I set my options to dim after 20 minutes on battery, and to sleep after 35.
These changes will not save, the screen still dims after the default amount of time passes, I think 5 or 10 minutes.
Here is a picture of my settings:
Any ideas?
Any ideas?
I should add, it goes back to the Manjaro screen saver after like 5 minutes… I want it to stay active instead of doing that. Did I change the correct setting?
Make sure you arent keeping the session saved.
I unchecked that, but it had no effect, even after rebooting. Any ideas?
The setting that for the “Screen Locking” is different from the dim screen. Search in the application launcher for Screen Locking and then you can easily configure.
Thanks!!
