So i’m triyng to run Orcaslicer [project link] on my Manjaro system.
I just get error when i try to run it. seems like I’m missing something for it to run.
Installed and tried to run with AppImageLauncher too.
$ ./OrcaSlicer_Linux_V2.0.0-beta.AppImage
/tmp/.mount_OrcaSlVVl9XN/bin/orca-slicer: error while loading shared libraries: libwebkit2gtk-4.0.so.37: cannot open shared object file: No such file or directory
Problem seem to be that i’ve wrong version of libwebkit2gtk.
$ pacman -Qs libwebkit
local/webkit2gtk-4.1 2.42.5-2
Web content engine for GTK
I did find this AUR “webkit2gtk-4.0-hvml 2.34.1-8” But i get error when i try to install.
So I’m kind of lost here. Isn’t appimage supposed to be “independent”?
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=8a3d48b0-be62-4c5e-b601-d6852651ba19 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A33 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: X370 SLI PLUS (MS-7A33) v: 2.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 3.JU date: 11/02/2021
ID-1: hidpp_battery_0 charge: 78% condition: N/A volts: 4.0 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
System RAM: total: 32 GiB available: 31.28 GiB used: 6.88 GiB (22.0%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2B3200C16 serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2200 min/max: 2200/4409 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 91236
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: CardExpert driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 2e:00.0 chip-ID: 10de:2704
class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 6840x2160 s-dpi: 101 s-size: 1719x543mm (67.68x21.38")
s-diag: 1803mm (70.97")
Monitor-1: DP-2 pos: bottom-r res: 1920x1080 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-2: DP-4 pos: top-left res: 1080x1920 hz: 60 dpi: 102
size: 268x477mm (10.55x18.78") diag: 547mm (21.54") modes: N/A
Monitor-3: HDMI-0 pos: primary,top-center res: 3840x2160 dpi: 139
size: 700x390mm (27.56x15.35") diag: 801mm (31.55") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
memory: 15.62 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 550.54.14
device-ID: 10de:2704 surfaces: xcb,xlib
Device-1: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 2e:00.1 chip-ID: 10de:22bb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: DSEA A/S EPOS H3PRO driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.4.1:5
chip-ID: 1395:0101 class-ID: 0300 serial: <filter>
Device-4: DSEA A/S EPOS H3PRO Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 1395:0303 class-ID: 0300
serial: <filter>
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 29:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp41s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox 360 Wireless Adapter driver: xpad type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 045e:0719
class-ID: ff00 serial: <filter>
Info: services: NetworkManager
Local Storage: total: 2.5 TiB used: 1 TiB (40.0%)
model: WDS512G1X0C-00ENX0 size: 476.94 GiB block-size: physical: 512 B
fw-rev: B35500WD temp: 59.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EFRX-68EUZN0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A82 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Corsair model: Force LE SSD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 12.2 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 51.31 GiB (11.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 8a3d48b0-be62-4c5e-b601-d6852651ba19
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: AC99-6BB5
ID-3: /home/<filter>/#EXA raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 973.98 GiB (53.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: EXA
uuid: d662067d-1ac6-4179-9a6d-e1a12f648245
ID-4: /home/<filter>/#MY raw-size: 223.57 GiB size: 219 GiB (97.96%)
used: 2 MiB (0.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: MY
uuid: 15ccf5f0-ca00-47d2-b872-c626b8e60736
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-2:2 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
driver: xpad interfaces: 8 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 260mA chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Device-2: 1-12:3 info: Corsair Gaming K70 LUX RGB Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 1b1c:1b33 class-ID: 0300 serial: <filter>
Device-3: 1-13:4 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Hub-7: 5-3.4:4 info: Cambridge Silicon Radio ports: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 0a12:4010
Device-1: 5-3.4.1:5 info: DSEA A/S EPOS H3PRO type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
Device-2: 5-4:3 info: DSEA A/S EPOS H3PRO Dongle type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
chip-ID: 1395:0303 class-ID: 0300 serial: <filter>
Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 6-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Device-1: 6-3.1:3 info: Genesys Logic All-in-One Cardreader
type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 05e3:0732 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 46.2 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: 1387 pm: pacman pkgs: 1381 libs: 362 tools: pamac pm: flatpak
pkgs: 6
Active pacman repo servers in: /etc/pacman.conf
1: https://mega.nz/linux/repo/Arch_Extra/$arch
1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
2: https://mirror.zetup.net/manjaro/stable/$repo/$arch
3: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 314
1: cpu: 17.7% command: firefox pid: 1821 mem: 664.8 MiB (2.0%)
2: cpu: 4.6% command: firefox pid: 2237 mem: 334.6 MiB (1.0%)
3: cpu: 3.7% command: FreeCAD pid: 8526 mem: 763.3 MiB (2.3%)
4: cpu: 2.8% command: Xorg pid: 638 mem: 254.4 MiB (0.7%)
5: cpu: 1.6% command: firefox pid: 12451 mem: 319.3 MiB (0.9%)
Memory top: 5 of 314
1: mem: 1449.9 MiB (4.5%) command: pamac-manager pid: 2885 cpu: 1.0%
2: mem: 763.3 MiB (2.3%) command: FreeCAD pid: 8526 cpu: 3.7%
3: mem: 664.8 MiB (2.0%) command: firefox pid: 1821 cpu: 17.7%
4: mem: 532.6 MiB (1.6%) command: plasmashell pid: 908 cpu: 0.5%
5: mem: 416.6 MiB (1.3%) command: gimp-2.10 pid: 9847 cpu: 0.2%
Processes: 314 Power: uptime: 46m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
