When switching to testing branch with sudo pacman-mirrors -aS testing && sudo pacman -Syyu
Seems to be taking forever ::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xffff84b5ec70>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
I tried sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer
but none of those existed anyone got any ideas?
Unable to switch testing-branch
Anyone?
sudo pacman-mirrors -aS arm-testing
Iām using a Raspberry Pi 4 B and Iām not able to boot into my machine.
I did the update, rebooted and ssh into my machine again. After a few short minutes, it froze, I wasnāt able to issue anything through ssh, use any of the services running in there, not even ping the machine, itās like it was disconnected but everything was physically the same.
After pulling the power cable and putting it back in again nothing happens, both lights (red and yellow if Iām not mistaken) near the USB type C connector are solid on.
Because I have an issue reading the SD card on my Linux machine I booted into Windows and using an ext4 reader checked the SD card and there was no folder extlinux in /boot, in fact thereās nothing in /boot itself because itās all in a different partition, but thereās no extlinux folder on that partition.
The SD card seems to be fine and both the RPI and SD card are between one to two years old and Iāve never did anything that would cause unnecessary wear.
Any tips on how to proceed the debugging?
I upgraded in the stable branch on 2 different pi4 devices with no issue.
Might be an underling reason why you are having issues. Might be some corruption.
There is nothing there on the root fs when viewing the root file system not booted up. The boot partition gets mounted there during the boot process. Also there is no uboot with our pi kernels so no extlinux folder will ever be present.
No the issue in due to drivers in my Linux machine, I canāt read any SD card from it.
How do I check for corruption of the SD card in Windows? Iām going to get one of those USB to SD card reader adapters soon anyways, I really canāt make the built in laptop reader to work regardless of what I do.
Does the fact that the light stay on give any relevant information? From what Iāve picked up online the red one is for power and the yellow one for the SD card, which always flashed a lot during the boot process, as it should because thereās a lot of IO going on, but now it just stay solid, so it might very well be the SD card.
TTYs do not support UTF-8 anymore.
For example:
printf "\u20AC"
do not print ⬠but ?^J or ?? or ?, according to shell or multiplexer.
Someone to confirm the bug?
TTY2 available with ctrl+alt+2. ctrl+alt+7 to return to graphical interface.
Hi,
On my Pi 4 4GB, I follow OPās āHow to use Kodi RPI on Manjaro ARMā, Kodi wonāt run, and if I run it from cmd, I got this:
/usr/lib/kodi/kodi-xrandr: Failed to get size of gamma for output default
libEGL warning: DRI2: failed to authenticate
ERROR: Unable to create GUI. Exiting
Iām on stable channel, a freshly installed xfce version for pi 4.
Anyone know how to fix it?
Or does xfce / gnome / plasma matter?
Thanks!
Did you follow the guide in post #1 in this thread to install kodi-rpi4 so it will not boot into a desktop but straight into kodi?
Oh, thatās the only part I skipped, thinking i was going to launch kodi from within a DE.
After disabling lightdm and enable kodi, now it works, thanks for the tip!
kodi.service sets up a different environment.
Hi.
On my PinePhone stable release (the one the factory installed) the display is dark (or brightness 0 ?) after the KDE icon has been shown during boot for a while.
Actually, while updating the display went dark and did not come back. After leaving it for quite a while in the hope that it would come back I rebooted and now regulary get the dark screen.
What exactly happens after reboot is:
- Power light turns on and then off
- The KDE symbol shows and rotates
- Symbol rotation stops
- The mouse pointer shows and then dissapepears (I think this is normal)
- after another few seconds the display turns dark
How to report the bug? Who manages?
Hi @Strit,
Still cannot login to KDE Plasma (Wayland) session. Just freeze at login screen. Below is the āwayland-session.logā. Power recycle to reboot and login to Plasma (X11).
[jfl@MNJROGTKPro sddm]$ cat wayland-session.log
No backend specified through command line argument, trying auto resolution
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Filter multi-plane format 961959257
Filter multi-plane format 825316697
Filter multi-plane format 842093913
Filter multi-plane format 909202777
Filter multi-plane format 875713881
Filter multi-plane format 961893977
Filter multi-plane format 825316953
Filter multi-plane format 842094169
Filter multi-plane format 909203033
Filter multi-plane format 875714137
Filter multi-plane format 842094158
Filter multi-plane format 909203022
kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
kwin_xkbcommon: XKB: Failed to compile xkb_symbols
kwin_xkbcommon: XKB: Failed to compile keymap
kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
kwin_core: Failed to update gamma ramp for output KWin::DrmOutput(0xaaab0b55a330, name="Composite-1", geometry=QRect(0,0 720x576), scale=1)
(WW) Option "-listen" for file descriptors is deprecated
Please use "-listenfd" instead.
glamor: No eglstream capable devices found
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Could not resolve keysym XF86BrightnessAuto
> Warning: Could not resolve keysym XF86DisplayOff
> Warning: Could not resolve keysym XF86Info
> Warning: Could not resolve keysym XF86AspectRatio
> Warning: Could not resolve keysym XF86DVD
> Warning: Could not resolve keysym XF86Audio
> Warning: Could not resolve keysym XF86ChannelUp
> Warning: Could not resolve keysym XF86ChannelDown
> Warning: Could not resolve keysym XF86Break
> Warning: Could not resolve keysym XF86VideoPhone
> Warning: Could not resolve keysym XF86ZoomReset
> Warning: Could not resolve keysym XF86Editor
> Warning: Could not resolve keysym XF86GraphicsEditor
> Warning: Could not resolve keysym XF86Presentation
> Warning: Could not resolve keysym XF86Database
> Warning: Could not resolve keysym XF86Voicemail
> Warning: Could not resolve keysym XF86Addressbook
> Warning: Could not resolve keysym XF86DisplayToggle
> Warning: Could not resolve keysym XF86SpellCheck
> Warning: Could not resolve keysym XF86ContextMenu
> Warning: Could not resolve keysym XF86MediaRepeat
> Warning: Could not resolve keysym XF8610ChannelsUp
> Warning: Could not resolve keysym XF8610ChannelsDown
> Warning: Could not resolve keysym XF86Images
> Warning: Could not resolve keysym XF86NotificationCenter
> Warning: Could not resolve keysym XF86PickupPhone
> Warning: Could not resolve keysym XF86HangupPhone
> Warning: Could not resolve keysym XF86Fn
> Warning: Could not resolve keysym XF86Fn_Esc
> Warning: Could not resolve keysym XF86FnRightShift
> Warning: Could not resolve keysym XF86Numeric0
> Warning: Could not resolve keysym XF86Numeric1
> Warning: Could not resolve keysym XF86Numeric2
> Warning: Could not resolve keysym XF86Numeric3
> Warning: Could not resolve keysym XF86Numeric4
> Warning: Could not resolve keysym XF86Numeric5
> Warning: Could not resolve keysym XF86Numeric6
> Warning: Could not resolve keysym XF86Numeric7
> Warning: Could not resolve keysym XF86Numeric8
> Warning: Could not resolve keysym XF86Numeric9
> Warning: Could not resolve keysym XF86NumericStar
> Warning: Could not resolve keysym XF86NumericPound
> Warning: Could not resolve keysym XF86NumericA
> Warning: Could not resolve keysym XF86NumericB
> Warning: Could not resolve keysym XF86NumericC
> Warning: Could not resolve keysym XF86NumericD
> Warning: Could not resolve keysym XF86CameraFocus
> Warning: Could not resolve keysym XF86WPSButton
> Warning: Could not resolve keysym XF86CameraZoomIn
> Warning: Could not resolve keysym XF86CameraZoomOut
> Warning: Could not resolve keysym XF86CameraUp
> Warning: Could not resolve keysym XF86CameraDown
> Warning: Could not resolve keysym XF86CameraLeft
> Warning: Could not resolve keysym XF86CameraRight
> Warning: Could not resolve keysym XF86AttendantOn
> Warning: Could not resolve keysym XF86AttendantOff
> Warning: Could not resolve keysym XF86AttendantToggle
> Warning: Could not resolve keysym XF86LightsToggle
> Warning: Could not resolve keysym XF86ALSToggle
> Warning: Could not resolve keysym XF86Buttonconfig
> Warning: Could not resolve keysym XF86Taskmanager
> Warning: Could not resolve keysym XF86Journal
> Warning: Could not resolve keysym XF86ControlPanel
> Warning: Could not resolve keysym XF86AppSelect
> Warning: Could not resolve keysym XF86Screensaver
> Warning: Could not resolve keysym XF86VoiceCommand
> Warning: Could not resolve keysym XF86Assistant
> Warning: Could not resolve keysym XF86BrightnessMin
> Warning: Could not resolve keysym XF86BrightnessMax
> Warning: Could not resolve keysym XF86KbdInputAssistPrev
> Warning: Could not resolve keysym XF86KbdInputAssistNext
> Warning: Could not resolve keysym XF86KbdInputAssistPrevgroup
> Warning: Could not resolve keysym XF86KbdInputAssistNextgroup
> Warning: Could not resolve keysym XF86KbdInputAssistAccept
> Warning: Could not resolve keysym XF86KbdInputAssistCancel
> Warning: Could not resolve keysym XF86RightUp
> Warning: Could not resolve keysym XF86RightDown
> Warning: Could not resolve keysym XF86LeftUp
> Warning: Could not resolve keysym XF86LeftDown
> Warning: Could not resolve keysym XF86RootMenu
> Warning: Could not resolve keysym XF86MediaTopMenu
> Warning: Could not resolve keysym XF86Numeric11
> Warning: Could not resolve keysym XF86Numeric12
> Warning: Could not resolve keysym XF86AudioDesc
> Warning: Could not resolve keysym XF863DMode
> Warning: Could not resolve keysym XF86NextFavorite
> Warning: Could not resolve keysym XF86StopRecord
> Warning: Could not resolve keysym XF86PauseRecord
> Warning: Could not resolve keysym XF86VOD
> Warning: Could not resolve keysym XF86Unmute
> Warning: Could not resolve keysym XF86FastReverse
> Warning: Could not resolve keysym XF86SlowReverse
> Warning: Could not resolve keysym XF86OnScreenKeyboard
> Warning: Could not resolve keysym XF86PrivacyScreenToggle
> Warning: Could not resolve keysym XF86SelectiveScreenshot
> Warning: Could not resolve keysym XF86Macro1
> Warning: Could not resolve keysym XF86Macro2
> Warning: Could not resolve keysym XF86Macro3
> Warning: Could not resolve keysym XF86Macro4
> Warning: Could not resolve keysym XF86Macro5
> Warning: Could not resolve keysym XF86Macro6
> Warning: Could not resolve keysym XF86Macro7
> Warning: Could not resolve keysym XF86Macro8
> Warning: Could not resolve keysym XF86Macro9
> Warning: Could not resolve keysym XF86Macro10
> Warning: Could not resolve keysym XF86Macro11
> Warning: Could not resolve keysym XF86Macro12
> Warning: Could not resolve keysym XF86Macro13
> Warning: Could not resolve keysym XF86Macro14
> Warning: Could not resolve keysym XF86Macro15
> Warning: Could not resolve keysym XF86Macro16
> Warning: Could not resolve keysym XF86Macro17
> Warning: Could not resolve keysym XF86Macro18
> Warning: Could not resolve keysym XF86Macro19
> Warning: Could not resolve keysym XF86Macro20
> Warning: Could not resolve keysym XF86Macro21
> Warning: Could not resolve keysym XF86Macro22
> Warning: Could not resolve keysym XF86Macro23
> Warning: Could not resolve keysym XF86Macro24
> Warning: Could not resolve keysym XF86Macro25
> Warning: Could not resolve keysym XF86Macro26
> Warning: Could not resolve keysym XF86Macro27
> Warning: Could not resolve keysym XF86Macro28
> Warning: Could not resolve keysym XF86Macro29
> Warning: Could not resolve keysym XF86Macro30
> Warning: Could not resolve keysym XF86MacroRecordStart
> Warning: Could not resolve keysym XF86MacroRecordStop
> Warning: Could not resolve keysym XF86MacroPresetCycle
> Warning: Could not resolve keysym XF86MacroPreset1
> Warning: Could not resolve keysym XF86MacroPreset2
> Warning: Could not resolve keysym XF86MacroPreset3
> Warning: Could not resolve keysym XF86KbdLcdMenu1
> Warning: Could not resolve keysym XF86KbdLcdMenu2
> Warning: Could not resolve keysym XF86KbdLcdMenu3
> Warning: Could not resolve keysym XF86KbdLcdMenu4
> Warning: Could not resolve keysym XF86KbdLcdMenu5
Errors from xkbcomp are not fatal to the X server
> Warning: Unsupported maximum keycode 708, clipping.
> X11 cannot support keycodes above 255.
kdeinit5: preparing to launch '/usr/lib/kf5/klauncher'
kdeinit5: Launched KLauncher, pid = 1171, result = 0
kdeinit5: opened connection to :1
kdeinit5: Got SETENV 'GTK_RC_FILES=/etc/gtk/gtkrc:/home/jfl/.gtkrc:/home/jfl/.config/gtkrc' from launcher.
kdeinit5: Got SETENV 'GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/jfl/.gtkrc-2.0:/home/jfl/.config/gtkrc-2.0' from launcher.
kdeinit5: Got SETENV 'SESSION_MANAGER=local/MNJROGTKPro:@/tmp/.ICE-unix/1181,unix/MNJROGTKPro:/tmp/.ICE-unix/1181' from launcher.
** Message: 20:41:30.839: updates_checker.vala:71: check updates
** Message: 20:41:32.684: updates_checker.vala:101: 0 updates found
kdeinit5: Got EXEC_NEW '/usr/lib/qt/plugins/kf5/kio/desktop.so' from launcher.
kdeinit5: preparing to launch '/usr/lib/qt/plugins/kf5/kio/desktop.so'
kdeinit5: Got EXEC_NEW '/usr/lib/qt/plugins/kf5/kio/file.so' from launcher.
kdeinit5: preparing to launch '/usr/lib/qt/plugins/kf5/kio/file.so'
Error occured fetching news:
Cannot resolve hostname
kdeinit5: PID 1423 terminated.
kdeinit5: PID 1426 terminated.
kdeinit5: PID 1428 terminated.
Plasma Wayland is not mature enough on most devices at this point.
I unfortunately wasnāt able to use my PineBook Pro for a longer period of time. However, upon coming back to it after this updateā¦
Everythingās getting really smooth. Even running Parsec through the web browser (currently chromium only) was at a playable state for at least certain games and general remote desktop use.
Overall, great work. I canāt wait to see how things continue to develop, especially now that I can play around with the PBP again.
Hit a few snags in the past, but overall I really do feel like it gets better with every update, even performance, generally speaking.
Begginner here: my microSD was corrupted, but later ive managed to flash sway to rpi4. I love how sway is improving, but sadly i still cant fix my keyboard layout (pt-br-abnt2). The maintainer kindly send me instructions, but messing in config files seems out of my experience⦠i understand sway is not target to begginners lol. Anyway, i might try it again later today. Later, ive tryed flashing gnome by rpi imager, but my microSD didnāt booted. As user @_Undercover reported above, maybe its a rpi4 problem. I might try it again in the next update with a better microSD.
The sway keyboard layout fix informed by the maintainer (appelgriebsch) was: please have a look here: Home Ā· swaywm/sway Wiki Ā· GitHub. The changes can be either done globally (/etc/sway/inputs/default-keyboard) or for your user session only (~/.config/sway/conf.d/00-user.conf)
We are currently investigating the boot issues with the RPi4 image for the GNOME profile.
Hi all,
Reboot mess things in rpi 3b and brings inestable system, while if I poweroff and switch it on everithing is load properly. For now Iāve found:
- Lost net (wifi,eth) connection after reboot
- sudo command is unusable (keep blank, ctrl+c doesnāt stop it).
It happened creating a sd with «manjaro-arm-installer», but due to that check also downloading last manjaro arm img file and update within.
I canāt post journalctl -x -b due to word limit. So itās here:
dmesg.log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.43-1-MANJARO-ARM (builduser@odroid-n2plus-pm) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Mon Jun 14 14:31:41 UTC 2021
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001e800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003bffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003bffffff]
[ 0.000000] On node 0 totalpages: 245760
[ 0.000000] DMA zone: 3840 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 245760 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 32 pages/cpu s91224 r8192 d31656 u131072
[ 0.000000] pcpu-alloc: s91224 r8192 d31656 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: ARM erratum 843419
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 241920
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=LABEL=ROOT_MNJRO rw rootwait console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] audit: disabled (until reboot)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 670004K/983040K available (11648K kernel code, 2408K rwdata, 3996K rodata, 3712K init, 1403K bss, 50892K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x90/0x190 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 36184 entries in 142 pages
[ 0.000000] ftrace: allocated 142 pages with 4 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000314] Console: colour dummy device 80x25
[ 0.001216] printk: console [tty1] enabled
[ 0.001300] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001365] pid_max: default: 32768 minimum: 301
[ 0.001699] LSM: Security Framework initializing
[ 0.002032] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002098] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.004142] Disabling memory control group subsystem
[ 0.007396] rcu: Hierarchical SRCU implementation.
[ 0.008981] EFI services will not be available.
[ 0.009768] smp: Bringing up secondary CPUs ...
[ 0.011262] Detected VIPT I-cache on CPU1
[ 0.011363] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.013138] Detected VIPT I-cache on CPU2
[ 0.013208] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.014853] Detected VIPT I-cache on CPU3
[ 0.014911] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.015132] smp: Brought up 1 node, 4 CPUs
[ 0.015279] SMP: Total of 4 processors activated.
[ 0.015314] CPU features: detected: 32-bit EL0 Support
[ 0.015349] CPU features: detected: CRC32 instructions
[ 0.015384] CPU features: detected: 32-bit EL1 Support
[ 0.056051] CPU: All CPU(s) started at EL2
[ 0.056211] alternatives: patching kernel code
[ 0.058685] devtmpfs: initialized
[ 0.081794] Enabled cp15_barrier support
[ 0.081884] Enabled setend support
[ 0.082229] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.082295] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.096077] pinctrl core: initialized pinctrl subsystem
[ 0.097404] DMI not present or invalid.
[ 0.098062] NET: Registered protocol family 16
[ 0.109708] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.110237] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.111828] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.112941] thermal_sys: Registered thermal governor 'step_wise'
[ 0.113326] cpuidle: using governor menu
[ 0.113742] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.114039] ASID allocator initialised with 65536 entries
[ 0.114283] Serial: AMBA PL011 UART driver
[ 0.143280] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.148812] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-06-08T13:08:17, variant start
[ 0.152823] raspberrypi-firmware soc:firmware: Firmware hash is 03df0e450c356822f03454c27edea347fd8d211b
[ 0.205254] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.210003] vgaarb: loaded
[ 0.210766] SCSI subsystem initialized
[ 0.211159] usbcore: registered new interface driver usbfs
[ 0.211267] usbcore: registered new interface driver hub
[ 0.211387] usbcore: registered new device driver usb
[ 0.211910] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.214614] clocksource: Switched to clocksource arch_sys_counter
[ 2.000033] VFS: Disk quotas dquot_6.6.0
[ 2.000209] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.000481] FS-Cache: Loaded
[ 2.000860] CacheFiles: Loaded
[ 2.002369] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes, mapped to 0x(____ptrval____)
[ 2.002424] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 2.038659] Console: switching to colour frame buffer device 240x67
[ 2.072100] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 2.087565] NET: Registered protocol family 2
[ 2.088098] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 2.089990] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 2.090444] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 2.090849] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 2.091280] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.091798] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 2.092052] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 2.092710] NET: Registered protocol family 1
[ 2.094136] RPC: Registered named UNIX socket transport module.
[ 2.094332] RPC: Registered udp transport module.
[ 2.094489] RPC: Registered tcp transport module.
[ 2.094698] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.094917] PCI: CLS 0 bytes, default 64
[ 2.095417] Trying to unpack rootfs image as initramfs...
[ 2.670937] Freeing initrd memory: 7052K
[ 2.673114] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 2.673641] kvm [1]: IPA Size Limit: 40 bits
[ 2.675778] kvm [1]: Hyp mode initialized successfully
[ 2.682689] Initialise system trusted keyrings
[ 2.683310] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 2.694904] zbud: loaded
[ 2.698078] FS-Cache: Netfs 'nfs' registered for caching
[ 2.699337] NFS: Registering the id_resolver key type
[ 2.699541] Key type id_resolver registered
[ 2.699683] Key type id_legacy registered
[ 2.700003] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.700215] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.704240] Key type asymmetric registered
[ 2.704391] Asymmetric key parser 'x509' registered
[ 2.704610] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 2.705215] io scheduler mq-deadline registered
[ 2.705370] io scheduler kyber registered
[ 2.705725] io scheduler bfq registered
[ 2.720249] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.721147] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.731054] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.740023] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.767958] brd: module loaded
[ 2.798668] loop: module loaded
[ 2.809530] Loading iSCSI transport class v2.0-870.
[ 2.823103] libphy: Fixed MDIO Bus: probed
[ 2.833166] usbcore: registered new interface driver lan78xx
[ 2.841345] usbcore: registered new interface driver smsc95xx
[ 2.849978] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.586549] Core Release: 2.80a
[ 3.594468] Setting default values for core params
[ 3.602425] Finished setting default values for core params
[ 3.810954] Using Buffer DMA mode
[ 3.819013] Periodic Transfer Interrupt Enhancement - disabled
[ 3.827087] Multiprocessor Interrupt Enhancement - disabled
[ 3.835159] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.843271] Dedicated Tx FIFOs mode
[ 3.856277] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = ffff800011b23000 dma = 0x00000000dec00000 len=9024
[ 3.872359] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.912088] dwc_otg: Microframe scheduler enabled
[ 3.912149] WARN::hcd_init_fiq:496: MPHI regs_base at ffff800011735000
[ 3.927751] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.935554] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.943362] dwc_otg 3f980000.usb: irq 74, io mem 0x00000000
[ 3.951047] Init: Port Power? op_state=1
[ 3.958596] Init: Power Port (0)
[ 3.966529] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.974148] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.981741] usb usb1: Product: DWC OTG Controller
[ 3.989235] usb usb1: Manufacturer: Linux 5.10.43-1-MANJARO-ARM dwc_otg_hcd
[ 3.996835] usb usb1: SerialNumber: 3f980000.usb
[ 4.005502] hub 1-0:1.0: USB hub found
[ 4.013246] hub 1-0:1.0: 1 port detected
[ 4.022526] dwc_otg: FIQ enabled
[ 4.022544] dwc_otg: NAK holdoff enabled
[ 4.022558] dwc_otg: FIQ split-transaction FSM enabled
[ 4.022617] Module dwc_common_port init
[ 4.023427] usbcore: registered new interface driver uas
[ 4.031441] usbcore: registered new interface driver usb-storage
[ 4.039365] mousedev: PS/2 mouse device common for all mice
[ 4.049419] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 4.061571] sdhci: Secure Digital Host Controller Interface driver
[ 4.069210] sdhci: Copyright(c) Pierre Ossman
[ 4.077663] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 4.082389] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 4.086553] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.092388] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.096741] hid: raw HID events driver (C) Jiri Kosina
[ 4.100886] usbcore: registered new interface driver usbhid
[ 4.104828] usbhid: USB HID core driver
[ 4.109132] ashmem: initialized
[ 4.117901] Initializing XFRM netlink socket
[ 4.121946] NET: Registered protocol family 17
[ 4.125966] Key type dns_resolver registered
[ 4.130299] registered taskstats version 1
[ 4.134174] Loading compiled-in X.509 certificates
[ 4.138109] Indeed it is in host mode hprt0 = 00021501
[ 4.142637] Key type ._fscrypt registered
[ 4.147600] Key type .fscrypt registered
[ 4.152666] Key type fscrypt-provisioning registered
[ 4.167557] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 4.171537] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
[ 4.177595] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 4.182998] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 4.186950] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 4.216407] random: fast init done
[ 4.221097] sdhost: log_buf @ (____ptrval____) (c431d000)
[ 4.253884] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.260258] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.266535] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.270784] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 4.278350] of_cfs_init
[ 4.282967] of_cfs_init: OK
[ 4.298215] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.304559] Freeing unused kernel memory: 3712K
[ 4.314706] Run /init as init process
[ 4.319200] with arguments:
[ 4.319209] /init
[ 4.319224] with environment:
[ 4.319232] HOME=/
[ 4.319241] TERM=linux
[ 4.319249] selinux=0
[ 4.319259] kgdboc=ttyS0,115200
[ 4.326717] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.332512] Indeed it is in host mode hprt0 = 00001101
[ 4.340065] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.348291] mmc0: new high speed SDHC card at address 0007
[ 4.355917] mmcblk0: mmc0:0007 SD32G 29.9 GiB (quirks 0x80000000)
[ 4.365589] mmcblk0: p1 p2
[ 4.436494] mmc1: new high speed SDIO card at address 0001
[ 4.547111] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 4.551442] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.557786] hub 1-1:1.0: USB hub found
[ 4.562433] hub 1-1:1.0: 5 ports detected
[ 4.858676] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.963328] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.970780] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.983270] smsc95xx v2.0.0
[ 5.043753] libphy: smsc95xx-mdiobus: probed
[ 5.051407] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:29:69:f7
[ 5.138675] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 5.265017] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c521, bcdDevice=57.00
[ 5.271236] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.278905] usb 1-1.2: Product: USB Receiver
[ 5.286840] usb 1-1.2: Manufacturer: Logitech
[ 5.317577] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C521.0001/input/input0
[ 5.326495] hid-generic 0003:046D:C521.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.2/input0
[ 5.354114] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C521.0002/input/input1
[ 5.396032] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.423767] hid-generic 0003:046D:C521.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.2/input1
[ 5.452385] random: crng init done
[ 5.510703] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 5.729681] usb 1-1.3: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10
[ 5.739011] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.748196] usb 1-1.3: Product: USB Keyboard
[ 5.757348] usb 1-1.3: Manufacturer:
[ 5.817309] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1603.0003/input/input4
[ 5.887572] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Keyboard [ USB Keyboard] on usb-3f980000.usb-1.3/input0
[ 5.968674] input: USB Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1603.0004/input/input5
[ 6.039048] input: USB Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1603.0004/input/input6
[ 6.049630] hid-generic 0003:04D9:1603.0004: input,hidraw3: USB HID v1.10 Device [ USB Keyboard] on usb-3f980000.usb-1.3/input1
[ 6.138707] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
[ 6.257245] usb 1-1.5: New USB device found, idVendor=0951, idProduct=1643, bcdDevice= 1.00
[ 6.267617] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.277962] usb 1-1.5: Product: DataTraveler G3
[ 6.288301] usb 1-1.5: Manufacturer: Kingston
[ 6.298634] usb 1-1.5: SerialNumber: 00142238268CBA81B51D00A3
[ 6.308825] usb-storage 1-1.5:1.0: USB Mass Storage device detected
[ 6.317916] scsi host0: usb-storage 1-1.5:1.0
[ 6.393290] systemd[1]: System time before build time, advancing clock.
[ 6.610091] NET: Registered protocol family 10
[ 6.623028] Segment Routing with IPv6
[ 6.714886] systemd[1]: systemd 248.3-2-arch running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 6.738818] systemd[1]: Detected architecture arm64.
[ 6.789589] systemd[1]: Hostname set to <cala>.
[ 7.358526] scsi 0:0:0:0: Direct-Access Kingston DataTraveler G3 PMAP PQ: 0 ANSI: 0 CCS
[ 8.247694] systemd[1]: /usr/lib/systemd/system/stop-dmesg.service:2: Unknown key name 'USER' in section 'Unit', ignoring.
[ 8.282683] systemd[1]: Configuration file /usr/lib/systemd/system/attach-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.302493] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.340257] systemd[1]: Created slice system-getty.slice.
[ 8.362231] systemd[1]: Created slice system-modprobe.slice.
[ 8.382426] systemd[1]: Created slice User and Session Slice.
[ 8.399128] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.413277] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.421015] sd 0:0:0:0: [sda] 15646720 512-byte logical blocks: (8.01 GB/7.46 GiB)
[ 8.423412] sd 0:0:0:0: [sda] Write Protect is off
[ 8.423426] sd 0:0:0:0: [sda] Mode Sense: 03 41 00 00
[ 8.425730] sd 0:0:0:0: [sda] No Caching mode page found
[ 8.425740] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.453428] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.466936] systemd[1]: Reached target Local Encrypted Volumes.
[ 8.477364] sda: sda1
[ 8.486612] systemd[1]: Reached target Login Prompts.
[ 8.493001] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 8.506989] systemd[1]: Reached target Paths.
[ 8.519859] systemd[1]: Reached target Remote Encrypted Volumes.
[ 8.532185] systemd[1]: Reached target Remote File Systems.
[ 8.544161] systemd[1]: Reached target Slices.
[ 8.555916] systemd[1]: Reached target Swap.
[ 8.567643] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 8.579919] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.594448] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.613369] systemd[1]: Listening on Process Core Dump Socket.
[ 8.637049] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 8.643630] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.655805] systemd[1]: Listening on Journal Socket.
[ 8.668211] systemd[1]: Listening on Network Service Netlink Socket.
[ 8.684968] systemd[1]: Listening on udev Control Socket.
[ 8.697072] systemd[1]: Listening on udev Kernel Socket.
[ 8.709034] systemd[1]: Listening on User Database Manager Socket.
[ 8.720434] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 8.770314] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.786248] systemd[1]: Mounting Kernel Debug File System...
[ 8.802199] systemd[1]: Mounting Kernel Trace File System...
[ 8.819311] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 8.835320] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.851179] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.867041] systemd[1]: Starting Load Kernel Module configfs...
[ 8.883744] systemd[1]: Starting Load Kernel Module drm...
[ 8.899650] systemd[1]: Starting Load Kernel Module fuse...
[ 8.919831] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.947114] fuse: init (API version 7.32)
[ 8.983484] systemd[1]: Starting Load Kernel Modules...
[ 9.001402] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.014005] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 9.026231] systemd[1]: Starting Coldplug All udev Devices...
[ 9.047844] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.060534] systemd[1]: Mounted Kernel Debug File System.
[ 9.073136] systemd[1]: Mounted Kernel Trace File System.
[ 9.085416] systemd[1]: Mounted Temporary Directory (/tmp).
[ 9.098708] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.118433] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 9.151437] systemd[1]: Finished Load Kernel Module configfs.
[ 9.164272] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 9.171399] systemd[1]: Finished Load Kernel Module drm.
[ 9.184402] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 9.191175] systemd[1]: Finished Load Kernel Module fuse.
[ 9.204534] systemd[1]: Finished Load Kernel Modules.
[ 9.217511] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 9.252129] systemd[1]: Mounting FUSE Control File System...
[ 9.269734] systemd[1]: Mounting Kernel Configuration File System...
[ 9.281606] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 9.303203] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.308905] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.318759] systemd[1]: Starting Load/Save Random Seed...
[ 9.335626] systemd[1]: Starting Apply Kernel Variables...
[ 9.353474] systemd[1]: Starting Create System Users...
[ 9.370568] systemd[1]: Mounted FUSE Control File System.
[ 9.382879] systemd[1]: Mounted Kernel Configuration File System.
[ 9.483960] systemd[1]: Finished Coldplug All udev Devices.
[ 10.086456] systemd[1]: Finished Load/Save Random Seed.
[ 10.100123] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 10.124287] systemd[1]: Finished Apply Kernel Variables.
[ 11.585411] systemd[1]: Finished Create System Users.
[ 11.636738] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.787087] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 11.836868] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 11.862306] systemd[1]: Starting Journal Service...
[ 11.883824] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 12.033061] systemd[1]: Started Journal Service.
[ 12.117297] systemd-journald[187]: Received client request to flush runtime journal.
[ 12.911334] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.918450] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 12.925254] [vc_sm_connected_init]: start
[ 12.935503] [vc_sm_connected_init]: installed successfully
[ 12.978818] mc: Linux media interface: v0.10
[ 13.070649] videodev: Linux video capture interface: v2.00
[ 13.171291] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.181172] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 13.189252] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 13.223267] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.223270] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.223275] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.279957] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.285475] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.291114] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.300564] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 13.307037] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 13.320418] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 13.320538] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 13.331248] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 13.337043] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 13.343966] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 13.349604] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 13.354659] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 13.359750] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 13.360711] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 13.364830] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 13.369736] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 13.374500] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 13.384595] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 13.572031] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.611517] vc4-drm soc:gpu: bound 3f600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 13.617366] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 13.625765] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[ 13.625779] fb0: switching to vc4drmfb from simple
[ 13.631595] Console: switching to colour dummy device 80x25
[ 13.632891] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 13.683781] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 13.753329] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 13.753350] cfg80211: failed to load regulatory.db
[ 13.782953] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 13.789571] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 13.789869] usbcore: registered new interface driver brcmfmac
[ 13.854686] Console: switching to colour frame buffer device 240x67
[ 13.898933] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 14.074773] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 14.088469] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Feb 16 2020 22:39:24 version 7.45.98.97 (r724416 CY) FWID 01-bf41ed64
[ 17.983949] smsc95xx 1-1.1:1.0 eth0: entering SUSPEND2 mode
[ 22.870347] uart-pl011 3f201000.serial: no DMA platform data
[ 22.929406] zram: Added device: zram0
[ 22.945472] zram0: detected capacity change from 0 to 1448312832
[ 23.122785] Adding 1414364k swap on /dev/zram0. Priority:100 extents:1 across:1414364k SSFS
[ 30.720310] Bluetooth: Core ver 2.22
[ 30.720472] NET: Registered protocol family 31
[ 30.720481] Bluetooth: HCI device and connection manager initialized
[ 30.720510] Bluetooth: HCI socket layer initialized
[ 30.720525] Bluetooth: L2CAP socket layer initialized
[ 30.720559] Bluetooth: SCO socket layer initialized
[ 36.382392] Bluetooth: HCI UART driver ver 2.3
[ 36.382430] Bluetooth: HCI UART protocol H4 registered
[ 36.382740] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 36.383322] Bluetooth: HCI UART protocol Broadcom registered
[ 37.298402] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 37.298437] Bluetooth: BNEP filters: protocol multicast
[ 37.298477] Bluetooth: BNEP socket layer initialized
[ 37.331118] NET: Registered protocol family 38
[ 73.389083] Bluetooth: RFCOMM TTY layer initialized
[ 73.389138] Bluetooth: RFCOMM socket layer initialized
[ 73.389201] Bluetooth: RFCOMM ver 1.11
[ 242.654748] INFO: task kworker/2:1:33 blocked for more than 120 seconds.
[ 242.654776] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 242.654791] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 242.654808] task:kworker/2:1 state:D stack: 0 pid: 33 ppid: 2 flags:0x00000028
[ 242.655086] Workqueue: events_power_efficient reg_check_chans_work [cfg80211]
[ 242.655132] Call trace:
[ 242.655159] __switch_to+0x114/0x170
[ 242.655183] __schedule+0x320/0x900
[ 242.655203] schedule+0x50/0x10c
[ 242.655223] schedule_preempt_disabled+0x24/0x3c
[ 242.655241] __mutex_lock.constprop.0+0x184/0x510
[ 242.655259] __mutex_lock_slowpath+0x1c/0x30
[ 242.655278] mutex_lock+0x54/0x60
[ 242.655300] rtnl_lock+0x24/0x30
[ 242.655524] reg_check_chans_work+0x34/0x410 [cfg80211]
[ 242.655548] process_one_work+0x1dc/0x4bc
[ 242.655582] worker_thread+0x148/0x47c
[ 242.655602] kthread+0x14c/0x160
[ 242.655626] ret_from_fork+0x10/0x38
[ 242.655689] INFO: task kworker/u8:1:88 blocked for more than 120 seconds.
[ 242.655708] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 242.655722] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 242.655738] task:kworker/u8:1 state:D stack: 0 pid: 88 ppid: 2 flags:0x00000028
[ 242.655781] Workqueue: netns cleanup_net
[ 242.655808] Call trace:
[ 242.655828] __switch_to+0x114/0x170
[ 242.655849] __schedule+0x320/0x900
[ 242.655868] schedule+0x50/0x10c
[ 242.655888] schedule_preempt_disabled+0x24/0x3c
[ 242.655908] __mutex_lock.constprop.0+0x184/0x510
[ 242.655925] __mutex_lock_slowpath+0x1c/0x30
[ 242.655944] mutex_lock+0x54/0x60
[ 242.655963] rtnl_lock+0x24/0x30
[ 242.656145] cfg80211_pernet_exit+0x28/0xa4 [cfg80211]
[ 242.656180] ops_exit_list+0x4c/0x80
[ 242.656200] cleanup_net+0x22c/0x380
[ 242.656219] process_one_work+0x1dc/0x4bc
[ 242.656236] worker_thread+0x148/0x47c
[ 242.656257] kthread+0x14c/0x160
[ 242.656278] ret_from_fork+0x10/0x38
[ 242.656332] INFO: task kworker/2:2:184 blocked for more than 120 seconds.
[ 242.656348] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 242.656362] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 242.656377] task:kworker/2:2 state:D stack: 0 pid: 184 ppid: 2 flags:0x00000028
[ 242.656567] Workqueue: events_power_efficient crda_timeout_work [cfg80211]
[ 242.656608] Call trace:
[ 242.656628] __switch_to+0x114/0x170
[ 242.656649] __schedule+0x320/0x900
[ 242.656668] schedule+0x50/0x10c
[ 242.656688] schedule_preempt_disabled+0x24/0x3c
[ 242.656708] __mutex_lock.constprop.0+0x184/0x510
[ 242.656725] __mutex_lock_slowpath+0x1c/0x30
[ 242.656744] mutex_lock+0x54/0x60
[ 242.656763] rtnl_lock+0x24/0x30
[ 242.656924] crda_timeout_work+0x1c/0x50 [cfg80211]
[ 242.656945] process_one_work+0x1dc/0x4bc
[ 242.656962] worker_thread+0x148/0x47c
[ 242.656982] kthread+0x14c/0x160
[ 242.657004] ret_from_fork+0x10/0x38
[ 242.657058] INFO: task NetworkManager:407 blocked for more than 120 seconds.
[ 242.657075] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 242.657089] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 242.657103] task:NetworkManager state:D stack: 0 pid: 407 ppid: 1 flags:0x00000000
[ 242.657137] Call trace:
[ 242.657157] __switch_to+0x114/0x170
[ 242.657177] __schedule+0x320/0x900
[ 242.657197] schedule+0x50/0x10c
[ 242.657219] rpm_resume+0x168/0x704
[ 242.657238] rpm_resume+0x278/0x704
[ 242.657257] __pm_runtime_resume+0x48/0x9c
[ 242.657278] usb_autopm_get_interface+0x2c/0x70
[ 242.657297] usbnet_read_cmd+0x4c/0xb0
[ 242.657319] __smsc95xx_read_reg+0x74/0xdc
[ 242.657338] __smsc95xx_phy_wait_not_busy+0x68/0xd0
[ 242.657356] __smsc95xx_mdio_read+0x5c/0x160
[ 242.657374] smsc95xx_mdiobus_read+0x24/0x30
[ 242.657396] __mdiobus_read+0x50/0x174
[ 242.657415] mdiobus_read+0x48/0x6c
[ 242.657438] smsc_phy_reset+0x30/0x80
[ 242.657457] phy_init_hw+0x40/0xd0
[ 242.657475] smsc95xx_resume+0x6c/0x140
[ 242.657493] usb_resume_interface.part.0.isra.0+0x98/0xe0
[ 242.657512] usb_resume_both+0x7c/0x160
[ 242.657531] usb_runtime_resume+0x24/0x30
[ 242.657561] __rpm_callback+0x98/0x160
[ 242.657582] rpm_callback+0x64/0x90
[ 242.657601] rpm_resume+0x46c/0x704
[ 242.657620] rpm_resume+0x278/0x704
[ 242.657641] __pm_runtime_resume+0x48/0x9c
[ 242.657659] usb_autopm_get_interface+0x2c/0x70
[ 242.657679] usbnet_open+0x34/0x2b4
[ 242.657700] __dev_open+0x134/0x204
[ 242.657720] __dev_change_flags+0x19c/0x220
[ 242.657740] dev_change_flags+0x30/0x70
[ 242.657760] do_setlink+0x214/0xd54
[ 242.657779] __rtnl_newlink+0x504/0x820
[ 242.657798] rtnl_newlink+0x5c/0x90
[ 242.657819] rtnetlink_rcv_msg+0x128/0x344
[ 242.657840] netlink_rcv_skb+0x64/0x124
[ 242.657858] rtnetlink_rcv+0x24/0x30
[ 242.657878] netlink_unicast+0x268/0x32c
[ 242.657896] netlink_sendmsg+0x1c4/0x3d0
[ 242.657916] sock_sendmsg+0x60/0x6c
[ 242.657934] ____sys_sendmsg+0x218/0x234
[ 242.657955] ___sys_sendmsg+0x88/0xd0
[ 242.657975] __sys_sendmsg+0x74/0xcc
[ 242.657993] __arm64_sys_sendmsg+0x30/0x40
[ 242.658017] el0_svc_common.constprop.0+0x84/0x1e0
[ 242.658035] do_el0_svc+0x30/0xa0
[ 242.658065] el0_svc+0x20/0x30
[ 242.658086] el0_sync_handler+0x1a4/0x1b0
[ 242.658104] el0_sync+0x180/0x1c0
[ 363.486711] INFO: task kworker/2:1:33 blocked for more than 241 seconds.
[ 363.486740] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.486755] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.486773] task:kworker/2:1 state:D stack: 0 pid: 33 ppid: 2 flags:0x00000028
[ 363.487099] Workqueue: events_power_efficient reg_check_chans_work [cfg80211]
[ 363.487132] Call trace:
[ 363.487160] __switch_to+0x114/0x170
[ 363.487187] __schedule+0x320/0x900
[ 363.487207] schedule+0x50/0x10c
[ 363.487227] schedule_preempt_disabled+0x24/0x3c
[ 363.487246] __mutex_lock.constprop.0+0x184/0x510
[ 363.487264] __mutex_lock_slowpath+0x1c/0x30
[ 363.487281] mutex_lock+0x54/0x60
[ 363.487316] rtnl_lock+0x24/0x30
[ 363.487532] reg_check_chans_work+0x34/0x410 [cfg80211]
[ 363.487557] process_one_work+0x1dc/0x4bc
[ 363.487575] worker_thread+0x148/0x47c
[ 363.487594] kthread+0x14c/0x160
[ 363.487617] ret_from_fork+0x10/0x38
[ 363.487674] INFO: task kworker/u8:1:88 blocked for more than 241 seconds.
[ 363.487693] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.487707] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.487724] task:kworker/u8:1 state:D stack: 0 pid: 88 ppid: 2 flags:0x00000028
[ 363.487766] Workqueue: netns cleanup_net
[ 363.487804] Call trace:
[ 363.487826] __switch_to+0x114/0x170
[ 363.487847] __schedule+0x320/0x900
[ 363.487866] schedule+0x50/0x10c
[ 363.487886] schedule_preempt_disabled+0x24/0x3c
[ 363.487904] __mutex_lock.constprop.0+0x184/0x510
[ 363.487921] __mutex_lock_slowpath+0x1c/0x30
[ 363.487942] mutex_lock+0x54/0x60
[ 363.487961] rtnl_lock+0x24/0x30
[ 363.488126] cfg80211_pernet_exit+0x28/0xa4 [cfg80211]
[ 363.488147] ops_exit_list+0x4c/0x80
[ 363.488166] cleanup_net+0x22c/0x380
[ 363.488195] process_one_work+0x1dc/0x4bc
[ 363.488213] worker_thread+0x148/0x47c
[ 363.488231] kthread+0x14c/0x160
[ 363.488250] ret_from_fork+0x10/0x38
[ 363.488291] INFO: task kworker/2:2:184 blocked for more than 241 seconds.
[ 363.488307] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.488322] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.488337] task:kworker/2:2 state:D stack: 0 pid: 184 ppid: 2 flags:0x00000028
[ 363.488520] Workqueue: events_power_efficient crda_timeout_work [cfg80211]
[ 363.488547] Call trace:
[ 363.488566] __switch_to+0x114/0x170
[ 363.488586] __schedule+0x320/0x900
[ 363.488606] schedule+0x50/0x10c
[ 363.488625] schedule_preempt_disabled+0x24/0x3c
[ 363.488645] __mutex_lock.constprop.0+0x184/0x510
[ 363.488664] __mutex_lock_slowpath+0x1c/0x30
[ 363.488693] mutex_lock+0x54/0x60
[ 363.488712] rtnl_lock+0x24/0x30
[ 363.488873] crda_timeout_work+0x1c/0x50 [cfg80211]
[ 363.488892] process_one_work+0x1dc/0x4bc
[ 363.488910] worker_thread+0x148/0x47c
[ 363.488930] kthread+0x14c/0x160
[ 363.488949] ret_from_fork+0x10/0x38
[ 363.488992] INFO: task NetworkManager:407 blocked for more than 241 seconds.
[ 363.489010] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.489024] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.489039] task:NetworkManager state:D stack: 0 pid: 407 ppid: 1 flags:0x00000000
[ 363.489070] Call trace:
[ 363.489089] __switch_to+0x114/0x170
[ 363.489109] __schedule+0x320/0x900
[ 363.489129] schedule+0x50/0x10c
[ 363.489153] rpm_resume+0x168/0x704
[ 363.489172] rpm_resume+0x278/0x704
[ 363.489201] __pm_runtime_resume+0x48/0x9c
[ 363.489222] usb_autopm_get_interface+0x2c/0x70
[ 363.489242] usbnet_read_cmd+0x4c/0xb0
[ 363.489260] __smsc95xx_read_reg+0x74/0xdc
[ 363.489278] __smsc95xx_phy_wait_not_busy+0x68/0xd0
[ 363.489297] __smsc95xx_mdio_read+0x5c/0x160
[ 363.489315] smsc95xx_mdiobus_read+0x24/0x30
[ 363.489337] __mdiobus_read+0x50/0x174
[ 363.489356] mdiobus_read+0x48/0x6c
[ 363.489378] smsc_phy_reset+0x30/0x80
[ 363.489398] phy_init_hw+0x40/0xd0
[ 363.489416] smsc95xx_resume+0x6c/0x140
[ 363.489434] usb_resume_interface.part.0.isra.0+0x98/0xe0
[ 363.489453] usb_resume_both+0x7c/0x160
[ 363.489472] usb_runtime_resume+0x24/0x30
[ 363.489493] __rpm_callback+0x98/0x160
[ 363.489512] rpm_callback+0x64/0x90
[ 363.489531] rpm_resume+0x46c/0x704
[ 363.489553] rpm_resume+0x278/0x704
[ 363.489571] __pm_runtime_resume+0x48/0x9c
[ 363.489590] usb_autopm_get_interface+0x2c/0x70
[ 363.489609] usbnet_open+0x34/0x2b4
[ 363.489634] __dev_open+0x134/0x204
[ 363.489653] __dev_change_flags+0x19c/0x220
[ 363.489686] dev_change_flags+0x30/0x70
[ 363.489707] do_setlink+0x214/0xd54
[ 363.489725] __rtnl_newlink+0x504/0x820
[ 363.489745] rtnl_newlink+0x5c/0x90
[ 363.489764] rtnetlink_rcv_msg+0x128/0x344
[ 363.489784] netlink_rcv_skb+0x64/0x124
[ 363.489804] rtnetlink_rcv+0x24/0x30
[ 363.489822] netlink_unicast+0x268/0x32c
[ 363.489839] netlink_sendmsg+0x1c4/0x3d0
[ 363.489858] sock_sendmsg+0x60/0x6c
[ 363.489878] ____sys_sendmsg+0x218/0x234
[ 363.489898] ___sys_sendmsg+0x88/0xd0
[ 363.489916] __sys_sendmsg+0x74/0xcc
[ 363.489934] __arm64_sys_sendmsg+0x30/0x40
[ 363.489958] el0_svc_common.constprop.0+0x84/0x1e0
[ 363.489976] do_el0_svc+0x30/0xa0
[ 363.489997] el0_svc+0x20/0x30
[ 363.490016] el0_sync_handler+0x1a4/0x1b0
[ 363.490033] el0_sync+0x180/0x1c0
[ 363.490067] INFO: task kworker/2:3:464 blocked for more than 120 seconds.
[ 363.490083] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.490101] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.490116] task:kworker/2:3 state:D stack: 0 pid: 464 ppid: 2 flags:0x00000028
[ 363.490283] Workqueue: ipv6_addrconf addrconf_verify_work [ipv6]
[ 363.490327] Call trace:
[ 363.490346] __switch_to+0x114/0x170
[ 363.490367] __schedule+0x320/0x900
[ 363.490387] schedule+0x50/0x10c
[ 363.490407] schedule_preempt_disabled+0x24/0x3c
[ 363.490427] __mutex_lock.constprop.0+0x184/0x510
[ 363.490444] __mutex_lock_slowpath+0x1c/0x30
[ 363.490463] mutex_lock+0x54/0x60
[ 363.490481] rtnl_lock+0x24/0x30
[ 363.490591] addrconf_verify_work+0x1c/0x30 [ipv6]
[ 363.490734] process_one_work+0x1dc/0x4bc
[ 363.490756] worker_thread+0x148/0x47c
[ 363.490776] kthread+0x14c/0x160
[ 363.490797] ret_from_fork+0x10/0x38
[ 363.490877] INFO: task (t-daemon):579 blocked for more than 120 seconds.
[ 363.490898] Tainted: G C 5.10.43-1-MANJARO-ARM #1
[ 363.490916] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 363.490931] task:(t-daemon) state:D stack: 0 pid: 579 ppid: 1 flags:0x00000009
[ 363.490964] Call trace:
[ 363.490984] __switch_to+0x114/0x170
[ 363.491005] __schedule+0x320/0x900
[ 363.491024] schedule+0x50/0x10c
[ 363.491044] schedule_preempt_disabled+0x24/0x3c
[ 363.491064] __mutex_lock.constprop.0+0x184/0x510
[ 363.491081] __mutex_lock_slowpath+0x1c/0x30
[ 363.491100] mutex_lock+0x54/0x60
[ 363.491118] rtnl_lock+0x24/0x30
[ 363.491237] fib6_rules_net_exit+0x24/0x40 [ipv6]
[ 363.491261] ops_exit_list+0x4c/0x80
[ 363.491286] setup_net+0x158/0x210
[ 363.491321] copy_net_ns+0xe4/0x4dc
[ 363.491345] create_new_namespaces+0x11c/0x320
[ 363.491366] unshare_nsproxy_namespaces+0x70/0xbc
[ 363.491390] ksys_unshare+0x1b0/0x304
[ 363.491409] __arm64_sys_unshare+0x20/0x30
[ 363.491430] el0_svc_common.constprop.0+0x84/0x1e0
[ 363.491449] do_el0_svc+0x30/0xa0
[ 363.491468] el0_svc+0x20/0x30
[ 363.491488] el0_sync_handler+0x1a4/0x1b0
[ 363.491505] el0_sync+0x180/0x1c0
One thing it looks like you need to install crda if it is not installed and set for your countryās Regulatory Domain.
What image did you download and install?
