Hi,
Using ARM EFI Manjaro on a Pinebook Pro, I’ve noticed that the use of the keyboard is rather inconsistent in grub.
At some boots it works, at some boots it simply does not work, and at some boots it works for a few seconds before stopping working.
Whether it’s a cold boot or a reboot seems to make no difference.
Strit
26 October 2022 10:12
2
I’ve noticed the same thing in Tow-Boot firmware menu.
So I believe it’s an issue with tow-boot.
I haven’t noticed this. Although I had noticed that both with tow-boot and the original u-boot, keys might be slow to be taken into account and had to be kept pressed longer than usual.
i’ve noticed this at well, and i thought it was just random, but after closer inspection, the workaround here seems to work for me.
opened 07:56PM - 20 Oct 21 UTC
type: bug
workaround
The issue had been reported on the Matrix room, but never filed here.
Acciden… tally, or mindfully, touching the touchpad will break keyboard input on the Pinebook Pro.
The workaround is to not touch the touchpad.
### TODO
- [x] ~~Verify if a keyboard+mouse exhibits the same issue on another board~~ (could not reproduce)
- [x] ~~Verify with mouse on **the same USB device** (e.g. test with my "air mouse" remote thingy)~~ (could not reproduce)
- [x] ~~Verify touchpad on Pinebook A64 (could not reproduce)~~
Perhaps yall can vote on this issue if its the same one for you.
