Looking back through my reboots in journalctl, it looks like I’ve been getting this notification rather consistently near/at the top of my logs…
$ journalctl -k --priority err
-- Journal begins at Tue 2021-07-13 15:47:15 CDT, ends at Fri 2021-12-10 15:42:16 CST. --
Dec 10 15:01:33 AM4-5600X-Linux kernel: ucsi_ccg 0-0008: failed to get FW build information
Doing a quick DDG, I see some references that made me think this might have something to do with USB… but I’m not sure.
If it is USB related, I know I’ve always had a question about what this odd/blank entry is in my USB list…
$ lsusb -s 1:4
Bus 001 Device 004: ID 0000:0000
verbose lsusb details of the device here
$ lsusb -s 1:4 -vvv
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x0000
idProduct 0x0000
bcdDevice 32.98
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0029
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 1 Single TT
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
If I was to guess what this odd USB entry is, I’d say it was the USB-C port on my AMD 6800XT… because it is absent from the global lsusb list…
$ lsusb
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 002: ID 1b1c:1b11 Corsair K95 RGB Mechanical Gaming Keyboard
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 003 Device 006: ID 04a9:27e5 Canon, Inc. MF731C/733C
Bus 003 Device 005: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 003 Device 004: ID 1462:7c35 Micro Star International MYSTIC LIGHT
Bus 003 Device 003: ID 1b1c:0a3d Corsair CORSAIR VIRTUOSO SE USB Gaming Headset
Bus 003 Device 002: ID 045e:028e Microsoft Corp. Xbox360 Controller
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 1b1c:1b3b Corsair Corsair Gaming MM800 RGB POLARIS
Bus 001 Device 003: ID 1b1c:1b79 Corsair CORSAIR SABRE RGB PRO Gaming Mouse
Bus 001 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
Yet does make it’s presence known in the lspci list (the below list was manually targeted to GPU) as a USB Controller…
$ lspci -vvv
2f:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] (rev c1) (prog-if 00 [VGA controller])
Subsystem: XFX Limited XFX Speedster MERC 319 AMD Radeon RX 6800 XT Black
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 212
IOMMU group: 29
Region 0: Memory at 7800000000 (64-bit, prefetchable) [size=16G]
Region 2: Memory at 7c00000000 (64-bit, prefetchable) [size=256M]
Region 4: I/O ports at e000 [size=256]
Region 5: Memory at fca00000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at fcb00000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: amdgpu
Kernel modules: amdgpu
2f:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin B routed to IRQ 209
IOMMU group: 30
Region 0: Memory at fcb24000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
2f:00.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] Device 73a6 (prog-if 30 [XHCI])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 73a6
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin C routed to IRQ 190
IOMMU group: 31
Region 0: Memory at fc900000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
2f:00.3 Serial bus controller [0c80]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 USB
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0408
Interrupt: pin D routed to IRQ 68
IOMMU group: 32
Region 0: Memory at fcb20000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: i2c-designware-pci
Any assistance understanding what this message means and what my actions should be would be greatly appreciated. My guessing and DDG research isn’t getting me very far… and I have a suspicion that the GPU’s USB Controller might be one of the many listed Linux Foundation X.0 root hub entries… meaning I’m chasing red herrings.
… but, more importantly…
