Archer T3U Plus - TP-Link 802.11ac - rtl88x2bu: Fail on association (took too long to associate)
I have checked all related topics in this forum and tried their solutions and they haven’t worked, I’ve also googled and found all relevant threads on it and those haven’t worked either (most reference the same solution)
jordan@Jordan-PC  ~  inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=0c116a5b-5a45-411c-95e0-60232ccc5ca8 rw quiet amd_iommu=on
  cryptdevice=UUID=dbc7eb80-5d69-4570-8044-12160c8205d0:luks-dbc7eb80-5d69-4570-8044-12160c8205d0
  root=/dev/mapper/luks-dbc7eb80-5d69-4570-8044-12160c8205d0 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-9fd524b3-0bba-440f-9287-821ee91bae27
  udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Desktop System: Micro-Star product: MS-7A34 v: 2.0 serial: <filter>
  Mobo: Micro-Star model: B350 PC MATE (MS-7A34) v: 2.0 serial: <filter>
  UEFI: American Megatrends v: A.LQ date: 11/29/2019
  RAM: total: 15.64 GiB used: 3.02 GiB (19.3%)
  Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
  L2: 4 MiB bogomips: 115250
  Speed: 1981 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 1981 2: 1937 3: 1867 4: 2701 5: 4278 6: 2161 7: 2128 8: 2149 9: 1867
  10: 2578 11: 3377 12: 2124 13: 2151 14: 1993 15: 1925 16: 1869
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
  vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
  xsaveopt xsaves
  conditional, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 25:00.0 chip-ID: 1002:67df
  class-ID: 0300
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK
  driver: vfio-pci v: 0.2 alternate: nouveau bus-ID: 26:00.0
  chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 952x285mm (37.5x11.2")
  s-diag: 994mm (39.1")
  Monitor-1: DisplayPort-0 res: 1680x1050 hz: 60 dpi: 90
  size: 474x296mm (18.7x11.7") diag: 559mm (22")
  Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 61
  size: 800x450mm (31.5x17.7") diag: 918mm (36.1")
  OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0
  5.10.52-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.1.5 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 25:00.1
  chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
  driver: vfio-pci v: 0.2 alternate: snd_hda_intel bus-ID: 26:00.1
  chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-4: Micronas Blue Snowball type: USB driver: snd-usb-audio
  bus-ID: 3-4:4 chip-ID: 074d:0005 class-ID: 0102
  Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: no
  vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 23:00.0
  IF: enp35s0 state: down mac: <filter>
  Device-2: TP-Link 802.11ac NIC type: USB driver: rtl88x2bu bus-ID: 1-3:18
  chip-ID: 2357:0138 class-ID: 0000 serial: <filter>
  IF: wlp3s0f0u3 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: luks-dbc7eb80-5d69-4570-8044-12160c8205d0 maj-min: 254:0
  type: LUKS dm: dm-0 size: 214.47 GiB
  Components:
  p-1: sdb2 maj-min: 8:18 size: 214.47 GiB
  Device-2: luks-9fd524b3-0bba-440f-9287-821ee91bae27 maj-min: 254:1
  type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: sdb3 maj-min: 8:19 size: 8.8 GiB
  Local Storage: total: 987.42 GiB used: 638.61 GiB (64.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD3200AAKS-61L9A0
  size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: N/A serial: <filter> rev: 3E01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 0102 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA050
  size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: A7C0 scheme: GPT
  ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%)
  used: 111.19 GiB (52.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-dbc7eb80-5d69-4570-8044-12160c8205d0 label: N/A
  uuid: 0c116a5b-5a45-411c-95e0-60232ccc5ca8
  used: 448 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
  uuid: AE41-1644
  ID-3: /mnt/HDD2 raw-size: 298.09 GiB size: 292.91 GiB (98.26%)
  used: 274.74 GiB (93.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: HDD2
  uuid: 231a862e-a33e-405f-a23d-0958194a2010
  ID-4: /mnt/HDD3 raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
  used: 252.68 GiB (55.2%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
  uuid: c918703f-2823-4ef4-81d8-52736e2ccd80
  dev: /dev/dm-1 maj-min: 254:1
  mapped: luks-9fd524b3-0bba-440f-9287-821ee91bae27 label: N/A
  uuid: 20158f01-88bc-4d05-8302-7e23ae30c9d4
  Device-1: 1-3:18 info: TP-Link 802.11ac NIC type: Network driver: rtl88x2bu
  interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 2357:0138
  Device-2: 1-8:3 info: Xenta ZELOTES GAME MOUSE type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 1d57:ad17 class-ID: 0301
  Device-3: 1-9:4 info: Dell KB216 Wired Keyboard type: Keyboard,HID
  power: 100mA chip-ID: 413c:2113 class-ID: 0300
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Primax Dell Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 0461:4d15 class-ID: 0301
  Device-2: 3-2:3 info: Dell Keyboard SK-8115 type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 70mA chip-ID: 413c:2003 class-ID: 0301
  Device-3: 3-4:4 info: Micronas Blue Snowball type: Audio
  driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 59.1 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1126
  Processes: 393 Uptime: 1h 30m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1385
  lib: 422 flatpak: 0 Shell: Zsh v: 5.8 running-in: xfce4-terminal
  inxi: 3.3.06
I have tried the following drivers:
Any help is appreciated! (If you need any more information, let me know)
Full log from when usb was plugged in to disconnected
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: new high-speed USB device number 18 using xhci_hcd
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: New USB device found, idVendor=2357, idProduct=0138, bcdDevice= 2.10
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: Product: 802.11ac NIC
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: Manufacturer: Realtek
Jul 28 20:18:04 Jordan-PC kernel: usb 1-3: SerialNumber: 123456
Jul 28 20:18:04 Jordan-PC kernel: RTW: [HALMAC]11692M
                                  HALMAC_MAJOR_VER = 1
                                  HALMAC_PROTOTYPE_VER = 6
                                  HALMAC_MINOR_VER = 5
                                  HALMAC_PATCH_VER = 6*
Jul 28 20:18:04 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
Jul 28 20:18:16 Jordan-PC kernel: RTW: HW EFUSE
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x000: 29 81 00 3C  09 00 A1 00  B6 04 64 10  00 00 A3 00
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x010: 2A 2A 2B 2B  2B 2B 28 29  29 29 29 14  00 00 FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x020: FF FF 21 22  23 22 1D 1D  1E 1E 1E 1E  1F 1F 1F 1F
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x030: 13 00 FF FF  00 FF 1C 00  FF FF 2A 2A  2B 2B 2B 2B
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x040: 29 29 29 2A  2A 14 00 00  FF FF FF FF  23 24 25 24
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x050: 21 20 20 1F  20 22 24 23  23 23 13 00  FF FF 00 FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x060: 1C 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0B0: FF FF FF FF  FF FF FF FF  A5 2F 1E 00  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0C0: FF 01 00 11  00 00 00 00  00 FF 03 FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x100: 57 23 38 01  E1 67 02 98  48 27 D3 AB  63 09 03 52
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x110: 65 61 6C 74  65 6B 0E 03  38 30 32 2E  31 31 61 63
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x120: 20 4E 49 43  08 03 31 32  33 34 35 36  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x140: 33 0A 1F 01  00 00 21 0F  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x200: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x210: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x220: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x230: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x240: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x250: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x260: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x270: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x280: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x290: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: 0x2F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
Jul 28 20:18:16 Jordan-PC kernel: RTW: hal_com_config_channel_plan chplan:0x25
Jul 28 20:18:16 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
Jul 28 20:18:17 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:18:19 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] ver_id.RF_TYPE:RF_2T2R, rf_reg_path_num:2, max_tx_cnt:2
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] Registry's RF PATH:UNKNOWN
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] HALDATA's trx_path_bmp:0x33, max_tx_cnt:2
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] HALDATA's rf_type:RF_2T2R
Jul 28 20:18:19 Jordan-PC kernel: RTW: [RF_PATH] NumTotalRFPath:2
Jul 28 20:18:19 Jordan-PC kernel: RTW: [TRX_Nss] HALSPEC - tx_nss :2, rx_nss:2
Jul 28 20:18:19 Jordan-PC kernel: RTW: [TRX_Nss] Registry - tx_nss :0, rx_nss:0
Jul 28 20:18:19 Jordan-PC kernel: RTW: [TRX_Nss] HALDATA - tx_nss :2, rx_nss:2
Jul 28 20:18:19 Jordan-PC NetworkManager[650]: <info>  [1627517899.8438] device (wlan0): driver supports Access Point (AP) mode
Jul 28 20:18:19 Jordan-PC NetworkManager[650]: <info>  [1627517899.8442] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/22)
Jul 28 20:18:19 Jordan-PC systemd[1]: Starting Load/Save RF Kill Switch Status...
░░ Subject: A start job for unit systemd-rfkill.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit systemd-rfkill.service has begun execution.
░░ The job identifier is 5929.
Jul 28 20:18:19 Jordan-PC kernel: RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
Jul 28 20:18:19 Jordan-PC kernel: RTW: rtw_ndev_init(wlan0) if1 mac_addr=98:48:27:d3:ab:63
Jul 28 20:18:19 Jordan-PC mtp-probe[23526]: checking bus 1, device 18: "/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3"
Jul 28 20:18:19 Jordan-PC mtp-probe[23526]: bus: 1, device: 18 was not an MTP device
Jul 28 20:18:20 Jordan-PC NetworkManager[650]: <info>  [1627517900.3799] rfkill5: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3/1-3:1.0/ieee80211/phy5/rfkill5) (driver rtl88x2bu)
Jul 28 20:18:20 Jordan-PC systemd[1]: Started Load/Save RF Kill Switch Status.
░░ Subject: A start job for unit systemd-rfkill.service has finished successfully
░░ A start job for unit systemd-rfkill.service has finished successfully.
Jul 28 20:18:20 Jordan-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:18:20 Jordan-PC kernel: audit: type=1130 audit(1627517900.376:454): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:18:20 Jordan-PC kernel: rtl88x2bu 1-3:1.0 wlp3s0f0u3: renamed from wlan0
Jul 28 20:18:20 Jordan-PC NetworkManager[650]: <info>  [1627517900.4085] device (wlan0): interface index 18 renamed iface from 'wlan0' to 'wlp3s0f0u3'
Jul 28 20:18:20 Jordan-PC NetworkManager[650]: <info>  [1627517900.4118] device (wlp3s0f0u3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 28 20:18:20 Jordan-PC mtp-probe[23567]: checking bus 1, device 18: "/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3"
Jul 28 20:18:20 Jordan-PC mtp-probe[23567]: bus: 1, device: 18 was not an MTP device
Jul 28 20:18:20 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:18:22 Jordan-PC ModemManager[878]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3': not supported by any plugin
Jul 28 20:18:25 Jordan-PC systemd[1]: systemd-rfkill.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit systemd-rfkill.service has successfully entered the 'dead' state.
Jul 28 20:18:25 Jordan-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:18:25 Jordan-PC kernel: audit: type=1131 audit(1627517905.383:455): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:18:32 Jordan-PC kernel: RTW: txpath=0x3, rxpath=0x3
Jul 28 20:18:32 Jordan-PC kernel: RTW: txpath_1ss:0x1, num:1
Jul 28 20:18:32 Jordan-PC kernel: RTW: txpath_2ss:0x3, num:2
Jul 28 20:18:33 Jordan-PC kernel: start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
Jul 28 20:18:33 Jordan-PC kernel: RTW: wlp3s0f0u3- hw port(0) mac_addr =98:48:27:d3:ab:63
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.3926] device (wlp3s0f0u3): set-hw-addr: set MAC address to A6:02:2F:C7:1F:13 (scanning)
Jul 28 20:18:34 Jordan-PC wpa_supplicant[1414]: nl80211: kernel reports: Authentication algorithm number required
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4811] device (wlp3s0f0u3): supplicant interface state: internal-starting -> disconnected
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4812] Wi-Fi P2P device controlled by interface wlp3s0f0u3 created
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4814] manager: (p2p-dev-wlp3s0f0u3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/23)
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4815] device (p2p-dev-wlp3s0f0u3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4820] device (wlp3s0f0u3): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jul 28 20:18:34 Jordan-PC NetworkManager[650]: <info>  [1627517914.4825] device (p2p-dev-wlp3s0f0u3): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 28 20:18:36 Jordan-PC ModemManager[878]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3': not supported by any plugin
Jul 28 20:18:47 Jordan-PC kernel: RTW: nolinked power save enter
Jul 28 20:18:47 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:18:59 Jordan-PC kernel: RTW: txpath=0x3, rxpath=0x3
Jul 28 20:18:59 Jordan-PC kernel: RTW: txpath_1ss:0x1, num:1
Jul 28 20:18:59 Jordan-PC kernel: RTW: txpath_2ss:0x3, num:2
Jul 28 20:19:00 Jordan-PC kernel: start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
Jul 28 20:19:00 Jordan-PC kernel: RTW: wlp3s0f0u3- hw port(0) mac_addr =a6:02:2f:c7:1f:13
Jul 28 20:19:01 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: Reject scan trigger since one is already pending
Jul 28 20:19:01 Jordan-PC kernel: RTW: nolinked power save leave
Jul 28 20:19:02 Jordan-PC NetworkManager[650]: <info>  [1627517942.7671] device (wlp3s0f0u3): Activation: starting connection 'Joes' (e2b28a81-e930-41d6-b6e1-e70f12ddf0ed)
Jul 28 20:19:02 Jordan-PC audit[650]: USYS_CONFIG pid=650 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=e2b28a81-e930-41d6-b6e1-e70f12ddf0ed name="Joes" pid=1587 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jul 28 20:19:02 Jordan-PC NetworkManager[650]: <info>  [1627517942.7672] audit: op="connection-activate" uuid="e2b28a81-e930-41d6-b6e1-e70f12ddf0ed" name="Joes" pid=1587 uid=1000 result="success"
Jul 28 20:19:02 Jordan-PC kernel: audit: type=1111 audit(1627517942.763:456): pid=650 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=e2b28a81-e930-41d6-b6e1-e70f12ddf0ed name="Joes" pid=1587 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jul 28 20:19:02 Jordan-PC NetworkManager[650]: <info>  [1627517942.7673] device (wlp3s0f0u3): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:02 Jordan-PC NetworkManager[650]: <info>  [1627517942.7675] manager: NetworkManager state is now CONNECTING
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8531] device (wlp3s0f0u3): set-hw-addr: reset MAC address to 98:48:27:D3:AB:63 (preserve)
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8533] device (wlp3s0f0u3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8535] device (wlp3s0f0u3): Activation: (wifi) access point 'Joes' has security, but secrets are required.
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8536] device (wlp3s0f0u3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8554] device (wlp3s0f0u3): supplicant interface state: disconnected -> interface_disabled
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8554] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: disconnected -> interface_disabled
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8563] device (wlp3s0f0u3): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8566] device (wlp3s0f0u3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8568] device (wlp3s0f0u3): Activation: (wifi) connection 'Joes' has security, and secrets exist.  No new secrets needed.
Jul 28 20:19:03 Jordan-PC flameshot[4400]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/6"
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8569] Config: added 'ssid' value 'Joes'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8569] Config: added 'scan_ssid' value '1'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8569] Config: added 'bgscan' value 'simple:30:-70:86400'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8569] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8569] Config: added 'auth_alg' value 'OPEN'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8570] Config: added 'psk' value '<hidden>'
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8773] device (wlp3s0f0u3): supplicant interface state: interface_disabled -> inactive
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8774] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: interface_disabled -> inactive
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8865] device (wlp3s0f0u3): supplicant interface state: inactive -> scanning
Jul 28 20:19:03 Jordan-PC NetworkManager[650]: <info>  [1627517943.8865] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: inactive -> scanning
Jul 28 20:19:10 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: Trying to associate with 58:2f:f7:6d:32:af (SSID='Joes' freq=5220 MHz)
Jul 28 20:19:10 Jordan-PC wpa_supplicant[1414]: nl80211: kernel reports: Authentication algorithm number required
Jul 28 20:19:10 Jordan-PC NetworkManager[650]: <info>  [1627517950.1890] device (wlp3s0f0u3): supplicant interface state: scanning -> associating
Jul 28 20:19:10 Jordan-PC NetworkManager[650]: <info>  [1627517950.1890] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: scanning -> associating
Jul 28 20:19:10 Jordan-PC kernel: RTW: rtw_set_802_11_connect(wlp3s0f0u3)  fw_state=0x00000008
Jul 28 20:19:16 Jordan-PC kernel: RTW: nolinked power save enter
Jul 28 20:19:20 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: Authentication with 58:2f:f7:6d:32:af timed out.
Jul 28 20:19:20 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:19:29 Jordan-PC NetworkManager[650]: <warn>  [1627517969.1399] device (wlp3s0f0u3): Activation: (wifi) association took too long
Jul 28 20:19:29 Jordan-PC NetworkManager[650]: <info>  [1627517969.1399] device (wlp3s0f0u3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:29 Jordan-PC NetworkManager[650]: <warn>  [1627517969.1403] device (wlp3s0f0u3): Activation: (wifi) asking for new secrets
Jul 28 20:19:29 Jordan-PC dbus-daemon[649]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.32' (uid=1000 pid=1587 comm="nm-applet ")
Jul 28 20:19:29 Jordan-PC audit: BPF prog-id=44 op=LOAD
Jul 28 20:19:29 Jordan-PC audit: BPF prog-id=45 op=LOAD
Jul 28 20:19:29 Jordan-PC audit: BPF prog-id=46 op=LOAD
Jul 28 20:19:29 Jordan-PC systemd[1]: Starting Hostname Service...
░░ Subject: A start job for unit systemd-hostnamed.service has begun execution
░░ A start job for unit systemd-hostnamed.service has begun execution.
░░ The job identifier is 5937.
Jul 28 20:19:29 Jordan-PC kernel: audit: type=1334 audit(1627517969.225:457): prog-id=44 op=LOAD
Jul 28 20:19:29 Jordan-PC kernel: audit: type=1334 audit(1627517969.225:458): prog-id=45 op=LOAD
Jul 28 20:19:29 Jordan-PC kernel: audit: type=1334 audit(1627517969.225:459): prog-id=46 op=LOAD
Jul 28 20:19:32 Jordan-PC kernel: RTW: txpath=0x3, rxpath=0x3
Jul 28 20:19:32 Jordan-PC kernel: RTW: txpath_1ss:0x1, num:1
Jul 28 20:19:32 Jordan-PC kernel: RTW: txpath_2ss:0x3, num:2
Jul 28 20:19:32 Jordan-PC NetworkManager[650]: <warn>  [1627517972.8273] device (wlp3s0f0u3): no secrets: User canceled the secrets request.
Jul 28 20:19:32 Jordan-PC NetworkManager[650]: <info>  [1627517972.8274] device (wlp3s0f0u3): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Jul 28 20:19:32 Jordan-PC NetworkManager[650]: <info>  [1627517972.8276] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 28 20:19:33 Jordan-PC kernel: start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
Jul 28 20:19:33 Jordan-PC kernel: RTW: wlp3s0f0u3- hw port(0) mac_addr =98:48:27:d3:ab:63
Jul 28 20:19:34 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: CTRL-EVENT-DISCONNECTED bssid=58:2f:f7:6d:32:af reason=3 locally_generated=1
Jul 28 20:19:34 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: CTRL-EVENT-ASSOC-REJECT status_code=1
Jul 28 20:19:34 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jul 28 20:19:34 Jordan-PC kernel: RTW: nolinked power save leave
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.1986] device (wlp3s0f0u3): set-hw-addr: set MAC address to 92:BB:78:70:70:3E (scanning)
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <warn>  [1627517974.1989] device (wlp3s0f0u3): Activation: failed for connection 'Joes'
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.1990] device (wlp3s0f0u3): supplicant interface state: associating -> disconnected
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.1991] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: associating -> disconnected
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.2012] device (wlp3s0f0u3): supplicant interface state: disconnected -> interface_disabled
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.2013] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: disconnected -> interface_disabled
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.2015] device (wlp3s0f0u3): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 28 20:19:34 Jordan-PC dbus-daemon[649]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 28 20:19:34 Jordan-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:19:34 Jordan-PC systemd[1]: Started Hostname Service.
░░ Subject: A start job for unit systemd-hostnamed.service has finished successfully
░░ A start job for unit systemd-hostnamed.service has finished successfully.
Jul 28 20:19:34 Jordan-PC kernel: audit: type=1130 audit(1627517974.219:460): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.2820] device (wlp3s0f0u3): supplicant interface state: interface_disabled -> inactive
Jul 28 20:19:34 Jordan-PC NetworkManager[650]: <info>  [1627517974.2821] device (p2p-dev-wlp3s0f0u3): supplicant management interface state: interface_disabled -> inactive
Jul 28 20:19:35 Jordan-PC polkitd[652]: Registered Authentication Agent for unix-process:23739:543678 (system bus name :1.182 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Jul 28 20:19:35 Jordan-PC polkitd[652]: Unregistered Authentication Agent for unix-process:23739:543678 (system bus name :1.182, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Jul 28 20:19:40 Jordan-PC kernel: RTW: nolinked power save enter
Jul 28 20:19:41 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:19:53 Jordan-PC kernel: RTW: txpath=0x3, rxpath=0x3
Jul 28 20:19:53 Jordan-PC kernel: RTW: txpath_1ss:0x1, num:1
Jul 28 20:19:53 Jordan-PC kernel: RTW: txpath_2ss:0x3, num:2
Jul 28 20:19:54 Jordan-PC kernel: start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
Jul 28 20:19:54 Jordan-PC kernel: RTW: wlp3s0f0u3- hw port(0) mac_addr =92:bb:78:70:70:3e
Jul 28 20:19:55 Jordan-PC kernel: RTW: nolinked power save leave
Jul 28 20:19:55 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: Reject scan trigger since one is already pending
Jul 28 20:20:04 Jordan-PC systemd[1]: systemd-hostnamed.service: Deactivated successfully.
░░ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Jul 28 20:20:04 Jordan-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:20:04 Jordan-PC kernel: audit: type=1131 audit(1627518004.268:461): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 28 20:20:04 Jordan-PC audit: BPF prog-id=46 op=UNLOAD
Jul 28 20:20:04 Jordan-PC audit: BPF prog-id=45 op=UNLOAD
Jul 28 20:20:04 Jordan-PC audit: BPF prog-id=44 op=UNLOAD
Jul 28 20:20:04 Jordan-PC kernel: audit: type=1334 audit(1627518004.288:462): prog-id=46 op=UNLOAD
Jul 28 20:20:04 Jordan-PC kernel: audit: type=1334 audit(1627518004.288:463): prog-id=45 op=UNLOAD
Jul 28 20:20:04 Jordan-PC kernel: audit: type=1334 audit(1627518004.288:464): prog-id=44 op=UNLOAD
Jul 28 20:20:07 Jordan-PC kernel: RTW: nolinked power save enter
Jul 28 20:20:08 Jordan-PC kernel: RTW: [HALMAC][ALWAYS]shall R reg twice!!
Jul 28 20:20:09 Jordan-PC kernel: usb 1-3: USB disconnect, device number 18
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_32: I/O FAIL!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_16: I/O FAIL!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_8: I/O FAIL!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]bcn valid!!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]dl rsvd page!!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]send fw pkt!!
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR [HALMAC][ERR]lte ready(W)
Jul 28 20:20:10 Jordan-PC kernel: RTW: ERROR download_fw: download firmware FAIL! status=0x66
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x80 = 0x0000
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10F8 = 0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10FC = 0x00000000 (0/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10FC = 0x00000000 (1/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10FC = 0x00000000 (2/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10FC = 0x00000000 (3/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x10FC = 0x00000000 (4/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x3A = 0x00
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xF6 = 0x00
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xC0 = 0x00000000 (0/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xC0 = 0x00000000 (1/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xC0 = 0x00000000 (2/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xC0 = 0x00000000 (3/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0xC0 = 0x00000000 (4/5)
Jul 28 20:20:10 Jordan-PC kernel: RTW: ======= MAC REG =======
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0000 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0010 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0020 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0030 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0040 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0050 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0060 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0070 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0080 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0090 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x00f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0100 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0110 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0120 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0130 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0140 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0150 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0160 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0170 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0180 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0190 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x01f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0200 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0210 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0220 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0230 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0240 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0250 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0260 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0270 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0280 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0290 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x02f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0300 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0310 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0320 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0330 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0340 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0350 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0360 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0370 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0380 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0390 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x03f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0400 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0410 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0420 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0430 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0440 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0450 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0460 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0470 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0480 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0490 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x04f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0500 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0510 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0520 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0530 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0540 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0550 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0560 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0570 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0580 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0590 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x05f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0600 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0610 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0620 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0630 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0640 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0650 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0660 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0670 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0680 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0690 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x06f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0700 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0710 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0720 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0730 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0740 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0750 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0760 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0770 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0780 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x0790 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x07f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1000 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1010 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1020 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1030 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1040 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1050 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1060 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1070 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1080 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1090 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x10f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1100 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1110 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1120 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1130 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1140 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1150 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1160 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1170 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1180 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1190 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x11f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1200 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1210 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1220 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1230 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1240 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1250 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1260 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1270 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1280 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1290 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x12f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1300 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1310 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1320 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1330 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1340 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1350 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1360 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1370 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1380 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1390 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x13f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1400 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1410 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1420 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1430 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1440 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1450 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1460 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1470 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1480 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1490 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x14f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1500 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1510 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1520 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1530 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1540 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1550 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1560 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1570 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1580 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1590 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x15f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1600 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1610 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1620 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1630 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1640 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1650 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1660 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1670 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1680 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1690 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x16f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1700 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1710 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1720 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1730 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1740 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1750 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1760 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1770 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1780 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x1790 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17a0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17b0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17c0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17d0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17e0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:10 Jordan-PC kernel: RTW: 0x17f0 0x00000000  0x00000000  0x00000000  0x00000000
Jul 28 20:20:21 Jordan-PC wpa_supplicant[1414]: wlp3s0f0u3: Reject scan trigger since one is already pending
Jul 28 20:20:21 Jordan-PC kernel: RTW: _debug_dlfw_fail: 0x80 = 0x0000 (after 10 secs)
Jul 28 20:20:21 Jordan-PC kernel: RTW: ERROR rtl8822b_hal_init Download Firmware from array failed
Jul 28 20:20:21 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_8: I/O FAIL!
Jul 28 20:20:21 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_32: I/O FAIL!
Jul 28 20:20:21 Jordan-PC kernel: RTW: ERROR _halmac_reg_write_16: I/O FAIL!
Jul 28 20:20:21 Jordan-PC kernel: RTW: wlp3s0f0u3- hw port(0) mac_addr =00:00:00:00:00:00
Jul 28 20:20:21 Jordan-PC kernel: RTW: nolinked power save leave
Jul 28 20:20:21 Jordan-PC kernel: RTW: rtw_ndev_uninit(wlp3s0f0u3) if1
Jul 28 20:20:21 Jordan-PC NetworkManager[650]: <info>  [1627518021.0385] device (wlp3s0f0u3): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jul 28 20:20:21 Jordan-PC NetworkManager[650]: <info>  [1627518021.0397] device (p2p-dev-wlp3s0f0u3): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jul 28 20:20:21 Jordan-PC NetworkManager[650]: <info>  [1627518021.0704] radio killswitch /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3/1-3:1.0/ieee80211/phy5/rfkill5 disappeared
:+1: Welcome to Manjaro! :+1:
Have you tried updating your firmware yet?
Have you tried one of the stable kernels yet? (5.13 would be my first choice)
:crossed_fingers:
I’ll update my firmware but do you think I should update to the stable version or beta version? (https://www.msi.com/Motherboard/support/B350-PC-MATE)
Also I will try 5.13 but isn’t 5.10 stable and LTS (not using real-time, using linux510 not linux510-rt)?
Yes, it it, but sometimes a Stable version can get you out of trouble…
:crossed_fingers:
I just found out my firmware was up to date already so I will be updating the kernel now and editing my post hopefully saying this fixed it :slight_smile:
Edit: Seems to be the same exact error/issue after the kernel update (even uninstall and reinstalled the driver)
File a bug with the developer as per their pinned comment:
RinCat commented on 2020-09-20 23:29
If you encountered any problems, set debug log use echo 5 > /proc/net/rtl88x2bu/log_level or modprobe 88x2bu rtw_drv_log_level=5, and post your dmesg and network managers logs to https://pastebin.com/ .
:sob:
Alright, will do, thanks!
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
