It fixed it for others after my post above. Maybe you left a step out?
Do it in this order:
sudo pacman -Syy
sudo systemctl disable brcm43438.service
sudo pacman -S -dd brcm-patchram-plus
sudo systemctl enable attach-bluetooth.service
sudo pacman -Syu
Vigils
24
Nailed it! Thanks, your generosity is a blessing for us (especially me).
I applied this update on my pinebook using pamac and system crashed while update the system, making boot kernel panic.
I have needed to reinstall from fresh sd card ;(
I don’t have serial-usb cable to see inside. I buyed one with pinebook pro docking base. XD
I reply to myself…
System crashed because system don’t close correctly and /boot was marked like dirty.
Booting from sd and making a simple fsck over it solves the problem…
N00b for fun and profit! ;(
