Hi,
I have an issue with the system settings in plasma where the application permissions panel is grayed out.
This is a big problem because it makes it impossible to revoke permissions once they have been granted, unless there is another mechanism to do so. Clearly, it has security implications.
The KDE devs remark that (quoting from a bug report, see https://bugs.kde.org/show_bug.cgi?id=490666)
The permissions are stored in System Settings > Application Permissions.
If you're using Plasma 6.5 and you don't see that page, or it doesn't work,
then there's some kind of local misconfiguration on your system or a
distro-specific problem.
Because I am on “testing” I am definitely on plasma 6.5, so that should work. I do not think it comes from my local configuration, so I suspect the “distro-specific” problem might be at stake. Is this the case? Is it arch-derived?
