I created a QEMU Windows 10 virtual machine and installed StarCraft 2 to see if it is playable on Linux.
Unfortunately the FPS fluctuates between 0 and 1 on the lowest settings.
Is there a way to improve the performance to above 30 fps?
inxi -Fazy
~ >>> inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=e5832754-c602-46d5-9f50-e8776af08fe3 rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: TRX40 AORUS MASTER v: -CF
serial: <filter>
Mobo: Gigabyte model: TRX40 AORUS MASTER v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: F5j date: 09/07/2020
Topology: 32-Core (4-Die) model: AMD Ryzen Threadripper 3970X bits: 64
type: MT MCP MCM arch: Zen 2 family: 17 (23) model-id: 31 (49) stepping: N/A
microcode: 8301039 L2 cache: 16.0 MiB
bogomips: 473793
Speed: 2383 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2514 2: 2027 3: 2021 4: 2042 5: 2196 6: 2196 7: 2209 8: 2198 9: 1865
10: 2800 11: 1865 12: 1865 13: 2026 14: 2129 15: 2126 16: 2126 17: 4245
18: 2197 19: 2196 20: 2196 21: 2196 22: 4246 23: 2022 24: 2027 25: 2139
26: 2124 27: 2799 28: 1864 29: 1867 30: 1865 31: 2055 32: 3600 33: 2055
34: 2056 35: 2060 36: 2126 37: 2223 38: 2182 39: 2085 40: 2199 41: 2197
42: 2200 43: 2199 44: 1865 45: 2798 46: 3597 47: 1863 48: 1866 49: 2118
50: 2117 51: 2116 52: 4233 53: 2195 54: 2199 55: 2200 56: 2199 57: 2055
58: 4249 59: 2119 60: 2125 61: 2121 62: 2055 63: 2026 64: 2475
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 02:00.0
chip ID: 1002:67df
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.38.0
5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus ID: 02:00.1
chip ID: 1002:aaf0
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
bus ID: 22:00.4 chip ID: 1022:1487
Device-3: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 7-5:2 chip ID: 0414:a001
Device-4: Logitech Logitech BRIO type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 6-1:2
chip ID: 046d:085e serial: <filter>
Device-5: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-6:3 chip ID: 0414:a000
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k
port: c000 bus ID: 44:00.0 chip ID: 8086:1539
IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel port: c000 bus ID: 45:00.0
chip ID: 1d6a:11b1
IF: enp69s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: c000
bus ID: 46:00.0 chip ID: 8086:2723
IF: wlo2 state: down mac: <filter>
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
IF-ID-3: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
Local Storage: total: 953.87 GiB used: 114.55 GiB (12.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 512GB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 1B2QEXP7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 PRO 1TB size: 953.87 GiB
ID-1: / raw size: 953.57 GiB size: 937.60 GiB (98.33%)
used: 114.55 GiB (12.2%) fs: ext4 dev: /dev/nvme1n1p2
System Temperatures: cpu: 58.2 C mobo: N/A gpu: amdgpu temp: 34 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 932
Processes: 831 Uptime: 1h 12m Memory: 31.30 GiB used: 12.85 GiB (41.1%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: 1166 pacman: 1161
lib: 310 flatpak: 5 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.05
Thanks in advance.
