Hi!
Phone calls work on my PinePhone Pro with Manjaro ARM Phosh Beta 30, but the audio quality is problematic for others (too quiet and/or noisy).
I tried with the (nearly) free custom firmware for Pinephone’s modem and editing the file /usr/share/alsa/ucm2/PinePhonePro/VoiceCall.conf . Currently I changed the line cset "name='ADC Capture Volume' 47" and line cset "name='Mono ADC Capture Volume' 47". With a value of 84 it seems that the audio quality is better, but it gets worse again after a suspend.
If I install pipewire, the audio gets too noisy.
Any idea?
Thanks!
If you want to use pipewire install also pipewire-media-session and pipewire-pulse
Wireplumber does not work with calls (it does not route audio correctly)
You can fix the mic issue like this:
But afaik there is no fix for the suspend issue and that one forced me to switch back to OG PP. More info from the mic / suspend issue can be found here:
