I have an AMD GPU that supports vulkan and it’s working fine for other applications but is not working for a particular appimage. Looking at the logs I get the message Vulkan: Missing required extension VK_KHR_surface.
but my system does support this extension.
Here is the output of vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.3.221
Instance Extensions: count = 20
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 7
VK_LAYER_INTEL_nullhw (INTEL NULL HW) Vulkan version 1.1.73, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (AMD RADV NAVI10)
Layer-Device Extensions: count = 0
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.3.211, layer version 1:
Devices: count = 1
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.3.211, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (AMD RADV NAVI10):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
AMD RADV NAVI10 (ID: 0)
subsetAllocation = 0
Present Capabilities:
AMD RADV NAVI10 (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4206803 (1.3.211)
driverVersion = 92278788 (0x5801004)
vendorID = 0x1002
deviceID = 0x731f
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = AMD RADV NAVI10
pipelineCacheUUID = f80cb1c2-9551-182a-5547-75d40fe81b51
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 4294967295
maxUniformBufferRange = 4294967295
maxStorageBufferRange = 4294967295
maxPushConstantsSize = 256
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000001
sparseAddressSpaceSize = 0xfffffffc
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 8388606
maxPerStageDescriptorUniformBuffers = 8388606
maxPerStageDescriptorStorageBuffers = 8388606
maxPerStageDescriptorSampledImages = 8388606
maxPerStageDescriptorStorageImages = 8388606
maxPerStageDescriptorInputAttachments = 8388606
maxPerStageResources = 8388606
maxDescriptorSetSamplers = 8388606
maxDescriptorSetUniformBuffers = 8388606
maxDescriptorSetUniformBuffersDynamic = 16
maxDescriptorSetStorageBuffers = 8388606
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 8388606
maxDescriptorSetStorageImages = 8388606
maxDescriptorSetInputAttachments = 8388606
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 4294967295
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4096
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 127
maxGeometryInputComponents = 64
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 8388606
maxComputeSharedMemorySize = 65536
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 1024
maxComputeWorkGroupSize: count = 3
1024
1024
1024
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 16
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32767
viewportSubPixelBits = 8
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000004
minUniformBufferOffsetAlignment = 0x00000004
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -32
maxTexelOffset = 31
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -2
maxInterpolationOffset = 2
subPixelInterpolationOffsetBits = 8
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 1024
framebufferColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferNoAttachmentsSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
storageImageSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 10
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0
8191.88
lineWidthRange: count = 2
0
8191.88
pointSizeGranularity = 0.125
lineWidthGranularity = 0.125
strictLines = false
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000001
optimalBufferCopyRowPitchAlignment = 0x00000001
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = true
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
primitiveOverestimationSize = 0
maxExtraPrimitiveOverestimationSize = 0
extraPrimitiveOverestimationSizeGranularity = 0
primitiveUnderestimation = false
conservativePointAndLineRasterization = false
degenerateTrianglesRasterized = true
degenerateLinesRasterized = false
fullyCoveredFragmentShaderInputVariable = false
conservativeRasterizationPostDepthCoverage = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 3
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 67108863
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = false
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 8388606
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 8388606
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 8388606
maxPerStageDescriptorUpdateAfterBindSampledImages = 8388606
maxPerStageDescriptorUpdateAfterBindStorageImages = 8388606
maxPerStageDescriptorUpdateAfterBindInputAttachments = 8388606
maxPerStageUpdateAfterBindResources = 8388606
maxDescriptorSetUpdateAfterBindSamplers = 8388606
maxDescriptorSetUpdateAfterBindUniformBuffers = 8388606
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 16
maxDescriptorSetUpdateAfterBindStorageBuffers = 8388606
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 8388606
maxDescriptorSetUpdateAfterBindStorageImages = 8388606
maxDescriptorSetUpdateAfterBindInputAttachments = 8388606
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
maxDiscardRectangles = 4
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_MESA_RADV
driverName = radv
driverInfo = Mesa 22.1.4
conformanceVersion:
major = 1
minor = 2
subminor = 7
patch = 1
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 0
renderMajor = 226
renderMinor = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat16 = true
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = true
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = 00000000-0900-0000-0000-000000000000
driverUUID = 414d442d-4d45-5341-2d44-525600000000
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockProperties:
maxInlineUniformBlockSize = 4194304
maxPerStageDescriptorInlineUniformBlocks = 134217728
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 134217728
maxDescriptorSetInlineUniformBlocks = 64
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 64
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 22369621
maxMemoryAllocationSize = 0xfffffffc
VkPhysicalDeviceMaintenance4Properties:
maxBufferSize = 0xfffffffc
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 8
maxMultiviewInstanceIndex = 2147483647
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 9
pciDevice = 0
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = true
filterMinmaxImageComponentMapping = true
VkPhysicalDeviceShaderIntegerDotProductProperties:
integerDotProduct8BitUnsignedAccelerated = false
integerDotProduct8BitSignedAccelerated = false
integerDotProduct8BitMixedSignednessAccelerated = false
integerDotProduct4x8BitPackedUnsignedAccelerated = false
integerDotProduct4x8BitPackedSignedAccelerated = false
integerDotProduct4x8BitPackedMixedSignednessAccelerated = false
integerDotProduct16BitUnsignedAccelerated = false
integerDotProduct16BitSignedAccelerated = false
integerDotProduct16BitMixedSignednessAccelerated = false
integerDotProduct32BitUnsignedAccelerated = false
integerDotProduct32BitSignedAccelerated = false
integerDotProduct32BitMixedSignednessAccelerated = false
integerDotProduct64BitUnsignedAccelerated = false
integerDotProduct64BitSignedAccelerated = false
integerDotProduct64BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating8BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating8BitSignedAccelerated = false
integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating16BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating16BitSignedAccelerated = false
integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating32BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating32BitSignedAccelerated = false
integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating64BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating64BitSignedAccelerated = false
integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated = false
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 64
supportedStages: count = 8
SHADER_STAGE_VERTEX_BIT
SHADER_STAGE_TESSELLATION_CONTROL_BIT
SHADER_STAGE_TESSELLATION_EVALUATION_BIT
SHADER_STAGE_GEOMETRY_BIT
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
SHADER_STAGE_ALL_GRAPHICS
SHADER_STAGE_ALL
supportedOperations: count = 8
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_ARITHMETIC_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_CLUSTERED_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlProperties:
minSubgroupSize = 32
maxSubgroupSize = 64
maxComputeWorkgroupSubgroups = 4294967295
requiredSubgroupSizeStages: count = 2
SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentProperties:
storageTexelBufferOffsetAlignmentBytes = 0x00000004
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000004
uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0xffffffff
maxTransformFeedbackStreamDataSize = 512
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 512
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = true
transformFeedbackRasterizationStreamSelect = false
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 64
subgroupSupportedStages: count = 8
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 8
subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
driverName = radv
conformanceVersion:
major = 1
minor = 2
subminor = 7
patch = 1
framebufferIntegerColorSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
VkPhysicalDeviceVulkan13Properties:
SHADER_STAGE_ALL
maxInlineUniformTotalSize = 65535
Device Extensions: count = 135
VK_AMD_buffer_marker : extension revision 1
VK_AMD_device_coherent_memory : extension revision 1
VK_AMD_draw_indirect_count : extension revision 2
VK_AMD_gcn_shader : extension revision 1
VK_AMD_gpu_shader_half_float : extension revision 2
VK_AMD_gpu_shader_int16 : extension revision 2
VK_AMD_memory_overallocation_behavior : extension revision 1
VK_AMD_mixed_attachment_samples : extension revision 1
VK_AMD_shader_ballot : extension revision 1
VK_AMD_shader_core_properties : extension revision 2
VK_AMD_shader_core_properties2 : extension revision 1
VK_AMD_shader_explicit_vertex_parameter : extension revision 1
VK_AMD_shader_fragment_mask : extension revision 1
VK_AMD_shader_image_load_store_lod : extension revision 1
VK_AMD_shader_trinary_minmax : extension revision 1
VK_AMD_texture_gather_bias_lod : extension revision 1
VK_EXT_4444_formats : extension revision 1
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clip_control : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_global_priority_query : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 2
VK_EXT_image_robustness : extension revision 1
VK_EXT_image_view_min_lod : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_memory_priority : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_primitive_topology_list_restart : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_atomic_float2 : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_image_atomic_int64 : extension revision 1
VK_EXT_shader_stencil_export : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_vertex_input_dynamic_state : extension revision 2
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_dynamic_rendering : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_format_feature_flags2 : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_maintenance4 : extension revision 2
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_pipeline_library : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_integer_dot_product : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_extended_types : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VK_VALVE_mutable_descriptor_type : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
timestampValidBits = 64
present support = true
VkQueueFamilyGlobalPriorityPropertiesKHR:
priorityCount = 4
priorities: count = 4
QUEUE_GLOBAL_PRIORITY_LOW_KHR
QUEUE_GLOBAL_PRIORITY_MEDIUM_KHR
QUEUE_GLOBAL_PRIORITY_HIGH_KHR
QUEUE_GLOBAL_PRIORITY_REALTIME_KHR
queueProperties[1]:
queueCount = 4
queueFlags = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
priorityCount = 4
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
memoryHeaps[0]:
size = 8321499136 (0x1f0000000) (7.75 GiB)
budget = 8170684416 (0x1e702c000) (7.61 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1]:
size = 8573157376 (0x1ff000000) (7.98 GiB)
budget = 8508628992 (0x1fb276000) (7.92 GiB)
flags:
None
memoryHeaps[2]:
size = 268435456 (0x10000000) (256.00 MiB)
budget = 230608896 (0x0dbed000) (219.93 MiB)
flags: count = 1
memoryTypes: count = 8
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D16_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
IMAGE_TILING_LINEAR:
color images
memoryTypes[1]:
heapIndex = 1
propertyFlags = 0x0006: count = 2
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[2]:
heapIndex = 2
propertyFlags = 0x0007: count = 3
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[3]:
heapIndex = 1
propertyFlags = 0x000e: count = 3
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[4]:
heapIndex = 0
propertyFlags = 0x00c1: count = 3
MEMORY_PROPERTY_DEVICE_COHERENT_BIT_AMD
MEMORY_PROPERTY_DEVICE_UNCACHED_BIT_AMD
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[5]:
heapIndex = 1
propertyFlags = 0x00c6: count = 4
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[6]:
heapIndex = 2
propertyFlags = 0x00c7: count = 5
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[7]:
heapIndex = 1
propertyFlags = 0x00ce: count = 5
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = false
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = true
shaderStorageImageReadWithoutFormat = true
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = true
shaderResourceMinLod = true
sparseBinding = true
sparseResidencyBuffer = true
sparseResidencyImage2D = true
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = true
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = true
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = true
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = false
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = true
shaderUniformTexelBufferArrayDynamicIndexing = true
shaderStorageTexelBufferArrayDynamicIndexing = true
shaderUniformBufferArrayNonUniformIndexing = true
shaderSampledImageArrayNonUniformIndexing = true
shaderStorageBufferArrayNonUniformIndexing = true
shaderStorageImageArrayNonUniformIndexing = true
shaderInputAttachmentArrayNonUniformIndexing = true
shaderUniformTexelBufferArrayNonUniformIndexing = true
shaderStorageTexelBufferArrayNonUniformIndexing = true
descriptorBindingUniformBufferUpdateAfterBind = true
descriptorBindingSampledImageUpdateAfterBind = true
descriptorBindingStorageImageUpdateAfterBind = true
descriptorBindingStorageBufferUpdateAfterBind = true
descriptorBindingUniformTexelBufferUpdateAfterBind = true
descriptorBindingStorageTexelBufferUpdateAfterBind = true
descriptorBindingUpdateUnusedWhilePending = true
descriptorBindingPartiallyBound = true
descriptorBindingVariableDescriptorCount = true
runtimeDescriptorArray = true
VkPhysicalDeviceDynamicRenderingFeatures:
dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesKHR:
globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeatures:
robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeatures:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = false
bresenhamLines = true
smoothLines = false
stippledRectangularLines = false
stippledBresenhamLines = true
stippledSmoothLines = false
VkPhysicalDeviceMaintenance4Features:
maintenance4 = true
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
memoryPriority = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeatures:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
primitiveTopologyListRestart = true
primitiveTopologyPatchListRestart = false
VkPhysicalDevicePrivateDataFeatures:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloat2FeaturesEXT:
shaderBufferFloat16Atomics = false
shaderBufferFloat16AtomicAdd = false
shaderBufferFloat16AtomicMinMax = false
shaderBufferFloat32AtomicMinMax = true
shaderBufferFloat64AtomicMinMax = true
shaderSharedFloat16Atomics = false
shaderSharedFloat16AtomicAdd = false
shaderSharedFloat16AtomicMinMax = false
shaderSharedFloat32AtomicMinMax = true
shaderSharedFloat64AtomicMinMax = true
shaderImageFloat32AtomicMinMax = true
sparseImageFloat32AtomicMinMax = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = true
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = true
shaderSharedFloat64Atomics = true
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = true
sparseImageFloat32AtomicAdd = false
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = true
shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeatures:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = true
shaderInt8 = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
shaderImageInt64Atomics = true
sparseImageInt64Atomics = true
VkPhysicalDeviceShaderIntegerDotProductFeatures:
shaderIntegerDotProduct = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeatures:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeatures:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSynchronization2Features:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTextureCompressionASTCHDRFeatures:
textureCompressionASTC_HDR = false
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVertexInputDynamicStateFeaturesEXT:
vertexInputDynamicState = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = true
descriptorIndexing = true
samplerFilterMinmax = true
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = false
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkan13Features:
privateData = true
shaderZeroInitializeWorkgroupMemory = true
maintenance4 = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeatures:
Here is the output of inxi -Fx
Host: manjaro Kernel: 5.18.16-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.1 Desktop: Xfce v: 4.16.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F62
date: 07/13/2021
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2237 high: 2742 min/max: 2200/4208 boost: enabled
cores: 1: 1939 2: 2477 3: 2056 4: 2199 5: 2196 6: 2196 7: 2742 8: 2396
9: 2061 10: 2196 11: 2195 12: 2196 bogomips: 86270
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1 bus-ID: 09:00.0
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting,radeon gpu: amdgpu resolution: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 09:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4
Sound Server-1: ALSA v: k5.18.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:ed:25:e6
Local Storage: total: 2.27 TiB used: 1.53 TiB (67.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0
size: 465.76 GiB temp: 40.9 C
ID-2: /dev/sda vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 136.58 GiB used: 113.59 GiB (83.2%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 25.7 MiB (26.7%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 40.6 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 687
Processes: 309 Uptime: 1h 1m Memory: 15.56 GiB used: 3.58 GiB (23.0%)
Init: systemd Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1669
Shell: Bash v: 5.1.16 inxi: 3.3.20
I also have all required packages installed, including 32bit versions, namely: vulkan-icd-loader
, lib32-vulkan-icd-loader
, vulkan-radeon
, lib32-vulkan-radeon
Any ideas?
