chomsky@manjaro ~ $ sudo dmesg -l emerg,alert,crit,err,warn
[sudo] password for chomsky:
[ 0.122687] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.406230] nvme nvme0: missing or invalid SUBNQN field.
[ 1.208997] usb: port power management may be unreliable
[ 2.191941] usb 1-10: device descriptor read/64, error -71
[ 2.215402] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.215451] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.421907] usb 1-10: device descriptor read/64, error -71
[ 2.600418] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x400000
[ 2.623284] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 2.623285] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 2.623286] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 2.623287] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 2.623287] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 2.623288] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 2.623288] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 2.623289] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 2.623290] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 2.623290] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 2.623291] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 2.623292] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 2.623292] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 2.623293] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 2.623293] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 2.623294] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 2.623295] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 2.775238] usb 1-10: device descriptor read/64, error -71
[ 2.907865] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 3.005240] usb 1-10: device descriptor read/64, error -71
[ 3.279034] snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[ 3.758705] usb 1-10: Device not responding to setup address.
[ 3.965395] usb 1-10: Device not responding to setup address.
[ 4.171909] usb 1-10: device not accepting address 6, error -71
[ 4.295330] usb 1-10: Device not responding to setup address.
[ 4.502266] usb 1-10: Device not responding to setup address.
[ 4.708604] usb 1-10: device not accepting address 7, error -71
[ 4.708655] usb usb1-port10: unable to enumerate USB device
[ 5.685654] kauditd_printk_skb: 131 callbacks suppressed
[ 9.637059] hid-generic 0005:046D:B342.0003: unknown main item tag 0x0
[ 13.014092] kauditd_printk_skb: 174 callbacks suppressed
[ 27.875959] kauditd_printk_skb: 7 callbacks suppressed
Everything seems to be working as it should but it doesn’t feel good. Thoughts?
