Well, for me it is a bit difficult to explain.
If I go to the application screen by moving the mouse pointer to the corner top left, the screen appears. Then I usually type an application name (eg “back in” for Back in Time). Under the searchfield will appear Icons of the desired application, in the example 2 Icons, one for BackInTime, one for BackInTime(Root).
The problem is: since some time (don’t know excatly 3-4 weeks?) I cannot click these Icons. If i try, the “hang” on the mouse cursor, I can move them around but I can’t do anything than pressing “esc” to cancel. The 1st Icon is highlighted an can be started by pressing “enter” but I can’t access the 2nd or 3rd Icon. even “TAB” dos not chose another Icon.
More down on the screen some other search results appear and THERE mouse click is accepted.
I don’t have any trouble with the mouse elsewhere, and yes, I tried another mouse on another USB-Port and another keyboard. Also (as far as I see) I have installed all updates.
Does anyone have an Idea?
Regards,
Sönke
