I downloaded 2 appimage, one of whale-etchers and one of Kdrive cloud. I made them executable, but when I click I don’t start applications.
What can I do?
Did you mean balenaEtcher ?
Try running the AppImage from the terminal and see if there are any errors; i.e.,
./kDrive-3.3.7.20221109.AppImage
I’d install Appimagelauncher then all you have to do is just click on them normally to install them. I’d suggest placing the Appimages somewhere you won’t lose them and when you want to instal just drag and copy them to your Desktop cause once you click on them to install they will be movbed to you Applications foldser.
[sandro@sandro1 Documenti]$ ./kDrive-3.3.7.20221109.AppImage
dlopen(): error loading libfuse.so.2
AppImages require FUSE to run.
You might still be able to extract the contents of this AppImage
if you run it with the --appimage-extract option.
See FUSE · AppImage/AppImageKit Wiki · GitHub
for more information
SOLVED
I installed the FUSE package.
It’s all right now.
Thank you all.
