-15.86.0.r480.g627c40f-1
                   kquickimageeditor       r56.g9273b40-1       r60.g6107676-1
                                krdc21.08.1.r1537.gab2a1a3-121.08.1.r1540.g8610267-1
                           krecorder  21.08.r2.gb7676d0-1  21.08.r4.g93865a4-1
                               kross5.85.0.r337.g7db053c-15.86.0.r337.g7db053c-1
                              kruler21.08.1.r701.ge556d0a-121.08.1.r702.g97633ef-1
                             krunner5.85.0.r670.gd53c5c2-15.86.0.r675.gf178b55-1
                             kscreen5.22.5.r1352.g7b2ecb9-15.22.5.r1368.ga8143d4-1
                       kscreenlocker5.22.5.r871.g7157c9a-15.22.5.r877.g0f5cfa6-1
                            kservice5.85.0.r944.g927daaf-15.86.0.r947.g362951e-1
                             kshisen21.08.1.r1202.ge43cf2c-121.08.1.r1203.ge0961d9-1
                               ksmtp21.08.1.r368.g0caf31f-121.08.1.r383.g691b693-1
                          ksnakeduel21.08.1.r809.g27dabac-121.08.1.r810.ga84f637-1
                          kspaceduel21.08.1.r634.gb10a003-121.08.1.r635.geb4e797-1
                            ksquares21.08.1.r517.gcf195bb-121.08.1.r518.g3c1a44e-1
                         ksshaskpass5.22.5.r197.gcc50f63-15.22.5.r199.g1940b3e-1
                          ksystemlog21.08.1.r659.g83fd7a3-121.08.1.r661.g60929a8-1
                        ksystemstats5.22.5.r193.g207b896-15.22.5.r197.gc5aba84-1
                         ktexteditor5.85.0.r2942.g6fae77cf-15.86.0.r2944.g30f6cf19-1
                        ktextwidgets5.85.0.r414.g8901446-15.86.0.r415.ge76a94f-1
                              ktimer21.08.1.r470.g4705ed6-121.08.1.r471.g3c7d517-1
                               ktnef21.08.1.r665.g8ff8b40-121.08.1.r669.g7ab3a4e-1
                            ktorrent21.08.1.r2777.gc87029dd-121.08.1.r2778.ge4a201b9-1
                              ktouch21.08.1.r2141.gbd68c2a-121.08.1.r2143.g5d3d6cd-1
                     kunitconversion5.85.0.r378.g6e34b50-15.86.0.r378.g6e34b50-1
                             kwallet5.85.0.r1091.gf379e5f-15.86.0.r1091.gf379e5f-1
                         kwallet-pam5.22.5.r253.g258c428-15.22.5.r255.ga5dd462-1
                      kwalletmanager21.08.1.r1208.g0a74834-121.08.1.r1212.gbdf10cf-1
                            kwayland5.85.0.r1114.gc662581-15.86.0.r1114.gc662581-1
                kwayland-integration5.22.5.r186.g11769dd-15.22.5.r189.gda7ddbb-1
                     kwayland-server5.22.5.r1386.ga6a4760-15.22.5.r1393.g67e629a-1
                            kweather  21.08.r8.gb00ec36-1 21.08.r19.g3735c3e-1
                        kweathercore    0.5.r0.gb6ef51c-1    0.5.r1.g2be08aa-1
                      kwidgetsaddons5.85.0.r874.g05a6fcfd-15.86.0.r878.g76ecd700-1
                                kwin5.22.5.r19986.gabe6b4153-15.22.5.r20056.gef06b8ed9-1
                       kwindowsystem5.85.0.r628.g5d08848-15.86.0.r628.g5d08848-1
                              kwinft5.22.4.r19295.g053293198-15.22.4.r19339.g626fd5de1-1
                           kwordquiz21.08.1.r1146.g6ca5430-121.08.1.r1147.gc5725a0-1
                              kwrite21.08.1.r18345.g2636bb3a9-121.08.1.r18372.gba4d4ccc0-1
                             kwrited5.22.5.r482.g9548753-15.22.5.r484.g25fc24c-1
                             kxmlgui5.85.0.r808.g319b9318-15.86.0.r809.g0f2608f3-1
                       kxmlrpcclient5.85.0.r458.ga1ec55b43-15.86.0.r458.ga1ec55b43-1
                      layer-shell-qt5.21.5.r43.g331505a-15.21.5.r46.g06815f2-1
                          libakonadi21.08.1.r12575.g7cc57d6a2-121.08.1.r12604.gd7d907e67-1
                         libgravatar21.08.1.r369.gbb3111c-121.08.1.r372.g8e07a3f-1
                            libkcddb21.08.1.r736.g24d5755-121.08.1.r739.ge4cae29-1
                           libkdepim21.08.1.r850.gf067cdb-121.08.1.r854.g094931a-1
                            libkgapi21.08.1.r1296.gad7e812-121.08.1.r1299.g424b7c6-1
                             libkleo21.08.1.r933.g7a08864-121.08.1.r954.gd86eda3-1
                            libksane21.08.1.r561.gd9ab411-121.08.1.r562.g6db0765-1
                          libkscreen5.22.5.r1591.g94b5c19-15.22.5.r1595.gb6f7e16-1
                           libksieve21.08.1.r1586.gfaa0e310-121.08.1.r1597.g8e8a9b1f-1
                        libksysguard5.22.5.r2302.g8f49602-15.22.5.r2307.ge00ac4a-1
                         libktorrent21.08.1.r526.gb7edbf4-121.08.1.r539.gbf23d9a-1
                         libquotient     r2081.g9e548e0-1     r2106.gf7e15e7-1
                            lokalize21.08.1.r1769.gfccb25a-121.08.1.r1780.g749a2e88-1
                          mailcommon21.08.1.r1112.gbc29098-121.08.1.r1121.gcd065dc-1
                        mailimporter21.08.1.r473.g45e02ff-121.08.1.r476.g12a62c7-1
                    maliit-framework0.99.1.r71.g3ef56e25-10.99.1.r94.ga9ab4948-1
                     maliit-keyboard    r2105.ge373c9fc-1    r2126.g70d2cda1-1
                           maui-clip  2.0.0.r6.g2a69c67-1  2.0.0.r9.gf3cb75f-1
                           maui-nota  2.0.0.r6.g9689cfc-1  2.0.0.r8.gbfe9d04-1
                            maui-pix  2.0.0.r4.g5e04d12-1 2.0.0.r11.g8d11039-1
                             mauikit 2.0.1.r7.gfbb3e9da-12.0.2.r11.gc4531477-1
                    mauikit-accounts  2.0.1.r0.gbb4a052-1  2.0.1.r1.g2699dbe-1
                mauikit-filebrowsing  2.0.1.r3.g7ec385a-1  2.0.2.r6.g9434330-1
                  mauikit-imagetools  2.0.1.r0.g99dd3ed-1  2.0.1.r2.g3910642-1
                  mauikit-texteditor  2.0.1.r0.g4075d1c-1  2.0.1.r3.g13b6a5b-1
                       mbox-importer21.08.1.r516.g42efae8-121.08.1.r521.gb839f11-1
                          messagelib21.08.1.r6179.ge28d6ce3-121.08.1.r6199.g2730222f-1
                               milou5.22.5.r748.gc10c48c-15.22.5.r750.gb598453-1
                     modemmanager-qt5.85.0.r523.gc4fd1f1-15.86.0.r523.gc4fd1f1-1
                             neochat    r1858.gaf299257-1    r1876.g71d01593-1
                   networkmanager-qt5.85.0.r1121.g95baae9-15.86.0.r1121.g95baae9-1
                              okular21.08.1.r9466.g3a513f34b-121.08.1.r9486.gb22bba31f-1
                              oxygen5.22.5.r4426.g30a5d585-15.22.5.r4430.gd29cd5a0-1
                        oxygen-icons1:5.85.0.r5.gbff159d-11:5.86.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.85.0.r5.gbff159d-11:5.86.0.r5.gbff159d-1
                              parley21.08.1.r4455.g55172e88-121.08.1.r4456.g10cf6ea4-1
                   pim-data-exporter21.08.1.r2451.gaf562344-121.08.1.r2457.g6ca2e55f-1
                    pim-sieve-editor21.08.1.r1511.ga77b0c7-121.08.1.r1516.gf0e7e2f-1
                           pimcommon21.07.80.r1106.ge73d898-121.07.80.r1115.g10e79a0-1
          plasma-browser-integration5.22.5.r1278.g9d9726f2-15.22.5.r1281.g50950913-1
                      plasma-desktop5.22.5.r8607.g81dbc710b-15.22.5.r8637.gb4895ef0e-1
                       plasma-dialer  21.08.r2.gae2c182-1  21.08.r8.g8cc6788-1
                        plasma-disks5.22.5.r229.g920cbc0-15.22.5.r232.g76f263d-1
                     plasma-firewall5.22.5.r510.g6558f6c-15.22.5.r521.g9d7e427-1
                    plasma-framework5.85.0.r15979.gb869a784a-15.86.0.r15989.gef9e3f25f-1
                  plasma-integration5.22.5.r532.g04ac5f9-15.22.5.r534.gb8df483-1
                    plasma-mobile-nm5.22.3.r3090.g06eacc57-15.22.5.r3101.g5f46da62-1
                         plasma-nano5.21.5.r158.g85d2916-15.21.5.r160.ga0f98ca-1
                           plasma-nm5.22.5.r3090.g06eacc57-15.22.5.r3101.g5f46da62-1
                           plasma-pa5.22.5.r964.ga54c0e6-15.22.5.r977.ga99ad04-1
             plasma-phone-components5.22.5.r1462.g30344fd6-15.22.5.r1475.gfa9b0c97-1
                    plasma-phonebook  21.08.r6.g7ab0b99-1 21.08.r11.gcc8a2fa-1
                          plasma-sdk5.22.5.r2278.g28233174-15.22.5.r2280.g2e8f59ef-1
                     plasma-settings  21.08.r3.g3c44ea6-1 21.08.r19.g1b5e8d5-1
                plasma-systemmonitor5.22.5.r483.g4da01f9-15.22.5.r486.g2c298d8-1
                  plasma-thunderbolt5.22.5.r140.g4c9d324-15.22.5.r149.gee3a87b-1
                        plasma-vault5.22.5.r342.g83b045a-15.22.5.r345.g89b8e20-1
              plasma-wayland-session5.22.5.r10631.g368143329-15.22.5.r10671.gb6a5217c5-1
                    plasma-workspace5.22.5.r10631.g368143329-15.22.5.r10671.gb6a5217c5-1
         plasma-workspace-wallpapers5.22.5.r283.g2c3ee31-15.22.5.r294.gc329bc2-1
                    polkit-kde-agent5.22.5.r502.g9fabd61-15.22.5.r505.g4258711-1
                          powerdevil5.22.5.r2469.g7b7e37df-15.22.5.r2480.g52f44e41-1
                       print-manager21.08.1.r1040.g710cbb9-121.08.1.r1046.g37c9d66-1
                              prison5.85.0.r333.g9105c2d-15.86.0.r333.g9105c2d-1
                             purpose5.85.0.r880.g32bb1ad-15.86.0.r890.gcbbbd37-1
                         qcachegrind21.08.1.r1152.gbe3f69d-121.08.1.r1156.g9579e5d-1
                   qqc2-breeze-style5.22.5.r223.gef75e0b-15.22.5.r226.g79a2163-1
                  qqc2-desktop-style5.85.0.r523.g316fed5-15.86.0.r525.gd726db4-1
                                sddm0.19.0.r62.gd2b4ad0-10.19.0.r63.g83e1ae5-1
                            sddm-kcm5.22.5.r598.g9022354-15.22.5.r609.g7066534-1
                               solid5.85.0.r707.g483eba0-15.86.0.r708.g66059b9-1
                              sonnet5.85.0.r634.gff5ae47-15.86.0.r634.gff5ae47-1
                            spacebar  21.08.r2.g5bd9368-1  21.08.r5.g7f4a52a-1
                           spectacle21.08.1.r1167.gf89f2bc-121.08.1.r1175.g8db2717-1
                             svgpart21.08.1.r182.gb602ba5-121.08.1.r183.gc7f46a9-1
                         syndication5.85.0.r841.gec613d1-15.86.0.r841.gec613d1-1
                 syntax-highlighting5.85.0.r1696.gd277eb41-15.86.0.r1697.gedf0f349-1
                      systemsettings5.22.5.r2490.gd0362a47-15.22.5.r2511.g30a9c4c0-1
          telepathy-kde-accounts-kcm21.08.1.r1195.gd0ffbec-121.08.1.r1196.g27af480-1
                        threadweaver5.85.0.r512.gd9c6fbc-15.86.0.r512.gd9c6fbc-1
                             tokodon  21.08.r2.g6b35a2f-1  21.08.r4.g70103f5-1
                            umbrello21.08.1.r8264.g7a8d1cfb0-121.08.1.r8265.g50ef037a5-1
                         vakzination        r93.ae8475e-1        r97.66a1534-1
                               vvave 2.0.0.r17.gada7ee6-1 2.0.0.r22.g61b6756-1
                            wrapland5.22.4.r1595.g52ae265-15.22.4.r1599.ge051dd4-1
              xdg-desktop-portal-kde5.22.5.r383.gdbb4364-15.22.5.r386.g8e21923-1
                             yakuake21.08.1.r733.g246229c-121.08.1.r734.g916fb92-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
GT King Pro Manjaro-Arm-XFCE updated successfully. First Boot up right after the updated encountered a Kernel Panic during booting process. First time since switching to mainline linux kernel a few months ago.
Power Off and On cycle boot up with NO more panic issue. Tried twice and so far NO kernel panic. Uptime so far around 3 hours.
Will update Manjaro-Arm-Gnome edition shortly.
Is Chromium WebGPU supported on Arm Mali G52 GPU? Tried to activate using the following command:
chromium --enable-gpu-rasterization --enable-zero-copy --use-vulkan --webview-enable-vulkan --enable-features=Vulkan --use-gl=desktop --enable-features=VaapiVideoDecoder --enable-unsafe-webgpu
Graphics Feature Status
  • Canvas: Hardware accelerated
  • Compositing: Hardware accelerated
  • Multiple Raster Threads: Enabled
  • Out-of-process Rasterization: Hardware accelerated
  • OpenGL: Enabled
  • Rasterization: Hardware accelerated on all pages
  • Skia Renderer: Enabled
  • Video Decode: Hardware accelerated
  • Vulkan: Enabled
  • WebGL: Hardware accelerated
  • WebGL2: Hardware accelerated
But don’t think WebGPU is activated as Redirecting - WebGPU Samples NO outputs.
GT King Pro Manjaro-Arm-Gnome updated to Arm-Stable-2021-09-28 successfully and boot up with NO kernel panic. dmesg do have some sort of configuration warnings and errors.
[    6.799704] systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    6.851711] systemd[1]: Configuration file /usr/lib/systemd/system/sound.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    6.920238] systemd[1]: Configuration file /usr/lib/systemd/system/bluetooth-khadas.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.415366] systemd-journald[392]: File /var/log/journal/f9848e400f4b49c2b7cbd679286a85ed/system.journal corrupted or uncleanly shut down, renaming and replacing.
Repeated Errors more 20 lines (Had noticed this in Gnome Edition Only): (But Not listed repeatedly in Manjaro-Arm-XFCE)
[   20.524269]  fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[   20.524282]  fe.dai-link-1: ASoC: dpcm_fe_dai_prepare() failed (-22)
[   20.524516]  fe.dai-link-1: ASoC: no backend DAIs enabled for fe.dai-link-1
[   20.524518]  fe.dai-link-1: ASoC: dpcm_fe_dai_prepare() failed (-22)
Thanks works smoothly even on setting governor=‘schedutil’ & min_freq=“1.00GHz”.
I noticed running Chromium with these flags:
chromium --enable-features=UseOzonePlatform --ozone-platform=wayland --enable-gpu-rasterization --enable-zero-copy --ignore-gpu-blocklist --incognito --in-process-gpu
Can somethimes trigger auto logout. Three times over the pass two months. The last just a 10 minutes ago.
Also with the previous update I got a couple of hard freezes after updating and the first reboot.
Usually the hard freezes subside after a while.
Pinebook Pro ANSI.
I use Manjaro-ARM XFCE on a Raspberry Pi 400. I ran into 2 problems. The first happened as soon as the update was complete and just before I restarted my Pi. manjaro
I was able to restart my Pi and get back to the desktop without and problem.
The other happened with Vivaldi.vivaldi
That is what came up as soon as I opened Vivaldi. I clicked on the More Information button and did what Vivaldi suggested (close and restart the browser) and no change. The same thing came up again. I did a quick test running video on Twitch and the video wouldn’t play. Also did a test with YouTube and the same thing happened (I use the extension enhanced-h264ify. I did try unchecking blocking for the other video codeces and it worked but wasn’t smooth.) I then went to do a manual downgrade to the previous version as per Downgrading packages - Manjaro in the Manjaro wiki. This did NOT work at all. (Yes I DID use the file name of the last 4.1 package.) I was lucky and my back up SD card for XFCE had not yet been updated. I went to that card and set the /etc/pacman.conf file to ignore Vivaldi so it wouldn’t update to version 4.2 and have the issue. I then copied my backup SD card to my daily card so I would have a working version of Vivaldi.
Also I did mention the Vivaldi issue in the Vivaldi Raspberry Pi forum.
Does anyone know what is being done to solve this? Also should I file a bug report over at Vivaldi?
The first issue is known, and will be dealt with in the next update. It’s just a key in our keyring that no longer exists.
The second “issue” could be related to the missing vivaldi-ffmpeg-codecs package. Try seeing if installing vivaldi-codecs-ffmpeg-extra-bin from the AUR solves it.
I tried you suggestion to install vivaldi-codecs-ffmpeg-extra-bin and here is the results
What do I do now?
Looks like you need to run the update_pkg.sh script to get the newest versions.
How do I do that?
Do like they say on the AUR page. This can’t be done with Pamac though, so you need to do it “the Arch way”.
I’m totally lost. The only thing I see is a pinned comment that says
lucifermstar commented on 2019-04-18 08:41
IF/WHEN the package goes out of date. Just download this repo and run ./update_pkg.sh and then build the package manually with makepkg. That should work until the version is updated on the AUR.
I still don’t know what to do
Hey, good ppl from Manjaro! :slight_smile:
My mouse cursor is jumping around the screen since the update. Both using the TP and an USB mouse. I can move it somewhat smoothly, when I move the cursor really-really slow. Is there anything I can do, to stop this?
Thanks!
In your PKGBUILD try changing:
pkgver=92.0.4515.159
To:
pkgver=93.0.4577.63
My test download using wget using the variables from the PKGBUILD:
[ray@ray-pc Desktop]$ export pkgver=93.0.4577.63
[ray@ray-pc Desktop]$ export _ubuver=0ubuntu0
[ray@ray-pc Desktop]$ export _ubudist=18.04.1
[ray@ray-pc Desktop]$ wget http://security.ubuntu.com/ubuntu/pool/universe/c/chromium-browser/chromium-codecs-ffmpeg-extra_${pkgver}-${_ubuver}.${_ubudist}_amd64.deb
--2021-09-30 09:16:48--  http://security.ubuntu.com/ubuntu/pool/universe/c/chromium-browser/chromium-codecs-ffmpeg-extra_93.0.4577.63-0ubuntu0.18.04.1_amd64.deb
Resolving security.ubuntu.com (security.ubuntu.com)... 91.189.91.38, 91.189.91.39, 2001:67c:1562::15, ...
Connecting to security.ubuntu.com (security.ubuntu.com)|91.189.91.38|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1134804 (1.1M) [application/x-debian-package]
Saving to: ‘chromium-codecs-ffmpeg-extra_93.0.4577.63-0ubuntu0.18.04.1_amd64.deb’
chromium-codecs-ffmpeg-extra_93.0.4577.63 100%[===================================================================================>]   1.08M  1.27MB/s    in 0.9s
2021-09-30 09:16:49 (1.27 MB/s) - ‘chromium-codecs-ffmpeg-extra_93.0.4577.63-0ubuntu0.18.04.1_amd64.deb’ saved [1134804/1134804]
Thank you for the info. I was able to reproduce your test with no problems. I then changed
to
in the PKGBUILD .
After saving I went ahead and completed the build and got these results.Failed to build
What do I do now?
Sorry. I forgot to tell you to change the checksum in the PKGBUILD. Hold on will update in this post…
Change what is in bold in your PKGBUILD.
sha256sums=(‘a0983819ab143f2ea414cdb9a49d508b111aa6d5a4a365c8cb8f7c102239ca22’)
sha256sums_x86_64(‘f88fb1c4e3e367a77eb7efb81ea52c570155f0a3f919d8e86030f894caa38381’)
sha256sums_i686(‘5516291c2d07e4e175615757fc3695d5817477be4e4b6a27225df0e2b6d6df86’)
sha256sums_arm(‘686061772188e30c1f2f8471f5d9e9f1040649bb914967673c4788ce38e46f7a’)
sha256sums_armv6h(‘686061772188e30c1f2f8471f5d9e9f1040649bb914967673c4788ce38e46f7a’)
sha256sums_armv7h(‘686061772188e30c1f2f8471f5d9e9f1040649bb914967673c4788ce38e46f7a’)
sha256sums_aarch64(‘f19f1b7eb110326b8e6238a0d213e8f5e6c923c102394e481fcb1dc51a10c726’)
I changed the checksum as per your instructions.
After completing the build here are the results.
Download this package and install it:
sudo pacman -U vivaldi-codecs-ffmpeg-extra-bin-93.0.4577.63-1-aarch64.pkg.tar.zst
I had my pi3b+ testing the latest upstream linux-rc kernel fired up so tested on it with a mp4 movie and it worked surprising good.
Thank you! It works well. Here is a screenshot from a video in my favorites on my YouTube account.
Also here is a screenshot from my Twitch account.
I will be directing people on the Vivaldi Raspberry Pi forum to here so they can get the fix.
