Hi,
I installed kvm. But android studio reports error / dev / kvm not found.
I went to the /dev directory and there really wasn’t kvm. But I found kvm in /sys/ module. How can this be fixed?
Thanks for any help.
Gorry
Hi,
Gorry
Do you have virtualization enabled in your bios?
yes I have. but i think the problem is that android studio doesn’t know that kvm is installed in / sys
It isn’t. /dev/kvm
is a device special file. The contents of /sys
are not actual files, but rather a virtual filesystem through which the kernel exports information about the hardware to userspace, so that userland software can make use of that information.
Anyway, /dev/kvm
should exist on your system.
[nx-74205:/dev/pts/3][/home/aragorn]
[20:04:00][aragorn] > ls -l /dev/kvm
crw-rw-rw- 1 root kvm 10, 232 Oct 21 07:09 /dev/kvm
What kernel are you running?
mhwd-kernel -li
show this:
Currently running: 5.13.19-2-MANJARO (linux513)
* linux513
5.13 is EOL. Install 5.14 or one of the LTS kernels.
I don’t have /dev/kvm on my system either, but I can see that it’s built as a module in the kernel config, so maybe you just need to sudo modprobe kvm
or something similar to get it?
Ok, i have installed linux514
mhwd-kernel -li
show me this:
5.14.10-1-MANJARO (linux514)
* linux514
Problem solved.
I’m just an idiot. I had off svd
