Strange issue on a system that’s always on but I barely use (runs a few docker containers):
The Arc Menu keeps disappearing.
When I go to Extensions Manager, Arc Menu is disabled and shows an error “panels[i] is undefined” and I cannot enable it. But when I re-login it’s fine again.
My Panel itself is totally fine.
How can I prevent this from happening? I think it started after I updated and rebooted, about 1 or 2 wks ago.
Where did you install ArcMenu from? The latest version is 46, make sure you’re up to date. In the Extensions application, is it listed under Manually Installed, Built-In or both?
