Android Studio is slowing my system
hallo,
recently i’ve been forced to use android studio for some uni assignments, but it has a really poor perfomance; i dont think my laptop is that bad, but sometimes this program completely freezes my laptop for several minutes and it only makes me angrier and angrier;
therefore, i have 2 questions:
  • when the screen freezes, the only way that i know to recover my system is rebooting it; is there any other faster way? like accessing the task manager or something like that (taking in count that my laptop is useless, completely freezed in those moments)
  • i have the android studio aur package, is there an alternative? its such a shame because w flutter you can use vscode or whatever you want, but thats way more difficult w native app development
thanks in advance
pd: im running xfce and i tried w different kernels, but they dont seem to be the problem
Howdy!
May try the following!
Have a wonderful day!
Jetbrains applications need to watch many files and default for max_user_watches is very low.
Add a file in /etc/sysctl.d containing
fs.inotify.max_user_watches = 524288
then reload
sysctl -p --system
Then restart your IDE
Reference: https://confluence.jetbrains.com/display/IDEADEV/Inotify+Watches+Limit
A great addition to the above setting is to build and install watchman-bin from AUR
I don’t know if it is faster - but definitely safer.
Download the package from developer.android.com - and unpack it in a tools folder in your home. The applications are completely self contained - only requires a recent JDK
thaankiu, i hope astudio doesnt freeze the service as well :wink: i’ll give it a try
amazing answer as well, many thanks!
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
