Android emulator (Android Studio) stopped working on xfce
With the (two) latest updates of Android Studio the android emulator stopped working. I belive it is a xfce problem, but I’ve not installed a Wayland (plasma) version to test that. I’ve not seen that error reported, but it is from several days ago (I was working on Flutter).
Additional information (the error): The error happens either in Android Studio, Visual Studio Code and also on line-command, just the same error:
$ emulator -list-avds
Medium_Phone_API_34
$ emulator -avd Medium_Phone_API_34
INFO         | Android emulator version 35.4.9.0 (build_id 13025442) (CL:N/A)
INFO         | Graphics backend: gfxstream
INFO         | Found systemPath /opt/android-sdk/system-images/android-34/google_apis_playstore/x86_64/
INFO         | Checking system compatibility:
INFO         |   Checking: hasSufficientDiskSpace
INFO         |      Ok: Disk space requirements to run avd: `Medium_Phone_API_34` are met
INFO         |   Checking: hasSufficientHwGpu
INFO         |      Ok: Hardware GPU requirements to run avd: `Medium_Phone_API_34` are passed
INFO         |   Checking: hasSufficientSystem
INFO         |      Ok: System requirements to run avd: `Medium_Phone_API_34` are met
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_btn_xr_environment_living_room_day_clicked() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_btn_xr_environment_living_room_night_clicked() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_new_posture_requested(int) (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_dismiss_posture_selection_dialog() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_new_resizable_requested(PresetEmulatorSizeType) (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_dismiss_resizable_dialog() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_xr_environment_mode_changed(int) (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_dismiss_xr_environment_mode_dialog() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_xr_input_mode_changed(int) (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_dismiss_xr_input_mode_dialog() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_sleep_timer_done() (:0, )
INFO         | Warning: QMetaObject::connectSlotsByName: No matching signal for on_unfold_timer_done() (:0, )
INFO         | Storing crashdata in: /tmp/android-cesc/emu-crash-35.4.9.db, detection is enabled for process: 19403
INFO         | Guest Driver: Auto (ext controls)
WARNING      | API level 34 requires OpenGL ES 3.0+, attempting to turn on OpenGL ES 3.0/3.1
library_mode host gpu mode host
INFO         | emuglConfig_get_vulkan_hardware_gpu_support_info: Found physical GPU 'Intel(R) UHD Graphics 620 (KBL GT2)', type: VK_PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU, apiVersion: 1.4.305, driverVersion: 25.0.2
INFO         | Enabled VulkanAllocateHostMemory feature for gpu vendor Intel(R) UHD Graphics 620 (KBL GT2) on Linux
INFO         | GPU device local memory = 5871MB
INFO         | Initializing hardware OpenGLES emulation support
I0409 20:48:55.992460   19403 opengles.cpp:285] android_startOpenglesRenderer: gpu info
I0409 20:48:55.992491   19403 opengles.cpp:286]
INFO         | Raised nofile soft limit to 4096.
INFO         | HealthMonitor disabled.
INFO         | SharedLibrary::open for [libvulkan.so]
INFO         | SharedLibrary::open for [libvulkan.so]: not found in map, open for the first time
INFO         | SharedLibrary::open for [libvulkan.so] (posix): begin
INFO         | SharedLibrary::open for [libvulkan.so] (posix,linux): call dlopen on [libvulkan.so]
INFO         | Added library: libvulkan.so
INFO         | Selecting Vulkan device: Intel(R) UHD Graphics 620 (KBL GT2), Version: 1.4.305
INFO         | Supports id properties, got a vulkan device UUID
INFO         | SharedLibrary::open for [libX11]
INFO         | SharedLibrary::open for [libX11]: not found in map, open for the first time
INFO         | SharedLibrary::open for [libX11] (posix): begin
INFO         | SharedLibrary::open for [libX11] (posix,linux): call dlopen on [libX11.so]
INFO         | SharedLibrary::open for [libGL.so.1]
INFO         | SharedLibrary::open for [libGL.so.1]: not found in map, open for the first time
INFO         | SharedLibrary::open for [libGL.so.1] (posix): begin
INFO         | SharedLibrary::open for [libGL.so.1] (posix,linux): call dlopen on [libGL.so.1]
MESA: error: dri3_alloc_render_buffer:1634 xcb_dri3_pixmap_from_buffer[s] failed
MESA: error: X error: 11
Violació de segment (s'ha bolcat la memòria)
last error translated: Segment violation (memory dumped)
Additional information (my system):
Linux 6.12.20-2-MANJARO #1 SMP PREEMPT_DYNAMIC Mon, 24 Mar 2025 06:33:36 +0000 x86_64 GNU/Linux
Currently running: 6.12.20-2-MANJARO (linux612)
$ inxi -zv8
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: hpet,acpi_pm parameters: ro
    root=UUID=886f64f9-d824-41d1-80a2-d374c3d36147
    initrd=boot\initramfs-6.12-x86_64.img
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker,xfce4-screensaver vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 81BG v: Lenovo ideapad 320-15IKB
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15IKB
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
    part-nu: LENOVO_MT_81BG_BU_idea_FM_ideapad 320-15IKB
    uuid: <superuser required> UEFI: LENOVO v: 6JCN33WW date: 06/30/2020
  ID-1: BAT0 charge: 18.1 Wh (94.8%) condition: 19.1/30.0 Wh (63.6%)
    volts: 7.9 min: 7.4 model: LGC L16L2PB2 type: Li-poly serial: <filter>
    status: not charging
  System RAM: total: 12 GiB available: 11.47 GiB used: 8.94 GiB (77.9%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 2133 MT/s volts: curr: 1 min: 2 max: 2
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A5244CB0-CRC serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 min: 2 max: 2
    width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-2133C15-8GRS serial: N/A
  Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xD6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 700 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700
    8: 700 bogomips: 28808
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
    hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5917 class-ID: 0300
  Device-2: Syntek EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 174f:116a
  Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 870x286mm (34.25x11.26")
    s-diag: 916mm (36.06")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: left model: LG (GoldStar) MP59G
    serial: <filter> built: 2015 res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.306
    y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: eDP-1 pos: primary,right model: ChiMei InnoLux 0x15db
    built: 2015 res: mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
    chroma: red: x: 0.569 y: 0.333 green: x: 0.329 y: 0.580 blue: x: 0.161
    y: 0.145 white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) device-ID: 8086:5917 memory: 5.6 GiB unified: yes
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl,pavucontrol
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c821
    class-ID: 0280
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:c024
  Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 4.2 lmp-v: 8
    status: discoverable: no pairing: no
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.03 TiB used: 259.36 GiB (24.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G32TNF-N3A0A
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
    tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
  ID-1: / raw-size: 223.24 GiB size: 219.18 GiB (98.18%)
    used: 90.41 GiB (41.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: MJ-ROOT
    uuid: 886f64f9-d824-41d1-80a2-d374c3d36147
  ID-2: /efi raw-size: 384 MiB size: 380 MiB (98.96%) used: 2.2 MiB (0.6%)
    fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A uuid: 6864-413A
  ID-3: /home raw-size: 465.24 GiB size: 457.38 GiB (98.31%)
    used: 120.13 GiB (26.3%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19
    label: MJ-HOME uuid: dd1b813b-cfbb-44e0-b1c0-8371b5027442
  ID-4: /mnt/ntfs raw-size: 218.65 GiB size: 218.65 GiB (100.00%)
    used: 48.82 GiB (22.3%) fs: ntfs dev: /dev/sdb5 maj-min: 8:21 label: Virtual
    uuid: 48621C73621C67C8
  ID-1: swap-1 type: partition size: 24 GiB used: 768 KiB (0.0%)
    priority: -2 dev: /dev/sdb4 maj-min: 8:20 label: MJ-SWAP
    uuid: 9659dec3-9ddc-44b4-9a6c-6a92d4fbc9c6
  ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
    uuid: 7656-6044
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 95.68 GiB fs: ntfs label: Windows
    uuid: 42D05A1CD05A168F
  ID-4: /dev/sda4 maj-min: 8:4 size: 22.31 GiB fs: ntfs label: WIN-SWAP
    uuid: AA4042E64042B939
  ID-5: /dev/sda5 maj-min: 8:5 size: 1000 MiB fs: ntfs label: WINRE_DRV
    uuid: 2CDE5B7DDE5B3E70
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-1:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 1-1.1:4 info: Pixart Imaging Optical Mouse type: mouse
    chip-ID: 093a:2510 class-ID: 0301
  Device-2: 1-1.4:6 info: SINO WEALTH Gaming KB type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
  Device-3: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
  Device-4: 1-8:5 info: Syntek EasyCamera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 174f:116a class-ID: 0e02 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 39.0 C pch: 38.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1500 libs: 431 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    2: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 271
  1: cpu: 68.5% command: firefox pid: 1239 mem: 1008.0 MiB (8.5%)
  2: cpu: 19.7% command: firefox pid: 1693 mem: 277.1 MiB (2.3%)
  3: cpu: 11.4% command: firefox pid: 2505 mem: 256.7 MiB (2.1%)
  4: cpu: 8.0% command: firefox pid: 3063 mem: 1157.4 MiB (9.8%)
  5: cpu: 5.2% command: firefox pid: 2536 mem: 205.9 MiB (1.7%)
  Memory top: 5 of 271
  1: mem: 1157.4 MiB (9.8%) command: firefox pid: 3063 cpu: 8.0%
  2: mem: 1008.0 MiB (8.5%) command: firefox pid: 1239 cpu: 68.5%
  3: mem: 564.1 MiB (4.8%) command: firefox pid: 2165 cpu: 2.1%
  4: mem: 346.2 MiB (2.9%) command: firefox pid: 11815 cpu: 1.1%
  5: mem: 345.9 MiB (2.9%) command: firefox pid: 2444 cpu: 1.4%
  Processes: 271 Power: uptime: 36m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.58 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
Also note that avdmanager detects one more emulator (and also the flutter one) I’ve added in several tries, but I’ve seen they do not play any role in the error, and executed on Android Studio it produce just the same error (I’ve also removed all the emulators and installed again; I’ve even reinstalled the Android Studio emulator plug-in):
$ avdmanager list avd
Available Android Virtual Devices:
  Device: pixel (Google)
    Path: /home/cesc/.config/.android/avd/flutter_emulator.avd
  Target: Google Play (Google Inc.)
          Based on: Android API 36 Tag/ABI: google_apis_playstore/x86_64
  Sdcard: 512 MB
  Device: medium_phone (Generic)
    Path: /home/cesc/.config/.android/avd/Medium_Phone_API_34.avd
          Based on: Android 14.0 ("UpsideDownCake") Tag/ABI: google_apis_playstore/x86_64
    Skin: 1080x2400
  Sdcard: 512M
  Device: pixel_8_pro (Google)
    Path: /home/cesc/.config/.android/avd/Pixel_8_Pro.avd
    Skin: pixel_8_pro
  Sdcard: 512M
I’m facing the same situation since the stable update from 2025-03-24 and I think it might be connected to the mesa update. At least there is a ticket on the mesa issue board and someone fixed it by switching to wayland.
Btw. I am on i3 (x11) and might have to switch to sway, if that is really the issue
Manjaro just has issued a Mesa update:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
but the problem persists:
[ERR] The Android emulator exited with code -11 after startup
[ERR] Android emulator stderr:
[ERR] I0416 23:48:08.110291 222253 opengles.cpp:285] android_startOpenglesRenderer: gpu info
[ERR] I0416 23:48:08.110380 222253 opengles.cpp:286]
[ERR] MESA: error: dri3_alloc_render_buffer:1634 xcb_dri3_pixmap_from_buffer[s] failed
[ERR] MESA: error: X error: 11
[ERR] Address these issues and try again.
This worked for me: Android emulator runs in Wayland (Experimental) but not in Cinnamon (Default) Session · Issue #12780 · linuxmint/cinnamon · GitHub
