Hello everybody,
i noticed today that all my application windows show up on all my Activites by default. I also can’t assign a window to just one activity, the default back to “All Activities”
I can’t exactly say when this started to happen, but i guess it worked correctly last week. With correctly i mean, Application Windows only show up on the Activity that i started them from, or when i explicitly say, that i want to see them on all Activities.
I searched through the system settings, but neither the “Workplace Behaviour” nor the “Window Managment”-Setting have been helpful. I also searched for “activities” in the settings search, but it wasn’t helpful neither.
I hope someone has a clue what’s going on. The Activity Switch was really useful to me, when working from home and switching between work related and private windows.
Thank you in advance for all the help.
Edit: inxi output for details on system
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=d0dcf297-8999-484d-b070-738c7c120b94 ro quiet apparmor=1
security=apparmor udev.log_priority=3 radeon.si_support=0
amdgpu.si_support=1 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: B450 Gaming K4 serial: <filter>
UEFI: American Megatrends v: P4.20 date: 06/19/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.56 GiB used: 5.12 GiB (32.9%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 104854
Speed: 4367 MHz min/max: 2200/5114 MHz boost: enabled Core speeds (MHz):
1: 4367 2: 4367 3: 4367 4: 4366 5: 4367 6: 4367 7: 4367 8: 4367 9: 4367
10: 4366 11: 4366 12: 4367
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-2: Microdia USB Live camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: DisplayPort-0 res: 3440x1440 hz: 60 dpi: 109
size: 798x335mm (31.4x13.2") diag: 865mm (34.1")
OpenGL: renderer: Radeon RX 590 Series (POLARIS10 DRM 3.42.0
5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microdia USB Live camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: e000 bus-ID: 06:00.0 chip-ID: 10ec:818b class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: ASRock driver: r8169 v: kernel port: c000 bus-ID: 09:00.0
IF: enp9s0 state: down mac: <filter>
Local Storage: total: 5.12 TiB used: 2.76 TiB (53.8%)
model: WDS200T2B0C-00PXH0 size: 1.82 TiB block-size: physical: 512 B
rev: 21705000 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SP610 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 2C scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EZRZ-00Z5HB0
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW TS-H653G rev: DW10
dev-links: cdrom
ID-1: / raw-size: 1.34 TiB size: 1.31 TiB (98.36%) used: 666.36 GiB (49.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: d0dcf297-8999-484d-b070-738c7c120b94
used: 25.8 MiB (26.8%) fs: vfat dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: A6F3-B5A5
ID-3: /mnt/216471125F774515 raw-size: 495.83 GiB size: 495.83 GiB (100.00%)
used: 254.97 GiB (51.4%) fs: ntfs dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 216471125F774515
ID-4: /mnt/2E6C9FBC6C9F7D71 raw-size: 909.33 GiB size: 909.33 GiB (100.00%)
used: 180.96 GiB (19.9%) fs: ntfs dev: /dev/sdc5 maj-min: 8:37
label: Dat neuer Speicher uuid: 2E6C9FBC6C9F7D71
ID-5: /mnt/C4EF0007EEFFF012 raw-size: 110.71 GiB size: 110.71 GiB (100.00%)
used: 100.73 GiB (91.0%) fs: ntfs dev: /dev/sdb4 maj-min: 8:20
label: Dat Gehirn uuid: C4EF0007EEFFF012
ID-6: /mnt/EE7ED4C57ED4882B raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.58 TiB (87.0%) fs: ntfs dev: /dev/sdd2 maj-min: 8:50 label: Oschi
uuid: EE7ED4C57ED4882B
ID-7: /run/media/green/f4718ab4-6763-4b26-aab7-ee7d93c8c71e
raw-size: 476.93 GiB size: 468.38 GiB (98.21%) used: 12 KiB (0.0%) fs: ext4
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f4718ab4-6763-4b26-aab7-ee7d93c8c71e
ID-1: swap-1 type: file size: 8 GiB used: 3 MiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: ntfs
label: Wiederherstellung uuid: 942EF2FC2EF2D5E8
ID-2: /dev/sdb3 maj-min: 8:19 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb5 maj-min: 8:21 size: 577 MiB fs: ntfs label: N/A
uuid: 8820696E206963E2
ID-4: /dev/sdc1 maj-min: 8:33 size: 1 KiB fs: <superuser required>
ID-5: /dev/sdc2 maj-min: 8:34 size: 21.98 GiB fs: ntfs label: SAMSUNG_REC
uuid: C2AEEB2DAEEB18A5
ID-6: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Microdia USB Live camera type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
Device-2: 3-2:3 info: Line6 UX1 type: <vendor specific>
driver: snd_usb_toneport interfaces: 1 rev: 1.0 speed: 12 Mb/s power: 498mA
chip-ID: 0e41:4150 class-ID: ff00
Hub-4: 3-3:4 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2811 class-ID: 0900
Device-1: 3-3.2:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-3.3:6 info: Personal Communication Systems Dual PSX Adaptor
type: HID driver: pantherlord,usbhid interfaces: 1 rev: 1.0 speed: 1.5 Mb/s
power: 500mA chip-ID: 0810:0001 class-ID: 0300
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-3:2 info: VIA Labs Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:8110 class-ID: 0900
System Temperatures: cpu: 58.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1391
Processes: 346 Uptime: 8h 23m wakeups: 123 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
pacman: 1922 lib: 491 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
