I have a fresh installation of Anh-Linh 25.1-pre1 and installed printers and scanner with success. The scanner is working with gscan2pdf correct. Now I tried to install the Gimp-plugin.
sudo pacman -S xsane xsane-gimp
This didn’t show the scanner-connection in Gimp "File → Acquire → …” and there were errors. After I had a look at AUR, I uninstalled the 2 packages and installed:
xsane-git xsane-gimp-git cfitsio
Now the Plugin works and I can scan inside Gimp. But with errors (starting via commandline):
gimp
set device 'Wayland Pointer' to mode: disabled
(xsane:158305): Gdk-CRITICAL **: 14:38:06.664: gdk_monitor_get_workarea: assertion 'GDK_IS_MONITOR (monitor)' failed
(xsane:158305): Gtk-CRITICAL **: 14:38:06.665: gtk_widget_set_size_request: assertion 'width >= -1' failed
[xsane] ERROR: xsane-startimage not found. Looks like xsane is not installed correct.
[xsane] Failed to get preview image memory.
It is still possible to scan, because the errors disappear. Still the message “force quit or wait“ appears.
Any idea? Is it on missing X11?
Here my inxi:
inxi -zv8
Kernel: 6.18.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=36bfd2b8-5279-4b34-982d-616c2cd7e1de rw quiet splash apparmor=1
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: Z97-A-USB31 v: Rev 1.xx serial: <superuser required>
part-nu: All uuid: <superuser required> Firmware: UEFI-[Legacy]
vendor: American Megatrends v: 3503 date: 04/18/2018
System RAM: total: 16 GiB available: 15.55 GiB used: 5.02 GiB (32.3%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: DIMM_A1 type: DDR3 detail: synchronous size: 8 GiB speed:
spec: 1600 MT/s actual: 1333 MT/s volts: curr: 2 min: 2 max: 2 width (bits):
data: 64 total: 64 manufacturer: Chips and Technologies
part-no: F3-1600C9-8GAR serial: N/A
Device-2: DIMM_A2 type: DDR3 detail: synchronous size: 8 GiB speed:
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: no module installed
Info: model: Intel Xeon E3-1231 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 54371
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: Sapphire driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2,
DVI-D-1, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 46.0 C
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-2 model: Acer S273HL serial: <filter> built: 2011
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
x: 0.290 y: 0.612 blue: x: 0.145 y: 0.071 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 1920x1080, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 ACO DRM 3.64 6.18.1-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: Sapphire driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
class-ID: 0403
Device-3: VIA VT1720/24 [Envy24PT/HT] PCI Multi-Channel Audio
driver: snd_ice1724 v: kernel bus-ID: 07:00.0 chip-ID: 1412:1724
class-ID: 0401
API: ALSA v: k6.18.1-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
Local Storage: total: 10.92 TiB used: 1.85 TiB (17.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000DM004-2U9188
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD30EZRX-00DC0B0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.03
dev-links: cdrom
Optical-2: /dev/sr1 vendor: HL-DT-ST model: DVD-RAM GH22LP20 rev: 2.00
dev-links: N/A
ID-1: / raw-size: 784.54 GiB size: 771.16 GiB (98.29%)
used: 26.28 GiB (3.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 36bfd2b8-5279-4b34-982d-616c2cd7e1de
ID-2: /home raw-size: 7.28 TiB size: 7.16 TiB (98.42%)
used: 1.83 TiB (25.5%) fs: ext4 dev: /dev/sdb maj-min: 8:16 label: home
uuid: f107e863-69ce-4197-88d6-4cf06311bfa1
ID-3: /media/fritznas raw-size: N/A size: 117.18 GiB
used: 404.7 MiB (0.3%) fs: cifs dev: /dev/FA
ID-1: swap-1 type: partition size: 20.02 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: e1682136-484a-4a62-bac0-4faa41ed7348
ID-1: /dev/sda1 maj-min: 8:1 size: 579 MiB fs: ntfs label: N/A
uuid: 9A608D3A608D1DDF
ID-2: /dev/sda2 maj-min: 8:2 size: 126.39 GiB fs: ntfs label: WIN10PRO
uuid: DE6A888D6A88645D
ID-3: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdc1 maj-min: 8:33 size: 1.37 TiB fs: ntfs label: Bild
uuid: 080A694D0A693938
ID-5: /dev/sdc2 maj-min: 8:34 size: 1.36 TiB fs: ntfs label: Musik
uuid: 54226F67226F4CD4
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-4:2 info: CHERRY KC 6000 Slim Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:0113 class-ID: 0300
Device-2: 1-6:3 info: JMicron / USA JM20337 Hi-Speed USB to SATA & PATA
Combo Bridge type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 152d:2338 class-ID: 0806 serial: <filter>
Device-3: 1-7:4 info: Genesys Logic Multislot Card Reader/Writer
chip-ID: 05e3:0716 class-ID: 0806 serial: <filter>
Device-4: 1-12:5 info: MosArt Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4102 class-ID: 0301
Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-3: 2-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 8087:8009 class-ID: 0900
Hub-4: 3-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1555
Packages: 1508 pm: dpkg pkgs: 6 pm: pacman pkgs: 1488 libs: 379
tools: gnome-software,pamac pm: flatpak pkgs: 14
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
3: https://mirror.easyname.at/manjaro/stable/$repo/$arch
4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
5: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
6: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
7: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
8: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
Processes:
CPU top: 5 of 383
1: cpu: 3.5% command: gnome-shell pid: 2195 mem: 341.5 MiB (2.1%)
2: cpu: 2.0% command: C:\windows\system32\winedevice.exe pid: 3554
mem: 36.4 MiB (0.2%)
3: cpu: 1.9% command: gnome-text-editor pid: 160602 mem: 301.0 MiB (1.8%)
4: cpu: 1.3% command: brave pid: 7603 mem: 266.5 MiB (1.6%)
5: cpu: 1.2% command: brave pid: 7474 mem: 440.4 MiB (2.7%)
Memory top: 5 of 383
1: mem: 1315.6 MiB (8.2%) command: pamac-manager pid: 21625 cpu: 0.4%
2: mem: 566.7 MiB (3.5%) command: Telegram pid: 19913 cpu: 0.1%
3: mem: 440.4 MiB (2.7%) command: brave pid: 7474 cpu: 1.2%
4: mem: 341.5 MiB (2.1%) command: gnome-shell pid: 2195 cpu: 3.5%
5: mem: 301.0 MiB (1.8%) command: gnome-text-editor pid: 160602 cpu: 1.9%
Processes: 383 Power: uptime: 1h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.8 running-in: kgx
inxi: 3.3.40
