Anyone know why my GUFW won’t open?
[dullrobot@dullrobot ~]$ sudo pamac install ufw
[sudo] password for dullrobot:
Preparing...
Warning: ufw-0.36-5 is up to date -- skipping
Nothing to do.
[dullrobot@dullrobot ~]$ sudo systemctl enable ufw.service
[dullrobot@dullrobot ~]$ sudo ufw enable
Firewall is active and enabled on system startup
[dullrobot@dullrobot ~]$ sudo gufw
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.139: gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.139: gdk_keymap_get_modifier_mask: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gtk-CRITICAL **: 14:05:55.140: _gtk_replace_virtual_modifiers: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.140: gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.140: gdk_keymap_get_modifier_mask: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.141: gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(gufw.py:90836): Gtk-CRITICAL **: 14:05:55.141: _gtk_replace_virtual_modifiers: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.141: gdk_keymap_get_modifier_mask: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.142: gdk_keymap_get_modifier_mask: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gdk-CRITICAL **: 14:05:55.142: gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(gufw.py:90836): Gtk-CRITICAL **: 14:05:55.142: _gtk_replace_virtual_modifiers: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:90836): Gtk-CRITICAL **: 14:05:55.148: _gtk_style_provider_private_get_settings: assertion 'GTK_IS_STYLE_PROVIDER_PRIVATE (provider)' failed
/bin/gufw-pkexec: line 2: 90836 Segmentation fault (core dumped) python3 /usr/lib/python3.9/site-packages/gufw/gufw.py "$@"
