I am reinstalling Manjaro on a 2012 MacBook Air 11". I hadn’t used it in some time since the battery was bad, but I’ve just replaced the battery and wanted a fresh start. I’m using the KDE Plasma Manjaro installer downloaded today. After a few failed attempts, I noticed that my hardware clock was quite off, so I reset it with timedatectl set-time and hwclock --systohc, which seem to have fixed the time, although I have also noticed that the time jumps 5 hours (the difference between my time and UTC), sometimes during my install attempts. I’m not sure if this is actually related to my problem (see below), but that was my best guess.
Here’s the error message I get each time. I am grateful for any help!
Installation Failed
Boost.Python error in job "networkcfg".
<class 'NameError'> name 'target_network' is not defined
Traceback:
File "/usr/lib/calamares/modules/networkcfg/main.py", line 126, in run replace_username(target_network, live_user, user)
File "/usr/lib/calamares/modules/networkcfg/main.py", line 76, in replace_username
with open(target_network, "r") as network_conf:
an other shot at it: also try update the live system ? … be sure to terminate hangig calamares processes
before trying again, if not working also worth trying an older live medium
There’s an issue with installer itself. I replicated mentioned pull request changes in my local copy at “/usr/lib/calamares/modules/networkcfg/main.py” before running the installer and managed to install it. Now checking if everything works properly.
