My VPS provider only has Arch linux, so I had that installed and started using it.
However, I realized that I would like to follow a safer Manjaro pacman path and not Arch’s. Is there an easy way to make existing Arch installation to become Manjaro?
Easier is to back up your home folder and reinstall, tell to create a user with the same name, then copy the home back.
Or if you have a separate home partition just keep it while reinstalling, then just mount it on /home.
