Hi.
Previously, I used Garuda linux and all the emulators from Android studio worked fine in that OS.
However, in Manjaro whichever emulator I try from android studio it performs extremely slow that I can’t even boot the device up.
As far as I know that my CPU n chipset fully supports virtualization and it is also active.
Can you please tell me how can I improve the performance of android emulator that comes with android studio?
Thanks.
It is a configuration issue as there likely is a requirement for your user to be member of certain groups related to android.
cat /etc/group
Then locate the android related groups adb comes to mind - but there may be others.
Yes, there’s adb group there. What should I do with it to increase my emulator performance? Can you please elaborate?
Thanks.
