Hi,
I decided to install Manjaro with the new experimental desktop environment. For the most part, I love it so far. Easy to use, tiles my windows automatically, and everything is readily accessible. F12 Guake and live wallpapers are pretty sweet too.
The only problem I keep encountering is that the bottom left task bar where the applications and files menu is keeps freezing up on me, making it so I need to reboot. To be more specific, it’s Applications Menu, the Settings menu (doesn’t pop up when I move mouse to left of screen either), and the Power menu all lose functionality. I know it’s unstable software and still in it’s infancy, but has anyone found a quick fix for this problem yet?
Thanks!
TheSonofHans
