I’m currently on Manjaro KDE.
Sometime after Ardour 6.9-4 was replaced by 6.9-5 in the repository, the program consistently crashes on exit. At the time of 6.9-4 I was on XFCE, but when the crashes started and I felt I had tried everything, I gave up and installed KDE Plasma from scratch instead, but the problem persists…
On KDE I followed (parts of) this guide: GitHub - ElizabethHarmon/ManjaroProAudio: A complete guide to setting up Manjaro for professional audio. - no pipewire and skipping steps 4, 7, 8 & 9.
Then I installed Qjackctl from pamac and Ardour 6.9 from ardour.org .
Since it still crashes on exit (window freezes and nothing is responding to mouse clicks or keyboard commands, but I can Alt-Tab to other programs) I uninstalled and got 6.9-5 through pamac.
I tried with a fresh user profile (deleting .config/ardour6 before starting) as well as a backup of my old profile. Now I’m stuck and reaching out for help.
What should be my next steps?
(Edited to clarify I’m not using pipewire, but jack / pulseaudio)
Start it from terminal and then close it. Post output. Edit: Does it dump core? coredumpctl -r
I installed it in VM just now, without doing anything from that guide and it opens and closes. But to be honest, I have no clue how to test it further.
I tried an export, then I had a different kind of crash (full stop and exit) and core was dumped:
TIME PID UID GID SIG COREFILE EXE SIZE
Wed 2022-06-08 23:15:53 CEST 13724 1000 1000 SIGABRT present /opt/Ardour-6.9.0/bin/ardour-6.9.0 207.4M
Running from terminal, just opening a session and clicking ‘quit’ (the crash happens with any session I’ve tried so far):
Set cursor set to default
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:877:(find_matching_chmap) Found no matching channel map
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
fluidsynth: warning: No preset found on channel 9 [bank=128 prog=0]
Reading player:Drums solo 2 took 337 microseconds, final size = 204
Reading player:Drums solo 1 took 291 microseconds, final size = 306
Reading player:Drums last vocals took 64 microseconds, final size = 174
Reading player:Drums v 3 + power took 222 microseconds, final size = 120
Reading player:Crash took 281 microseconds, final size = 24
Reading player:Trommer v4 took 553 microseconds, final size = 1112
Reading player:Trommer exp took 724 microseconds, final size = 1032
Reading player:Trommer v1 took 1468 microseconds, final size = 2812
Butler drops pool trash
Terminated
Open Ardour, start a new empty session, quit:
ardour6
Ardour6.9.0 (built using 6.9 and GCC version 11.2.0)
Ardour: [INFO]: Your system is configured to limit Ardour to 524288 open files
Ardour: [INFO]: Loading system configuration file /etc/ardour6/system_config
Ardour: [INFO]: Loading user configuration file /home/user/.config/ardour6/config
Ardour: [INFO]: CPU vendor: GenuineIntel
Ardour: [INFO]: AVX-capable processor
Ardour: [INFO]: AVX with FMA capable processor
Ardour: [INFO]: CPU brand: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
Ardour: [INFO]: Using AVX and FMA optimized routines
Ardour: [INFO]: Loading plugin meta data file /usr/share/ardour6/plugin_metadata/plugin_tags
Ardour: [INFO]: Loading plugin statistics file /home/user/.config/ardour6/plugin_metadata/plugin_stats
Ardour: [INFO]: Loading default ui configuration file /etc/ardour6/default_ui_config
Ardour: [INFO]: Loading user ui configuration file /home/user/.config/ardour6/ui_config
Ardour: [INFO]: Loading 452 MIDI patches from /usr/share/ardour6/patchfiles
Ardour: [INFO]: Loading color file /usr/share/ardour6/themes/dark-ardour.colors
Ardour: [INFO]: Loading ui configuration file /etc/ardour6/clearlooks.rc
Ardour: [INFO]: Loading bindings from /home/user/.config/ardour6/ardour.keys
Scanning folders for bundled LV2s: /usr/lib/ardour6/LV2
Terminated
Yeah that’s what I get.
Do you use pulseaudio or pipewire? Asking because the guide starts with installing pipewire, but later you said:
which is in step 10 and should be skipped.
Forgot to mention that I’m still going with jack and pulseaudio, so no pipewire (yet)
Was only going to suggest to switch if that makes any difference at all. Other than that, I honestly don’t have the slightest idea.
Try reporting issue upstream, if they have a bugtracker or whatever.
Or you can try to analyze that coredump if you can decipher anything from it.
Edit: fixed by downgrading glibc:
sudo DOWNGRADE_FROM_ALA=1 downgrade glibc
Thanks to the Ardour forum:
After further investigation, JACK was found to be innocent. The problem is a bug in glibc (unreleased 3.35.x git). libjack is affected by that, Ardour itself is not: https://sourceware.org/bugzilla/show_bug.cgi?id=29214
system
Closed
11 June 2022 20:55
9
