Today I got this new wireless adapter:
Archer T3U
AC1300 Mini Wireless MU-MIMO USB Adapter
Of course i faced some issues installing it
Here are the steps i followed in case someone runs through the same problem as I did.
Manjaro kernel 5.8.6-1-MANJARO
KDE plasma
first you need to install the following package from the AUR:
- Search for rtl8822bu in your add-remove software app
- install the one under rtl8822bu-git v: r59.fd24afa-1
- choose the headers that corresponds with your current running kernel, mine was 58 since my kernel was 5.8.6-1
- You can find your kernel version by running the command
uname -r
- After it installs and builds you will need to unplug/ and re-plug the adapter and that should be it!!
Hope this helps,
Cheers!
