Android Studio 2023 2.1 Patch 2 crashed System
Hello, my system is actually running stably. However, a new event has occurred. I am working on an app in the Android Studio and while completing the code the system hangs and I am logged out afterwards and the Android Studio is gone. The session is not saved. The log files show a dump. I am working with a stable system without unstable sources.
Apr 30 08:05:04 thinkpad systemd-coredump[313506]: [🡕] Process 1288 (Xorg) of user 0 dumped core.
                                                   Stack trace of thread 1288:
                                                   #0  0x00007ba161d1932c n/a (libc.so.6 + 0x9132c)
                                                   #1  0x00007ba161cc86c8 raise (libc.so.6 + 0x406c8)
                                                   #2  0x00007ba161cb04b8 abort (libc.so.6 + 0x284b8)
                                                   #3  0x00006380bc208b00 OsAbort (Xorg + 0x159b00)
                                                   #4  0x00006380bc208e3b FatalError (Xorg + 0x159e3b)
                                                   #5  0x00006380bc200d46 n/a (Xorg + 0x151d46)
                                                   #6  0x00007ba161cc8770 n/a (libc.so.6 + 0x40770)
                                                   #7  0x00007ba161d1932c n/a (libc.so.6 + 0x9132c)
                                                   #8  0x00007ba161cc86c8 raise (libc.so.6 + 0x406c8)
                                                   #9  0x00007ba161cb04b8 abort (libc.so.6 + 0x284b8)
                                                   #10 0x00007ba161cb1395 n/a (libc.so.6 + 0x29395)
                                                   #11 0x00007ba161d232a7 n/a (libc.so.6 + 0x9b2a7)
                                                   #12 0x00007ba161d27a4c malloc (libc.so.6 + 0x9fa4c)
                                                   #13 0x00006380bc189800 n/a (Xorg + 0xda800)
                                                   #14 0x00006380bc0ee04e n/a (Xorg + 0x3f04e)
                                                   #15 0x00007ba161cb1cd0 n/a (libc.so.6 + 0x29cd0)
                                                   #16 0x00007ba161cb1d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                   #17 0x00006380bc0ee605 _start (Xorg + 0x3f605)
                                                   Stack trace of thread 1452:
                                                   #0  0x00007ba161d13ebe n/a (libc.so.6 + 0x8bebe)
                                                   #1  0x00007ba161d16750 pthread_cond_wait (libc.so.6 + 0x8e750)
                                                   #2  0x00007ba15eb021fc n/a (iris_dri.so + 0x1021fc)
                                                   #3  0x00007ba15eb18f0c n/a (iris_dri.so + 0x118f0c)
                                                   #4  0x00007ba161d1755a n/a (libc.so.6 + 0x8f55a)
                                                   #5  0x00007ba161d94a3c n/a (libc.so.6 + 0x10ca3c)
                                                   Stack trace of thread 1456:
                                                   Stack trace of thread 1457:
                                                   Stack trace of thread 1454:
                                                   Stack trace of thread 1453:
                                                   Stack trace of thread 1455:
                                                   Stack trace of thread 1460:
                                                   #0  0x00007ba161d14110 n/a (libc.so.6 + 0x8c110)
                                                   #1  0x00007ba161d1aa0a pthread_mutex_lock (libc.so.6 + 0x92a0a)
                                                   #2  0x00006380bc1fae75 n/a (Xorg + 0x14be75)
                                                   #3  0x00006380bc1fb8e2 n/a (Xorg + 0x14c8e2)
                                                   #4  0x00006380bc1ff6e9 n/a (Xorg + 0x1506e9)
                                                   #5  0x00007ba161d1755a n/a (libc.so.6 + 0x8f55a)
                                                   #6  0x00007ba161d94a3c n/a (libc.so.6 + 0x10ca3c)
Apr 30 08:05:04 thinkpad systemd[1]: systemd-coredump@0-313505-0.service: Deactivated successfully.
My sudo Xorg -version is
 sudo Xorg -version
X.Org X Server 1.21.1.12
Current Operating System: Linux thinkpad 6.7.12-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Apr  4 04:31:03 UTC 2024 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64 root=UUID=1e64abfe-feac-4993-a6a0-0e588a8d89b1 rw apparmor=1 security=apparmor resume=UUID=1869b52e-8ade-41e1-8f7c-80407d505afa udev.log_priority=3
Current version of pixman: 0.43.4
	Before reporting problems, check http://wiki.x.org
My system is stable
pacman-mirrors -aG
stable
here ar my systeminfos via inxi -Sa
inxi -Sa
  Host: thinkpad Kernel: 6.7.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 13.2.1 clocksource: tsc avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
I solved the problem by installing wayland and Gnome. When the update of Xorg is there, I go back to xfce and Xorg
Wayland is ‘the future’ - I imagine it would probably be beneficial to prioritize Wayland functionality over X11, as the ongoing focus is on Wayland.
(opinionated comment).
Cheers.
