Applications requiring root privileges such as Gparted, KDE Partition,Print Settings, do not open from the menu. In order to use them I have to go to the command line. I installed LXQT-sudo but that has not changed anything. Is there something else I need to do to make these apps run?
Thank you
Polkit service must be running. Check it with:
systemctl status polkit.service
polkit service is activated and loaded
