Application panel in GNOME 42 Settings is empty on fresh install
I recently installed Manjaro on another computer; and after updating to GNOME 42, discovered that the Application Panel/application list was empty. All it shows is No applications and “Install some” on a button.
Have the same issue with the empty Application panel after update. Have you fixed it? Also i rebuilt AUR packages with pamac upgrade -a. Don’t know if this could cause a conflict.
I have the same issue after the last update running Manjaro Ruah 21.3.0.
Notice the same behavior on Manjaro 21.3.4. Empty tab with one button
The same on 21.3.6
Can I see a screenshot about the issue?
@Chrysostomus I just discovered I see the same problem:
Same here on Manjaro and Endeverous installs. What for is that settings screen anyway?
It’s a known issue. There’s now an Arch bug report about it: FS#75501 - [gnome-control-center] Applications panel empty when malcontent is not installed. FS#75305 - [gnome-control-center] Application panel is empty if malcontent is not installed
If you install malcontent and restart, applications appear. Found in the link for the bug above
