Since today’s update (starting point is 21.1 rc) I have these extremely annoying folder icons in the Dolphin sidebar:
Is this a bug or a feature?
If it is to be a feature: Shitty idea!
Sounds like it’s from Dolphin 21.08, so sounds like a feature.
I am indeed considering to have a look at Xfce again …
I don’t speak German so don’t see anything too much…
we can add icon by drag&drop and we can hide icons at left by right click - or remove
It is not important to understand German in the screenshot. It is all the folders from the home directory that are now displayed in this way. I know I can hide them, but that’s not the point.
without translation, don’t know what you have too
i not understand , view download, video, … is normal
if you have too much, is you ? we can drag&drop directories in this left place … but we can also remove it
not me with last version …
I do NOT want to remove them, I just don’t like those stupid symbols. Before they were Breaze icons, they fit much better visually in this bar. But anyway …
EDIT: ok you want only change theme
He doesn’t want to remove the icons. He wants the old icons back…
You can right click on those entries and go to Edit… and then set the icons you want for them
OK, but unfortunately this does not work with paper grain. Thus I have then also no more uniform picture
But nevertheless thanks.
No problem. I guess Plasma developers are setting things towards symbolic icons. We can also change the icons size on that side panel, but 22 is a bit small and 32 is too large and with 16 only symbolic will be shown …
