@strit @appelgriebsch @spikerguy Thank you all for taking the time to read my post. I really appreciate all the hard work the developers have put into Manjaro. I will wait patiently as I am confident the issue will get resolved.
Thanks
Thanks
USB C video out on the Pinebook Pro stopped working after the 5.8 kernel update.
The VIA USB billboard device shows up but Displayport never connects.
Read the posts above you. It’s a known issue.
Edit: i see others are having the same issue. I use external display every day. Please fix it
Hi,
I’m using a pinebook pro with KDE Plasma. I had linux-aarch64 5.7 before the update. After the update i have linux 5.8 now.
The external display is not working anymore. DP-Alt mode.
I had no issues with the external display bevor kernel linux 5.8.
Is this a known issue ? I haven’t seen any infos about it.
Thanks.
Chris
We have notified the patch maintainer. Hopefully we will get a fix for it soon.
Hello ARM users,
Still happy with manjaro ARM on my Dealdig-Boxd6 (clone of a Beelink GT1 Ultimate) with Khadas Vim2 dtb.
System: Host: Dealdig-Boxd6 Kernel: 5.7.8-1-MANJARO-ARM aarch64 bits: 64 compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.19.4
Distro: Manjaro ARM
Machine: Type: ARM Device System: Khadas VIM2 details: N/A
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235 charge: 100% (should be ignored)
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K230 charge: 55% (should be ignored)
status: Discharging
CPU: Topology: 8-Core (2-Die) model: ARMv8 v8l variant: cortex-a53 bits: 64 type: MCP MCM arch: v8l rev: 4
features: Use -f option to see features bogomips: 0
Speed: 250 MHz min/max: 100/1512:1000 MHz Core speeds (MHz): 1: 1000 2: 1000 3: 1000 4: 1000 5: 250 6: 250 7: 250
8: 250
Graphics: Device-1: meson-gxm-dw-hdmi driver: meson_dw_hdmi v: N/A bus ID: N/A
Device-2: meson-gxm-mali driver: panfrost v: kernel bus ID: N/A
Display: x11 server: X.Org 1.20.8 driver: modesetting tty: N/A
OpenGL: renderer: Mali T820 (Panfrost) v: 2.1 Mesa 20.3.0-devel (git-dd003abd2f) direct render: Yes
Audio: Device-1: meson-gxm-dw-hdmi driver: meson_dw_hdmi bus ID: N/A
Device-2: gx-sound-card driver: gx_sound_card bus ID: N/A
Sound Server: ALSA v: k5.7.8-1-MANJARO-ARM
Network: Device-1: meson-gxbb-dwmac driver: meson8b_dwmac v: N/A port: N/A bus ID: N/A
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: pwm-clock driver: pwm_clock v: N/A port: N/A bus ID: N/A
IF-ID-1: ip6tnl0 state: down mac: <filter>
IF-ID-2: wlan0 state: down mac: <filter>
Drives: Local Storage: total: 28.91 GiB used: 12.04 GiB (41.7%)
ID-1: /dev/mmcblk1 model: SLD32G size: 28.91 GiB
Partition: ID-1: / size: 27.45 GiB used: 11.98 GiB (43.6%) fs: ext4 dev: /dev/mmcblk1p2
ID-2: /boot size: 243.7 MiB used: 64.2 MiB (26.3%) fs: vfat dev: /dev/mmcblk1p1
Sensors: System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 250 Uptime: 11m Memory: 2.68 GiB used: 1.08 GiB (40.2%) Init: systemd Compilers: gcc: 9.3.0 Shell: bash
v: 5.0.17 inxi: 3.0.37
What works: ethernet, wlan, bluetooth, emmc.
Panfrost support is getting better and better.
Thanks to the Manjaro ARM devs and Alyssa Rosenzweig!
Hello. I’m trying to avoid any problems with my pending, fat update. I’m not sure if this affects me, but considering that I can’t find the “/boot/extlinux/extlinux.conf file”, then am I good to go? Thank you.
What device is it and what version did you install from?
It is an HP laptop, multiple partition scheme, dual-boot Manjaro-Windows, uefi, and I really don’t remember what my installation version was, I have some evidence from an archived post that it could be 20.04.x, but I can’t be 100% sure (is there some way to find out?)
This thread is for ARM devices. You should post in [Stable Update] 2020-08-16 - Kernels, Plasma, KDE Framework, Systemd, Pamac, VirtualBox, Firefox.
I’m so sorry. I’m a newbie.
Hello, D-bus doesn’t start anymore. Mousepad doesn’t start anymore and LibreOffice lose the menu bar.
In 20.06 and in the update 20.08, systemd-networkd-wait-online fails to start, and network manager doesn’t start automatically. I can start network manager manually.
I think I will reinstall when the kernel patch for USB-C to HDMI will be released, it will be easier.
@regivanx I had the same network manager problem after a post-update restart. I manually started it, refreshed mirrors, and the problem did not return.
After I read that your libreoffice bar was missing, I started office and confirm mine is missing too. I will try to remove and reinstall office to see if it fixes it.
FWIW, I’m not too savvy at error logs and such as I’m still learning.
You have 2 network services trying to fight doing the same thing. This should not be enabled when using Network Manager.
sudo systemctl disable systemd-networkd
sudo systemctl disable systemd-networkd.socket
reboot
Other bug: Chromium is no longer able to play two videos at the same time … the sound device is busy. Cannot play sound from videos at all with vlc or mpv. Perhaps D-Bus?
I’m confused… (shock horror)…
Did the PBP not get a kernel/OS bump also (or perhaps my system is broken after one too many updates)?
pfeerick@pinebookpro
OS: Manjaro-ARM 20.07
Kernel: aarch64 Linux 5.7.0-3-MANJARO-ARM
##### Uptime: 13m
####### Packages: Unknown
##O#O## Shell: bash 5.0.17
####### Resolution: 1920x1080
########### DE: KDE 5.71.0 / Plasma 5.19.3
############# WM: KWin
############### GTK Theme: Breeze [GTK2], Breath-Dark [GTK3]
################ Icon Theme: breath2-dark
################# Disk: 14G / 117G (13%)
##################### CPU: Unknown @ 6x 1.416GHz
##################### GPU:
################# RAM: 897MiB / 3794MiB
As I’m up to date
[pfeerick@pinebookpro ~]$ sudo pacman -Syyu
[sudo] password for pfeerick:
core 218.4 KiB 950 KiB/s 00:00 [############################################] 100%
extra 2.3 MiB 2.02 MiB/s 00:01 [############################################] 100%
community 5.2 MiB 2.88 MiB/s 00:02 [############################################] 100%
there is nothing to do
And see that there is an image for 20.08 for the pbp…
I suppose this is my excuse to try out the NVMe-ready SPI uboot, and write the new image to the NVMe drive… what can go wrong?
You might be connected to an out of date mirror.
Try sudo pacman-mirrors -f5 && sudo pacman -Syyu
. That should get you a new mirror and updates to kernel 5.8.
That’s what I thought also. I tried updating last night, and got a decent number of updates, but it was probably the July updates as I haven’t had the PBP on for a few weeks. I think there is something going on the with the AU mirrors atm as my desktop needed a new mirrorlist for this months updates also.
[pfeerick@pinebookpro ~]$ pacman-mirrors --status
Local mirror status for arm-stable branch
Mirror #1 -- 693:20 Australia http://manjaro.mirror.serversaustralia.com.au/
[pfeerick@pinebookpro ~]$ sudo pacman-mirrors -f5 && sudo pacman -Syyu
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.472 Australia : http://manjaro.mirror.serversaustralia.com.au/
::INFO Writing mirror list
::Australia : http://manjaro.mirror.serversaustralia.com.au/arm-stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 218.4 KiB 910 KiB/s 00:00 [############################################] 100%
extra 2.3 MiB 1343 KiB/s 00:02 [############################################] 100%
community 5.2 MiB 1750 KiB/s 00:03 [############################################] 100%
Okay, try sudo pacman-mirrors -c all && sudo pacman -Syyu
to “reset” your mirrorlist to using all mirrors.
As you can see on the repo status page your mirrors has been out of date for at least 600 hours. I suggest picking a mirror in another region.
In progress of scanning mirrors now. Thanks Dammit… BOTH the AU servers are now MIA.
Edit: That fixed it. Coffee sent!
