The ark (archiving tool) will not start and i cannot extract zips using the tool.
I have searched online if anybody had the same problem but couldnt find any examples.
If i try to start ark via the terminal with:
$ ark
I get the following error:
ark: symbol lookup error: /usr/lib/libkerfuffle.so.20: undefined symbol: _ZN15KPluginMetaData16staticMetaObjectE
I have tried to search what the libkerfuffle is and tried to reinstall it but i couldnt find any info over. Apart that it is used by the ark package.
Does somebody might know where this error comes from. And how i can solve it?
Thanks in advance.
No, I did it a some time ago. But after the full update my manjaro wouldnt boot anymore. So I had to use timeshift to rollback. I could try it again to see if they fixed it in the meantime.
A partial upgrade might result in a program trying to use a shared library which it was not compiled with, and that could result in errors like the one you see.
