Good morning everyone,
for the past few weeks I’ve been having a really annoying problem that prevents me from using some apps like; Virtualbox, Gear Lever, Opera, Floorp, etc. This and other apps don’t start at all, while nautilus starts after about 10 sec.
I used to reboot and somehow everything would start working properly again, but lately even rebooting a lot of times the problem remains.
I have read many posts of people who had the same problem as me and many solved it by entering one or more strings by editing /etc/environment;
Kernel: 6.14.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
root=UUID=7e1e0ede-41c3-4804-8736-dd5cb2cd9074 rw rootflags=subvol=@
quiet
cryptdevice=UUID=4fa7a601-d6db-4acf-aefb-c54066635d15:luks-4fa7a601-d6db-4acf-aefb-c54066635d15
root=/dev/mapper/luks-4fa7a601-d6db-4acf-aefb-c54066635d15 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-5897c51d-56c2-49a0-8239-cb003b8797e4
udev.log_priority=3
Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 2-in-1 Laptop
16-aa0xxx v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8C16 v: 85.37 serial: <superuser required>
part-nu: 9D1Q8EA#ABZ uuid: <superuser required> UEFI: AMI v: F.12
date: 10/29/2024
ID-1: BAT0 charge: 77.7 Wh (100.0%) condition: 77.7/83.0 Wh (93.5%)
volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 3
Device-1: hid-34:88:5d:43:70:5d-battery model: Keyboard K380 serial: N/A
charge: N/A status: discharging
System RAM: total: 32 GiB available: 30.71 GiB used: 9.01 GiB (29.3%)
Device-1: Bottom - on board type: LPDDR5 detail: synchronous size: 16 GiB
speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5 width (bits): data: 16
total: 16 manufacturer: Samsung part-no: K3KL9L90CM-MGCT serial: N/A
Device-2: Bottom - on board type: LPDDR5 detail: synchronous size: 16 GiB
Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2000 min/max: 400/4500:4800:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 2000 3: 2000
4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 9: 2000 10: 2000 11: 2000 12: 2000
13: 2000 14: 2000 15: 2000 16: 2000 17: 2000 18: 2000 19: 2000 20: 2000
21: 2000 22: 2000 bogomips: 131788
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x41a6 built: 2022 res: 2880x1800 dpi: 213
gamma: 1.2 chroma: red: x: 0.686 y: 0.318 green: x: 0.239 y: 0.714 blue:
x: 0.137 y: 0.043 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: 2880x1800
EDID-Warnings: 1: parse_edid: unknown flag 2 2: parse_edid: unknown tag
112
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 14.99 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
name: Intel Arc Graphics (MTL) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:7d55 surfaces: xcb,xlib,wayland
Info: Tools: api: eglinfo, glxinfo, vulkaninfo x11: xprop,xrandr
Device-1: Intel Meteor Lake IPU vendor: Hewlett-Packard driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 00:05.0 chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.14.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
driver: iwlwifi v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 8086:272b class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: nordtun state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-4: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-5: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0036 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0000
Device-1: luks-c26f9573-98dc-48bb-a133-81fedbae1131 maj-min: 253:2
type: LUKS dm: dm-2 size: 1.82 TiB
Components:
p-1: sda maj-min: 8:0 size: 1.82 TiB
Device-2: luks-4fa7a601-d6db-4acf-aefb-c54066635d15 maj-min: 253:0
type: LUKS dm: dm-0 size: 1.85 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.85 TiB
Device-3: luks-5897c51d-56c2-49a0-8239-cb003b8797e4 maj-min: 253:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Local Storage: total: 3.68 TiB used: 1.23 TiB (33.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: HP01AP40 temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Corsair model: MP600 MINI
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A serial: <filter>
fw-rev: 1.00
ID-1: / raw-size: 1.85 TiB size: 1.85 TiB (100.00%) used: 132.64 GiB (7.0%)
fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-4fa7a601-d6db-4acf-aefb-c54066635d15 label: N/A
uuid: 7e1e0ede-41c3-4804-8736-dd5cb2cd9074
used: 79.8 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 92CE-871A
ID-3: /home raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
used: 132.64 GiB (7.0%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
ID-4: /run/media/marco/VMs raw-size: 1.82 TiB size: 1.82 TiB (99.95%)
used: 1.1 TiB (60.3%) fs: xfs dev: /dev/dm-2 maj-min: 253:2
mapped: luks-c26f9573-98dc-48bb-a133-81fedbae1131 label: VMs
uuid: e2861741-6080-4137-928c-41086ffcb21c
ID-5: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
used: 0 KiB (0.0%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
ID-6: /var/cache raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
ID-7: /var/log raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
dev: /dev/dm-1 maj-min: 253:1
mapped: luks-5897c51d-56c2-49a0-8239-cb003b8797e4 label: swap
uuid: bd3ad032-2116-4a5c-ac11-a51009fd41dc
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 2-2:2 info: Realtek RTL9210 M.2 NVME Adapter type: mass storage
driver: uas interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
mode: 3.2 gen-2x1 power: 896mA chip-ID: 0bda:9210 class-ID: 0806
serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:016c class-ID: ff00 serial: <filter>
Hub-4: 3-5:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-5: 3-5.1:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-6: 3-5.2:6 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-7: 3-5.3:7 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-5.3.2:8 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Device-2: 3-10:4 info: Intel type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-10: 4-1.1:3 info: Genesys Logic Hub ports: 4 rev: 3.2
Hub-11: 4-1.2:4 info: Genesys Logic Hub ports: 4 rev: 3.2
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: 1911 pm: dpkg pkgs: 0 pm: pacman pkgs: 1881 libs: 374
tools: gnome-software,pamac,yay pm: flatpak pkgs: 30
Active pacman repo servers in: /etc/pacman.conf
1: https://mega.nz/linux/repo/Arch_Extra/$arch
2: https://releases.warp.dev/linux/pacman/$repo/$arch
1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
3: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
4: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 575
1: cpu: 24.0% command: firefox pid: 10790 mem: 508.3 MiB (1.6%)
2: cpu: 16.4% command: gnome-shell pid: 8147 mem: 408.6 MiB (1.2%)
3: cpu: 14.2% command: firefox pid: 10969 mem: 458.4 MiB (1.4%)
4: cpu: 13.0% command: zsh pid: 12456 mem: 8.93 MiB (0.0%)
5: cpu: 9.2% command: firefox pid: 11121 mem: 287.9 MiB (0.9%)
Memory top: 5 of 575
1: mem: 665.9 MiB (2.1%) command: telegram-desktop pid: 8396 cpu: 1.8%
2: mem: 508.3 MiB (1.6%) command: firefox pid: 10790 cpu: 24.0%
3: mem: 458.4 MiB (1.4%) command: firefox pid: 10969 cpu: 14.2%
4: mem: 408.6 MiB (1.2%) command: gnome-shell pid: 8147 cpu: 16.4%
5: mem: 301.2 MiB (0.9%) command: rambox pid: 11344 cpu: 7.4%
Processes: 575 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.27 GiB services: gsd-power,upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: tilix
inxi: 3.3.38
Mod edit:- Tidied general formatting. No charge.
