Hi. I’ve just installed the latest GNOME mininal Manjaro release on my laptop.
While trying to enable the ‘Applications menu’ extension I got this error:
“Requiring GMenu, version none: Typelib file for namespace ‘GMenu’ (any version) not found”
I found there’s a comment here Applications Menu - GNOME Shell Extensions saying that "gir1.2-gmenu-3.0’ is needed, but cannot find it. Any ideas?
TIA
limaunion:
TIA
A transient ischemic attack (TIA), commonly known as a mini-stroke, is a minor stroke whose noticeable symptoms usually end in less than an hour. TIA causes the same symptoms associated with strokes, such as weakness or numbness on one side of the body, sudden dimming or loss of vision, difficulty speaking or understanding language, slurred speech, or confusion.
All forms of stroke, including TIA, result from a disruption in blood flow to the central nervous system. A TIA is caused by a tempor...
I wish you a speedy recovery.
https://packages.debian.org/de/sid/amd64/gir1.2-gmenu-3.0/filelist
pamac search -f GMenu-3.0.typelib
pamac list -f gnome-menus
pamac install gnome-menus
This has fixed the issue! only had to re-login
Thanks!
system
Closed
20 December 2023 23:41
4
