I’m also having random freezes after the latest update. I ran the full system update last Thursday March 7th, and then my computer started getting freezed randomly while playing videos in the browser. It is like the UI starts getting slow quickly until every mouse movement takes like 10 seconds and no more clicks or keyboard input is detected.
I initially thought that the problem was caused by Firefox, so I downgraded it to version 135.0.1-1, and that stopped the freezes for a couple of days, but today it happened twice again, in one occassion without having Firefox running.
This started happening since the last kernel update.
This is my inxi output:
inxi --filter --verbosity=8
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
cryptdevice=UUID=1825ad3d-6c4e-4e7e-bf5d-129dcdfc2f97:cryptlvm
root=/dev/LinuxVolGroup/root rw apparmor=1 security=apparmor
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20QKS0DN03 v: ThinkPad T495s
Mobo: LENOVO model: 20QKS0DN03 v: SDK0J40697 WIN
serial: <superuser required>
part-nu: LENOVO_MT_20QK_BU_Think_FM_ThinkPad T495s
uuid: <superuser required> UEFI: LENOVO v: R13ET52W(1.26 )
date: 02/15/2022
ID-1: BAT0 charge: 38.8 Wh (84.2%) condition: 46.1/57.0 Wh (80.9%)
volts: 12.4 min: 11.5 model: Celxpert 5B10W138 type: Li-poly
serial: <filter> status: not charging cycles: 757
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
System RAM: total: 16 GiB available: 13.56 GiB used: 4.8 GiB (35.4%)
(unregistered) size: 8 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATS1G64HZ-2G6E1 serial: N/A
Info: model: AMD Ryzen 7 PRO 3700U w/ Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 36748
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2
bus-ID: 06:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 76.0 C
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2.1:4 chip-ID: 04f2:b681
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: HP 24mh
serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green: x: 0.322 y: 0.612
blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 mapped: eDP pos: left model: AU Optronics 0x323d
built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
chroma: red: x: 0.569 y: 0.337 green: x: 0.349 y: 0.569 blue: x: 0.157
y: 0.122 white: x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 10 Graphics
(radeonsi raven LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2
chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Message: Unable to run lvs. Root privileges required.
Device-1: cryptlvm maj-min: 254:0 type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: nvme0n1p1 maj-min: 259:1 size: 1.82 TiB
Local Storage: total: 1.82 TiB used: 654.65 GiB (35.1%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731130WD temp: 43.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 652.41 GiB (36.3%)
fs: ext4 dev: /dev/dm-2 maj-min: 254:2 mapped: LinuxVolGroup-root label: N/A
uuid: N/A
ID-2: /boot raw-size: 2 GiB size: 2 GiB (99.80%) used: 219.4 MiB (10.7%)
fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A uuid: 2641-D7C8
ID-3: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 264D-96DB
ID-1: swap-1 type: partition size: 32 GiB used: 2.03 GiB (6.3%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: LinuxVolGroup-swap
label: N/A uuid: ac91426b-9fb8-4c02-bff5-99b54c8748f5
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-3.1:3 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 4-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 4-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-6: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 4-2.1:4 info: Chicony ThinkPad T490 Webcam type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02
serial: <filter>
Device-2: 4-2.3:5 info: Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
chip-ID: 2386:4337 class-ID: 0300
Device-3: 4-2.4:6 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Hub-7: 5-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 76.0 C mobo: N/A gpu: amdgpu temp: 75.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1351 libs: 389 tools: pamac pm: flatpak pkgs: 0
1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
5: https://mirror.easyname.at/manjaro/stable/$repo/$arch
6: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
8: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 337
1: cpu: 6.7% command: firefox pid: 3049 mem: 547.0 MiB (3.9%)
2: cpu: 5.1% command: Xorg pid: 1235 mem: 166.4 MiB (1.1%)
3: cpu: 5.1% command: chromium pid: 5563 mem: 558.7 MiB (4.0%)
4: cpu: 2.9% command: firefox pid: 3234 mem: 443.7 MiB (3.1%)
5: cpu: 1.9% command: [kworker/u32:12-comp_1.1.1] pid: 107900
mem: 0.00 MiB (0.0%)
Memory top: 5 of 337
1: mem: 731.8 MiB (5.2%) command: firefox pid: 4172 cpu: 1.3%
2: mem: 558.7 MiB (4.0%) command: chromium pid: 5563 cpu: 5.1%
3: mem: 547.0 MiB (3.9%) command: firefox pid: 3049 cpu: 6.7%
4: mem: 443.7 MiB (3.1%) command: firefox pid: 3234 cpu: 2.9%
5: mem: 369.7 MiB (2.6%) command: firefox pid: 46430 cpu: 0.9%
Processes: 337 Power: uptime: 1h 50m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.4 GiB services: upowerd,xfce4-power-manager
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
This is my cpupower output:
analyzing CPU 7:
CPUs which run at the same hardware frequency: 7
CPUs which need to have their frequency coordinated by software: 7
maximum transition latency: Cannot determine or is not supported.
hardware limits: 1.40 GHz - 2.30 GHz
available frequency steps: 2.30 GHz, 1.70 GHz, 1.40 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 1.40 GHz and 2.30 GHz.
The governor "schedutil" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 1.39 GHz (asserted by call to kernel)
boost state support:
Supported: no
Active: no
This is the journal output from the last crash (journalctl --priority=warning…crit --no-pager --boot=-1), from when the system started slowing down until I forced shutdown by pressing the power button:
Mar 11 14:08:15 my-computer-name kernel: clocksource: Long readout interval, skipping watchdog check: cs_nsec: 1696239575 wd_nsec: 1696245961
Mar 11 14:08:23 my-computer-name kernel: clocksource: Long readout interval, skipping watchdog check: cs_nsec: 4508594244 wd_nsec: 4508611568
Mar 11 14:08:50 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:08:50 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:08:50 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:08:30 my-computer-name rtkit-daemon[2230]: The canary thread is apparently starving. Taking action.
Mar 11 14:08:55 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:08:55 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:08:55 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:08:59 my-computer-name kernel: [drm] Fence fallback timer expired on ring sdma0
Mar 11 14:09:05 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:08 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:08 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:11 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:11 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:11 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:21 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:21 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:21 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:29 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:29 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:29 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:34 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:34 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:34 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:40 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:40 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:40 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:09:56 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:09:56 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:09:56 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:10:00 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:10:00 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:10:00 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:10:15 my-computer-name kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20240827/evregion-301)
Mar 11 14:10:15 my-computer-name kernel: ACPI Error: Timeout from EC hardware or EC device driver (20240827/evregion-311)
Mar 11 14:10:15 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.GBST due to previous error (AE_TIME) (20240827/psparse-529)
Mar 11 14:10:15 my-computer-name kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.BAT0._BST due to previous error (AE_TIME) (20240827/psparse-529)
