My applications do not show up in the KDE system tray anymore (e.g. slack), although system icons like volume control is there. I think this first started in the 2022-03-14 update (another user reported the same issue there but I didn’t find any solutions on the forum). Any help is greatly appreciated.
FWIW, none of the applications show up under System Tray Settings, but the system entries are all there and appear to be working.
Here’s my inxi output:
Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f18a577e-534d-49dd-9862-3b79e75c4e5d rw quiet apparmor=1
security=apparmor resume=UUID=aa93899a-d995-4497-937e-99f9e6e8b971
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C37 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.70
date: 01/09/2020
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 62.82 GiB used: 5.82 GiB (9.3%)
RAM Report:
Info: model: AMD Ryzen 9 3950X bits: 64 type: MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
Topology: cpus: 1x cores: 16 smt: <unsupported> cache: L1: 1024 KiB
desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB L3: 64 MiB
desc: 4x16 MiB
Speed (MHz): avg: 3642 high: 4320
min/max: 2200/6768:6624:6480:6337:6053:6193:5910:5479:5766:5623:5335:5192:5048:4905:4761
boost: enabled scaling: driver: acpi-cpufreq governor: performance cores:
1: 3599 2: 3598 3: 3743 4: 3600 5: 3598 6: 3598 7: 3128 8: 4320 9: 3596
10: 3596 11: 3598 12: 3597 13: 3889 14: 3630 15: 3592 16: 3594
bogomips: 112045
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:1f08 class-ID: 0300
Device-2: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1.1:3 chip-ID: 046d:082c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x400mm (27.64x15.75")
s-diag: 808mm (31.81")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 2d:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8168 v: 8.049.02-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 6.37 TiB used: 2.01 TiB (31.5%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 612.1 GiB size: 601.49 GiB (98.27%)
used: 330.69 GiB (55.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: f18a577e-534d-49dd-9862-3b79e75c4e5d
used: 26.1 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 179E-3744
ID-3: /brick raw-size: 5.46 TiB size: 5.41 TiB (99.19%)
used: 1.68 TiB (31.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 205d8607-1449-4fac-a938-15c5147e2e23
ID-1: swap-1 type: partition size: 69.11 GiB used: 1.8 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: aa93899a-d995-4497-937e-99f9e6e8b971
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 250.01 GiB fs: ntfs label: N/A
uuid: 1630A30805FCE231
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 7-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 7-1.1:3 info: Logitech HD Webcam C615 type: Audio,Video
power: 500mA chip-ID: 046d:082c class-ID: 0e02 serial: <filter>
Device-2: 7-1.3:4 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0346 class-ID: 0300
Hub-10: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-11: 8-2:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: 55.4 C mobo: 35.0 C gpu: nvidia temp: 43 C
Fan Speeds (RPM): fan-1: 1518 fan-2: 859 fan-3: 1056 fan-4: 844 fan-5: 0
fan-6: 0 fan-7: 0 gpu: nvidia fan: 0%
Processes: 366 Uptime: 29m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1928 lib: 452
flatpak: 0 Shell: Zsh v: 5.8.1 running-in: tilix inxi: 3.3.15
