Hello, I switched from Windows to Linux few months ago, and I have been strictly using Ubuntu or his derivates. That way I learned working in Ubuntu terminal, which I am not affraid of (doing things there instead in gui) since I am technical guy and I understand the power of the shell. I just have to ask, aside from package manager difference apt → pacman, are there any other differences between commands in Ubuntu’s terminal and Manjaro’s terminal?
For now I am satisfied with Manjaro and it’s flawless implementation of KDE Plasma (which I had to configue a lot when installing it on Ubuntu, where I had some strange screen flickers/lagging).
No one wrote that pamac is supposed to be Manjaro’s “official” package manager, (which includes handling of AUR packages) not pacman
pamac’s syntax is closer to what you are used to, though many are using pacman due to their previous habit in Arch, or because sometimes you need something more powerful/granular.
as long as you need to do something from terminal of course there will be differences with other commands as well, mkinitcpio for building your initramfs for example, other tools like pactree, building packages from the AUR with makepkg, updating your mirrors with pacman-mirrors, unique ones who handle your GPU/kernel drivers like mhwd and mhwd-kernel etc, etc.
No. If a package/program comes as a cli binary, it’ll be the same on Ubuntu and on Manjaro. Manjaro’s version is potentially newer and some things might change (added/deprecated/removed features), but that depends on the command and the developers of said programs.
