I am new into compiling my own ROMs (AOSP and LineageOS) for my mobile devices. I am getting some unexpected errors while attempting to compile at home. (I’m on the road now and going to try it with my laptop while away for a few days)
I am following this guide to build lineageos after successfully building AOSP and installing it on my device. Build for shamu | LineageOS Wiki
To build LineageOS, you’ll need:
* `bc bison build-essential ccache curl flex g++-multilib gcc-multilib git gnupg gperf imagemagick
lib32ncurses5-dev lib32readline-dev lib32z1-dev liblz4-tool libncurses5 libncurses5-dev
libsdl1.2-dev libssl-dev libxml2 libxml2-utils lzop pngcrush rsync
schedtool squashfs-tools xsltproc
zip zlib1g-dev`
For Ubuntu versions older than 20.04 (focal), install also:
* `libwxgtk3.0-dev`
While for Ubuntu versions older than 16.04 (xenial), install:
* `libwxgtk2.8-dev`
#### Java
Different versions of LineageOS require different JDK (Java Development Kit) versions.
* LineageOS 18.1: OpenJDK 11 (included in source download)
* LineageOS 16.0-17.1: OpenJDK 1.9 (included in source download)
* LineageOS 14.1-15.1: OpenJDK 1.8 (install `openjdk-8-jdk`)
* LineageOS 11.0-13.0: OpenJDK 1.7 (install `openjdk-7-jdk`)*
It appears I’m missing some dependencies. Is there a package that I can install that will give me everything I need to build Android ROMs and Kernels? I also noticed that libcurses5 appears maybe broken or not where “brunch” expects to find it?
I am going to try and build manjaro 64 for my pinephone sometime in the upcoming weeks too, does there exist a package to obtain all the prerequisites?
I’d like to point out I know there exists the meta packages in the AUR - but the Manjaro documentation Arch User Repository - Manjaro does not support this method so I thought I’d check to see if there’s another method that respects this.
with regards to the AUR - i’m aware, which is why Im just simply trying to avoid AUR where possible to avoid having to deal with broken packages… while i use manjaro mostly and with more frequency, for gaming and my hobbies, i originally came from debian-stable and cento-os hardend previously. Gaming and mobile phreaking seems to like the bleeding edge a lot more, so i get scared when i see updates and usually wait almost a week before updating now cause otherwise the system sometimes doesn’t work as expected, which is why as a rule im trying to stick with the manjaro repos rather than the AUR.
My only complaint with the manjaro pinephone doesnt support even low end luks encryption yet. I was going to try mixing the mobian build script with the manjaro gnome build for the pinephone. I need element messenger and luks to use it as a daily driver.
