Hi folks,
I was wondering if anyone knows when openssl is going to be updated on linux?
At the moment on manjaro we have:
openssl version
OpenSSL 1.1.1l 24 Aug 2021
For comparison on OSX:
openssl version
OpenSSL 3.0.0 7 sep 2021 (Library: OpenSSL 3.0.0 7 sep 2021)
On a similar note does anyone know why the -Qe flag doesn’t show openssl as installed on the system?
pacman -Qe |grep open
java-openjfx 16.u8-1
java8-openjfx 8.u202-3
jdk8-openjdk 8.u292-1
jre8-openjdk 8.u292-1
jre8-openjdk-headless 8.u292-1
libopenraw 0.3.0-1
mkinitcpio-openswap 0.1.0-3
networkmanager-openconnect 1.2.7dev+65+gca4187c-1
networkmanager-openvpn 1.8.14-1
openmpi 4.1.1-2
openresolv 3.12.0-1
openssh 8.7p1-2
Instead if we use Ss to search on upstream repo we see that openssl is already installed
pacman -Ss openssl
core/openssl 1.1.1.l-1 [installed]
The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
extra/pkcs11-helper 1.27.0-1 [installed]
A library that simplifies the interaction with PKCS11 providers for end-user applications using a simple API and
optional OpenSSL engine
extra/python-pyopenssl 20.0.1-1 [installed]
Python3 wrapper module around the OpenSSL library
extra/xmlsec 1.2.32-1 [installed]
