When I launch the Zoho Mail desktop AppImage I get, “cannot mount AppImage please check your fuse setup.”
When I open this AppImage for the first time after a reboot, I do not get the error. But if I close it and then reopen it, I get the error every time after that.
The AppImage works fine, I just have to close the error message every time.
This is only happening on one of my Manjaro machines but not the other. Both are using Plasma.
I was just trying to find a solution, so I don’t have to close the error message every time I open the app. If there isn’t one, I’ll just live with it.
It is odd though that this doesn’t happen on another machine with Manjaro.
When you update new version of this AppImage, the new App will be created in the KDE menu. But it does not have this option --appimage-extract-and-run. You can edit it manually.
It use to always happen. I think with successive updates from Zoho it gets better, cause where I use to get it all the time I only get everyother time now.
