Now Network Manager the only one on. but still no connection.
Greetings. Here is what I got from your commands.
ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.62 netmask 255.255.255.0 broadcast 192.168.1.255
ether 00:90:21:90:20:3b txqueuelen 1000 (Ethernet)
RX packets 12860 bytes 18948209 (18.0 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5765 bytes 425857 (415.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16 memory 0x55200000-55220000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:90:21:90:20:3b brd ff:ff:ff:ff:ff:ff
altname enp0s31f6
inet 192.168.1.62/24 brd 192.168.1.255 scope global dynamic noprefixroute eno1
valid_lft 86042sec preferred_lft 86042sec
inet 192.168.1.87/24 brd 192.168.1.255 scope global secondary dynamic noprefixroute eno1
valid_lft 86290sec preferred_lft 86290sec
journalctl -f
Journal file /var/log/journal/ad7fac0519294845814790bba46f9368/user-1000@0005f344116587f6-310306309df4b1ca.journal~ uses an unsupported feature, ignoring file.
Use SYSTEMD_LOG_LEVEL=debug journalctl --file=/var/log/journal/ad7fac0519294845814790bba46f9368/user-1000@0005f344116587f6-310306309df4b1ca.journal~ to see the details.
Jan 27 14:50:52 winter touchegg.desktop[1823]: Error connecting to TouchГ©gg daemon: Could not connect: Connection refused
Jan 27 14:50:52 winter touchegg.desktop[1823]: Reconnecting in 5 seconds...
Jan 27 14:50:57 winter touchegg.desktop[1823]: Error connecting to TouchГ©gg daemon: Could not connect: Connection refused
Jan 27 14:50:57 winter touchegg.desktop[1823]: Reconnecting in 5 seconds...
Jan 27 14:51:02 winter touchegg.desktop[1823]: Error connecting to TouchГ©gg daemon: Could not connect: Connection refused
Jan 27 14:51:02 winter touchegg.desktop[1823]: Reconnecting in 5 seconds...
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
I can’t see through this.
You have no wifi, but just an ethernet connection to your router - but somehow you have got two IP’s
altname enp0s31f6
A connection via ethernet is usually very simple.
I have no idea what this here is.
Your log contains nothing about the network connection - messages are about some multitouch gesture program which doesn’t seem to work.
Ah, didn’t notice it. The errors you get with keys and database also might show as if there was no Internet, although it was available. I had this kind of error too. That is why I assumed the connection is not a real issue here. Also, the title suggested there is an issue with the update, not with the connection.
I cannot possibly thank you enough.
