Apache doesn't start with "SSL Engine on"
I’m trying to enable SSL on a virtual host…
TSL Section: Apache HTTP Server - ArchWiki
I generate cert:
cd /etc/httpd/conf
sudo openssl genpkey -algorithm RSA -out server.key                                                    1 ✘
sudo openssl req -new -sha256 -key server.key -out server.crt
Uncomment in ‘/etc/httpd/conf/httpd.conf’:
LoadModule ssl_module modules/mod_ssl.so
LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
Include conf/extra/httpd-ssl.conf      <- this cause apache error
Apache (httpd) no longer starts…
As soon as I use:
SSLEngine on
Apache doesn’t start…
My virtual host:
<VirtualHost *:80>
    ServerAdmin mail@gmail.com
    DocumentRoot "/home/user/www/saniday"
    ServerName saniday.test
    ServerAlias saniday.test
    ErrorLog "/var/log/httpd/saniday.test-error_log"
    CustomLog "/var/log/httpd/saniday.test-access_log" common
    <Directory "/home/user/www/saniday">
        Options Indexes FollowSymLinks MultiViews
        AllowOverride All
        Order allow,deny
        allow from all
        Require all granted
    </Directory>
    DirectoryIndex index.php index.html
    <FilesMatch \.php$>
        SetHandler "proxy:unix:/run/php-fpm/php-fpm.sock|fcgi://localhost/"
    </FilesMatch>
</VirtualHost>
<VirtualHost *:443>
    ServerName saniday.test:443
    ServerAlias saniday.test:443
    SSLEngine on                  #  <- this cause apache error
    SSLCertificateFile "/etc/httpd/conf/server.crt"
    SSLCertificateKeyFile "/etc/httpd/conf/server.key"
        AllowOverride All
        Order allow,deny
        allow from all
        Require all granted
    </Directory>
    <FilesMatch \.php$>
    </FilesMatch>
</VirtualHost>
My controls…
$ apachectl configtest
> Syntax OK
UPDATE
Generate cert with:
sudo openssl req -new -newkey rsa:2048 -nodes -keyout /etc/httpd/conf/ssl/server.key -out /etc/httpd/conf/ssl/server.csr
It seems that as soon as I write “SSLEngine on” in the configuration file, Apache doesn’t start.
Do I need to install any packages?
Error:
× httpd.service - Apache Web Server
     Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; preset: disabled)
     Active: failed (Result: exit-code) since Sat 2023-10-28 16:41:26 CEST; 2s ago
   Duration: 30ms
    Process: 21651 ExecStart=/usr/bin/httpd -k start -DFOREGROUND (code=exited, status=1/FAILURE)
   Main PID: 21651 (code=exited, status=1/FAILURE)
        CPU: 21ms
ott 28 16:41:26 Domenico-PC systemd[1]: Started Apache Web Server.
ott 28 16:41:26 Domenico-PC systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
ott 28 16:41:26 Domenico-PC systemd[1]: httpd.service: Failed with result 'exit-code'.
This won’t do - you need a specific hostname and a certificate matching the host name otherwise the service will fail.
<VirtualHost saniday.test:443>
Same error…
You should use a search engine - all your questions has been asked before …
https://sx.nix.dk/search?q=apache using self signed ssl
cd /etc/httpd/conf
sudo openssl req -new -sha256 -key server.key -out server.crt <---- if uncomment, apache dosn’t start
Error even if I create that virtual host 443…
I simply followed the instructions on the arch WIKI…
I read and tried many tutorials on the web before asking, but it still doesn’t work.
The Arch wiki is a puzzle - you need to get all the pieces right - obviously you are not.
I don’t use Apache as webserver but Nginx - and I had to do a lot of reading and experimenting to get it right.
I guess the same is valid for Apache and I have no intention of doing the same for Apache - too little :cheese: involved.
You should most certainly look at the properties provided for certificate - most prominently the lack of hostname for the system.
Let’s hope someone can help me, but not how to get out of this…
Post the error why apache fails, you only posted what you did but not the error form apache.
Unfortunately, apache uses it own logs. The journal output is in this case not really useful.
After do:
sudo systemctl restart httpd
/var/log/httpd/error_log
AH00016: Configuration Failed
EDIT
Apache runs if I comment in ‘/etc/httpd/conf/httpd.conf’:
#Include conf/extra/httpd-ssl.conf
And comment in ’ /etc/httpd/conf/vhosts/saniday.test’:
#    SSLEngine on
[Sat Oct 28 20:22:11.597319 2023] [ssl:warn] [pid 42914:tid 140577131022208] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Sat Oct 28 20:22:11.598010 2023] [mpm_event:notice] [pid 42914:tid 140577131022208] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.3 configured -- resuming normal operations
[Sat Oct 28 20:22:11.598017 2023] [core:notice] [pid 42914:tid 140577131022208] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Sat Oct 28 20:22:31.898738 2023] [mpm_event:notice] [pid 42914:tid 140577131022208] AH00492: caught SIGWINCH, shutting down gracefully
Start with apache AH01873…
How configure this (SSLSessionCache)?
Actually, in ‘/etc/httpd/conf/extra/httpd-ssl.conf’:
SSLSessionCache        "shmcb:/run/httpd/ssl_scache(512000)"
EDIT
GNU nano 7.2        /var/log/httpd/saniday.test-error_log
[Sun Oct 29 07:38:53.081407 2023] [ssl:info] [pid 48225:tid 140393948448640] AH01914: Configuring server saniday.test:443 for SSL protocol
[Sun Oct 29 07:38:53.081703 2023] [ssl:debug] [pid 48225:tid 140393948448640] ssl_engine_init.c(526): AH01893: Configuring TLS extension handling
[Sun Oct 29 07:38:53.081728 2023] [ssl:emerg] [pid 48225:tid 140393948448640] AH02562: Failed to configure certificate saniday.test:443:0 (with chain), check /etc/httpd/conf/server>
[Sun Oct 29 07:38:53.081734 2023] [ssl:emerg] [pid 48225:tid 140393948448640] SSL Library Error: error:0480006C:PEM routines::no start line (Expecting: TRUSTED CERTIFICATE) -- Bad >
[Sun Oct 29 07:38:53.081737 2023] [ssl:emerg] [pid 48225:tid 140393948448640] SSL Library Error: error:0A080009:SSL routines::PEM lib
If i run:
cd /etc/httpd/conf
sudo openssl req -x509 -newkey rsa:4096 -days 365 -keyout server.key -out server.crt
[enter the passkey]
openssl req -noout -text -in server.crt
Result:
4087D8D9077F0000:error:0480006C:PEM routines:get_name:no start line:crypto/pem/pem_lib.c:763:Expecting: CERTIFICATE REQUEST
Unable to load X509 request
In ‘/var/log/httpd/saniday.test-error_log’:
[Sun Oct 29 07:57:11.010113 2023] [ssl:info] [pid 49634:tid 140039683155840] AH01914: Configuring server saniday.test:443 for SSL protocol
[Sun Oct 29 07:57:11.010389 2023] [ssl:debug] [pid 49634:tid 140039683155840] ssl_engine_init.c(526): AH01893: Configuring TLS extension handling
[Sun Oct 29 07:57:11.011459 2023] [ssl:info] [pid 49634:tid 140039683155840] AH02576: Attempting to load encrypted (?) private key saniday.test:443:0
[Sun Oct 29 07:57:11.011513 2023] [ssl:info] [pid 49634:tid 140039683155840] AH01968: Init: Requesting pass phrase via builtin terminal dialog
[Sun Oct 29 07:57:11.011570 2023] [ssl:info] [pid 49634:tid 140039683155840] AH01968: Init: Requesting pass phrase via builtin terminal dialog
[Sun Oct 29 07:57:11.011715 2023] [ssl:error] [pid 49634:tid 140039683155840] AH02578: Init: Unable to read pass phrase [Hint: key introduced or changed before restart?]
[Sun Oct 29 07:57:11.011719 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:04800068:PEM routines::bad password read -- You entered an incorrect pass phrase!?
[Sun Oct 29 07:57:11.011722 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:1E08010C:DECODER routines::unsupported (No supported data to decode.  Input type: DER, Input structure: typ>
[Sun Oct 29 07:57:11.011725 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:068000A8:asn1 encoding routines::wrong tag
[Sun Oct 29 07:57:11.011727 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error
[Sun Oct 29 07:57:11.011730 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error (Field=version, Type=RSAPrivateKey)
[Sun Oct 29 07:57:11.011732 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:068000A8:asn1 encoding routines::wrong tag
[Sun Oct 29 07:57:11.011734 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error
[Sun Oct 29 07:57:11.011736 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error (Field=version, Type=PKCS8_PRIV_KEY_INFO)
[Sun Oct 29 07:57:11.011738 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:1E08010C:DECODER routines::unsupported (No supported data to decode.  Input type: DER, Input structure: typ>
[Sun Oct 29 07:57:11.011740 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:068000A8:asn1 encoding routines::wrong tag
[Sun Oct 29 07:57:11.011742 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error
[Sun Oct 29 07:57:11.011744 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:068000A8:asn1 encoding routines::wrong tag
[Sun Oct 29 07:57:11.011746 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error (Type=RSAPrivateKey)
[Sun Oct 29 07:57:11.011748 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:068000A8:asn1 encoding routines::wrong tag
[Sun Oct 29 07:57:11.011751 2023] [ssl:error] [pid 49634:tid 140039683155840] SSL Library Error: error:0688010A:asn1 encoding routines::nested asn1 error (Type=PKCS8_PRIV_KEY_INFO)
[Sun Oct 29 07:57:11.011757 2023] [ssl:emerg] [pid 49634:tid 140039683155840] AH02564: Failed to configure encrypted (?) private key saniday.test:443:0, check /etc/httpd/conf/server.key
Don’t use a password with your private key. If you want a password, don’t rely on the interactive input, it will fail.
If i add blank password:
Enter PEM pass phrase:
404751B1DC7F0000:error:14000065:UI routines:UI_set_result_ex:result too small:crypto/ui/ui_lib.c:888:You must type in 4 to 1024 characters
404751B1DC7F0000:error:1400006B:UI routines:UI_process:processing error:crypto/ui/ui_lib.c:548:while reading strings
404751B1DC7F0000:error:0480006D:PEM routines:PEM_def_callback:problems getting password:crypto/pem/pem_lib.c:62:
404751B1DC7F0000:error:07880109:common libcrypto routines:do_ui_passphrase:interrupted or cancelled:crypto/passphrase.c:184:
404751B1DC7F0000:error:1C80009F:Provider routines:p8info_to_encp8:unable to get passphrase:providers/implementations/encode_decode/encode_key2any.c:116:
I think the problem is the SSL certificate I generate which is wrong, can you confirm?
I’m trying with:
cd /etc/httpd/conf/ssl
sudo certtool --generate-privkey --outfile server.key
sudo certtool --generate-self-signed --load-privkey server.key --outfile server.crt
Apache starts with this certificate, but chrome alert that the certificate is invalid…
Of course is this certificate is not trusted, since it is not from a Certificate Authority that your Browser/OS trusts.
This is always the case with self-signed certificate. There are ways to trust such certificate, depending on your Browser and OS.
Advice for chrome?
Once you accepted the certificate and continue to visiting your site, chrome should remember that choice and be fine.
I’m testing a PWA (Progressive Web App), and I need a valid certificate to install it.
Settings → Privacy and Security → Security → Manage Device Certificates
LetsEncrypt might be a better choice for you if you only need a certificate for a limited time. All the information needed can be found on their site.
Try to import your certificate in the cert-manager of chrome and then mark it as trusted. After a restart it should be accepted without any complaints
