I don’t really have any other way of explaining this but it doesn’t seem possible to press certain buttons inside Android Studio’s settings menu. For example the cog next to selecting keymap is not functional. Therefore I am unable to create my own keymap and therefore unable to use it at the moment.
I can provide further details if necessary I just wasn’t sure where to start with this.
Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=f5ac1938-c633-4152-b1f6-49e25fcd7d36 rw quiet apparmor=1
Desktop: i3 4.18.2 info: polybar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <filter> UEFI: American Megatrends v: B.40 date: 11/07/2019
RAM: total: 15.65 GiB used: 2.46 GiB (15.7%)
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 3072 KiB bogomips: 86437
Speed: 3596 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3599 2: 2048 3: 1867 4: 2799 5: 2054 6: 1867 7: 1862 8: 2801 9: 3594
10: 2055 11: 2057 12: 1863
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ZOTAC driver: nvidia
v: 440.100 alternate: nouveau,nvidia_drm bus ID: 29:00.0 chip ID: 10de:2187
Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.6x13.5")
s-diag: 872mm (34.3")
Monitor-1: DP-0 res: 3440x1440 hz: 60 dpi: 109 size: 800x335mm (31.5x13.2")
diag: 867mm (34.1")
OpenGL: renderer: GeForce GTX 1650 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 29:00.1 chip ID: 10de:1aeb
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2b:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.4.67-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 25:00.0
chip ID: 10ec:8168
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 103.02 GiB (8.8%)
ID-1: /dev/sda vendor: Western Digital model: WDS250G2B0A size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 90WD scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST31000524AS size: 931.51 GiB
rotation: 7200 rpm serial: <filter> rev: JC66 scheme: GPT
ID-1: / raw size: 58.73 GiB size: 57.55 GiB (98.00%) used: 14.01 GiB (24.3%)
fs: ext4 dev: /dev/sda2 label: N/A
uuid: f5ac1938-c633-4152-b1f6-49e25fcd7d36
ID-2: /boot/efi raw size: 500.0 MiB size: 499.0 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: D84E-DC8B
ID-3: /home raw size: 463.89 GiB size: 455.61 GiB (98.22%)
used: 89.01 GiB (19.5%) fs: ext4 dev: /dev/sdb2 label: N/A
uuid: 38277f1a-c0c4-4519-a0d3-fbf4a6f9b9f6
ID-1: /dev/sdb1 size: 467.62 GiB fs: ext4 label: N/A
uuid: 30f22d9a-af6d-4f31-a285-d78cb1fbd6ba
Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 5-1:2 info: Lenovo USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 17ef:602e
Device-2: 5-2:3 info: Cypress type: Keyboard,Mouse
chip ID: 04b4:6001
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 49.5 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 289 Uptime: 3h 16m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1130 lib: 314 Shell: Zsh v: 5.8 running in: termite
inxi: 3.1.05
