Hi there! First post so bear with me.
Apex Legends fails to start,
Reaching the EAC loading window for a split second,
and kills the process.
My laptop has an intel cpu with an nvidia 760m gpu. (legacy active)
I use optimus to switch between intergrated and dgpu,
but I keep it locked to nvidia due to hybrid not working.
Info about the laptop:
> System:
> Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
> root=UUID=58c28ee3-68e7-441c-bf03-9bd3e0b79991 rw quiet
> udev.log_priority=3
> Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
> Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Laptop System: Acer product: Aspire V3-772 v: V1.15 serial: <filter>
> Mobo: Acer model: VA70_HW v: Type2 - Board Version serial: <filter>
> UEFI: Insyde v: 1.15 date: 03/07/2014
> Battery:
> ID-1: BAT0 charge: 16.3 Wh (53.4%) condition: 30.5/72.6 Wh (42.0%)
> volts: 11.3 min: 10.8 model: AS10D31 type: Li-ion serial: N/A status: N/A
> Memory:
> RAM: total: 15.51 GiB used: 3.52 GiB (22.7%)
> Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
> note: est.
> Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
> speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
> manufacturer: N/A part-no: F3-1600C9-8GRSL serial: N/A
> Device-2: DIMM1 type: no module installed
> Device-3: DIMM1 type: DDR3 detail: synchronous size: 8 GiB
> Device-4: DIMM3 type: no module installed
> CPU:
> Info: model: Intel Core i7-4702MQ socket: LGA1150 (U3E1) note: check
> bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 built: 2013-15
> process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
> microcode: 0x28
> Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
> L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
> L3: 6 MiB desc: 1x6 MiB
> Speed (MHz): avg: 3019 high: 3155 min/max: 800/3200 base/boost: 2200/2200
> scaling: driver: intel_cpufreq governor: schedutil volts: 0.7 V
> ext-clock: 100 MHz cores: 1: 2916 2: 3027 3: 3155 4: 3144 5: 3006 6: 2913
> 7: 2980 8: 3016 bogomips: 35133
> Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
> bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
> dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
> fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
> md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
> pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
> rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
> syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
> vpid xsave xsaveopt xtopology xtpr
> Vulnerabilities:
> Type: itlb_multihit status: KVM: VMX disabled
> Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
> vulnerable
> Type: mds mitigation: Clear CPU buffers; SMT vulnerable
> Type: meltdown mitigation: PTI
> Type: mmio_stale_data status: Not affected
> Type: retbleed status: Not affected
> Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
> prctl and seccomp
> Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
> sanitization
> Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW,
> STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
> Type: srbds mitigation: Microcode
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Acer
> Incorporated ALI driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm
> built: 2010 ports: active: eDP-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:02.0
> chip-ID: 8086:0416 class-ID: 0300
> Device-2: NVIDIA GK106M [GeForce GTX 760M] vendor: Acer Incorporated ALI
> driver: nvidia v: 390.154 alternate: nouveau,nvidia_drm non-free:
> series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Kepler
> code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s
> lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
> chip-ID: 10de:11e3 class-ID: 0302
> Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-5:3
> chip-ID: 04f2:b374 class-ID: 0e02
> Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
> compositor: gnome-shell driver: X: loaded: modesetting,nvidia gpu: i915
> display-ID: :1 screens: 1
> Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
> Monitor-1: eDP-1 mapped: eDP-1-1 model: ChiMei InnoLux 0x1735 built: 2012
> res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
> diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
> OpenGL: renderer: GeForce GTX 760M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
> direct render: Yes
> Audio:
> Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Acer
> Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
> chip-ID: 8086:0c0c class-ID: 0403
> Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Acer
> Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
> chip-ID: 8086:8c20 class-ID: 0403
> Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
> Sound Server-2: JACK v: 1.9.21 running: no
> Sound Server-3: PulseAudio v: 16.1 running: yes
> Sound Server-4: PipeWire v: 0.3.56 running: yes
> Network:
> Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn
> driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
> bus-ID: 0d:00.0 chip-ID: 168c:0034 class-ID: 0280
> IF: wlp13s0 state: up mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: dynamic noprefixroute scope: global
> IP v6: <filter> type: noprefixroute scope: link
> Device-2: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe vendor: Acer
> Incorporated ALI driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s
> lanes: 1 port: N/A bus-ID: 0e:00.0 chip-ID: 14e4:1692 class-ID: 0200
> IF: enp14s0 state: down mac: <filter>
> WAN IP: <filter>
> Bluetooth:
> Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
> chip-ID: 0489:e04e class-ID: e001
> Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
> Logical:
> Message: No logical block device data found.
> RAID:
> Message: No RAID data found.
> Drives:
> Local Storage: total: 2.06 TiB used: 97.67 GiB (4.6%)
> ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
> family: Mobile HDD size: 1.82 TiB block-size: physical: 4096 B
> logical: 512 B sata: 3.1 speed: 3.0 Gb/s type: HDD rpm: 5400
> serial: <filter> rev: SDM1 temp: 37 C scheme: MBR
> SMART: yes state: enabled health: PASSED on: 1y 144d 0h cycles: 3012
> read: 13.03 TiB written: 13.99 TiB Old-Age: g-sense error rate: 105
> Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
> ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
> family: based SSDs size: 232.89 GiB block-size: physical: 512 B
> logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
> rev: 2B6Q temp: 34 C scheme: GPT
> SMART: yes state: enabled health: PASSED on: 1y 212d 15h cycles: 3871
> written: 18.92 TiB
> ID-3: /dev/sdc maj-min: 8:32 type: USB model: N/A size: 14.65 GiB
> block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
> rev: 2.00 scheme: MBR
> SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
> Message: No optical or floppy data found.
> Partition:
> ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 93.29 GiB
> (40.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18
> label: N/A uuid: 58c28ee3-68e7-441c-bf03-9bd3e0b79991
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
> (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
> label: NO_LABEL uuid: E746-3A6D
> ID-3: /run/media/mzziliac/MSI DISK raw-size: 14.65 GiB size: 14.65 GiB
> (100.00%) used: 4.38 GiB (29.9%) fs: ntfs block-size: 4096 B
> dev: /dev/sdc1 maj-min: 8:33 label: MSI DISK uuid: 14C24A6FC24A5560
> Swap:
> Alert: No swap data was found.
> Unmounted:
> ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: N/A
> uuid: 6FF6C312404DF3D4
> ID-2: /dev/sda2 maj-min: 8:2 size: 931.51 GiB fs: ntfs label: Windows Data
> uuid: 58238DF15B2B1184
> USB:
> Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
> chip-ID: 1d6b:0002 class-ID: 0900
> Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
> speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
> Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
> speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
> Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
> speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
> Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
> Device-1: 3-2:2 info: USB Disk 2.0 type: Mass Storage driver: usb-storage
> interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 346d:5678
> class-ID: 0806 serial: <filter>
> Device-2: 3-5:3 info: Chicony HD WebCam type: Video driver: uvcvideo
> interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b374
> class-ID: 0e02
> Device-3: 3-10:4 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
> interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e04e
> class-ID: e001
> Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
> chip-ID: 1d6b:0003 class-ID: 0900
> Sensors:
> System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 48 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 293 Uptime: 26m wakeups: 1 Init: systemd v: 251
> default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
> Packages: pm: pacman pkgs: 1218 libs: 416 tools: gnome-software,pamac,yay
> Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: gnome-terminal
> inxi: 3.3.21
and the proton log with the issue seems to be this section
> info: Game: r5apex.exe
> info: DXVK: v1.10.1-async
> info: Built-in extension providers:
> info: Win32 WSI
> info: OpenVR
> info: OpenXR
> 2309.890:0128:016c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wineopenxr.dll" at 00007FC5E3D60000: builtin
> warn: OpenXR: Unable to get required Vulkan instance extensions size
> 2309.891:0128:016c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\vulkan-1.dll" at 00000003785E0000: builtin
> 2309.892:0128:016c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winevulkan.dll" at 00000003B6DC0000: builtin
> info: Enabled instance extensions:
> info: VK_KHR_get_surface_capabilities2
> info: VK_KHR_surface
> info: VK_KHR_win32_surface
> warn: Skipping Vulkan 1.0 adapter: GeForce GTX 760M
> warn: DXVK: No adapters found. Please check your device filter settings and Vulkan setup.
> warn: OpenXR: Unable to get required Vulkan Device extensions size
> 2309.928:0128:016c:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\wineopenxr.dll" : builtin
> 2309.928:0128:016c:fixme:virtual:NtQueryVirtualMemory (0xffffffffffffffff,0x7fc5e3d60000,info_class=3,0x5f48e210,48,(nil)) Unknown information class
> err: D3D11CreateDevice: No default adapter available
> 2309.930:0128:016c:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\vulkan-1.dll" : builtin
> 2309.930:0128:016c:fixme:virtual:NtQueryVirtualMemory (0xffffffffffffffff,0x3785e0000,info_class=3,0x5f48e500,48,(nil)) Unknown information class
> 2309.930:0128:016c:err:seh:NtRaiseException Unhandled exception code c0000409 flags 1 addr 0x140e1ee08
> pid 13472 != 13471, skipping destruction (fork without exec?)
Two things, Why is it skipping my 760m?
Is the vulkan version too low for this legacy gpu?
and DXVK cant find the adapter due to the issue above?
Thanks for the help
