I have the following issue with my sound softeware: Because there is no analog stereo available it sets audio profile to dummy output.A remove and install of pulse or pipewire both give the same problem.
amixer -c0 ✔
Simple mixer control 'PCM',0
Capabilities: pvolume
Limits: Playback 0 - 255
Mono:
Front Left: Playback 254 [100%] [-0.20dB]
Front Right: Playback 254 [100%] [-0.20dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
pacmd list-cards INT ✘
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x601d170000 irq 197"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "51ca"
device.product.name = "Raptor Lake-P/U/H cAVS"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
pacmd list-sinks ✔
1 sink(s) available.
* index: 0
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 29490 / 45% / -20.81 dB, front-right: 29490 / 45% / -20.81 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 375 KiB
max rewind: 375 KiB
monitor source: 0
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
module: 16
properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
Alsa-info:
!!ALSA Information Script v 0.5.3
!!Script ran on: Fri Dec 5 20:25:52 UTC 2025
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: SKIKK
Product Name: Green 5
Product Version: Standard
Firmware Version: N.1.10STD00
System SKU: 0001
Board Vendor: SKIKK.EU
Board Name: Green 5
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/INOU0000:00/status 11
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INTC1055:00/status 15
/sys/bus/acpi/devices/INTC1078:00/status 15
/sys/bus/acpi/devices/INTC109C:00/status 15
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/OVTID858:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 8
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C0A:03/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:01/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/PRP00001:00/status 15
/sys/bus/acpi/devices/PRP00001:01/status 11
/sys/bus/acpi/devices/TXNW3643:00/status 15
/sys/bus/acpi/devices/UNIW0001:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:00/status 15
/sys/bus/acpi/devices/device:02/status 15
/sys/bus/acpi/devices/device:05/status 15
/sys/bus/acpi/devices/device:89/status 15
/sys/bus/acpi/devices/device:8a/status 15
/sys/bus/acpi/devices/device:8b/status 15
/sys/bus/acpi/devices/device:8d/status 15
/sys/bus/acpi/devices/device:8e/status 15
/sys/bus/acpi/devices/device:8f/status 15
/sys/bus/acpi/devices/device:94/status 15
/sys/bus/acpi/devices/device:9b/status 15
/sys/bus/acpi/devices/device:9d/status 15
!!ACPI SoundWire Device Status Information
Realtek 0x000020025d071100
Realtek 0x000120025d071100
!!Kernel Information
Kernel release: #1 SMP PREEMPT_DYNAMIC Fri, 19 Sep 2025 16:11:04 0000
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.12.48-1-MANJARO
Library version: 1.2.14
Utilities version: 1.2.14
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - No
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Raptor Lake-P/U/H cAVS [8086:51ca] (rev 01) (prog-if 80)
DeviceName: Onboard - Sound
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
ctl_dev_id : N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : -1
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 10
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Raptor Lake P HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086281f
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 7 Dec 5 13:00 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 6 Dec 5 13:00 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 2 Dec 5 13:00 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 3 Dec 5 13:00 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 4 Dec 5 13:00 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 5 Dec 5 13:00 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 1 Dec 5 13:00 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Dec 5 13:00 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Dec 5 13:00 .
drwxr-xr-x 3 root root 220 Dec 5 13:00 ..
lrwxrwxrwx 1 root root 12 Dec 5 13:00 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x601d170000 irq 197'
Mixer name : 'Intel Raptor Lake P HDMI'
Components : 'HDA:8086281f,80860101,00100000'
Controls : 29
Simple ctrls : 5
Mono:
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write volatile'
type INTEGER
count 8
range '0 - 36'
control.26 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
type INTEGER
count 8
range '0 - 36'
control.27 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
type INTEGER
count 8
range '0 - 36'
control.28 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
type INTEGER
count 8
range '0 - 36'
control.29 {
iface MIXER
name 'PCM Playback Volume'
value.0 254
value.1 254
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 -20
dbvalue.1 -20
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
acpi_tad
aesni_intel
af_alg
algif_hash
algif_skcipher
asus_wmi
atkbd
blake2b_generic
bluetooth
bnep
btbcm
btintel
btmtk
btrfs
btrtl
btusb
ccm
cec
cfg80211
chacha_x86_64
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
curve25519_x86_64
dm_mod
drm_buddy
drm_display_helper
drm_exec
drm_gpuvm
drm_suballoc_helper
drm_ttm_helper
dummy
fat
gf128mul
ghash_clmulni_intel
gpu_sched
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_mux
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
igen6_edac
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_pmc_core
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_tcc_cooling
intel_uncore
intel_uncore_frequency
intel_uncore_frequency_common
intel_vsec
ip6_udp_tunnel
ip_tables
irqbypass
iwlmvm
iwlwifi
joydev
kvm
kvm_intel
libarc4
libchacha
libchacha20poly1305
libcrc32c
libcurve25519_generic
libps2
loop
mac80211
mac_hid
mc
mei
mei_hdcp
mei_me
mei_pxp
mousedev
mtd
nf_conntrack
nf_defrag_ipv4
nf_defrag_ipv6
nf_tables
nfnetlink
nft_ct
nft_fib
nft_fib_ipv4
nvme
nvme_auth
nvme_core
ov13858
pcspkr
pinctrl_tigerlake
platform_profile
pmt_class
pmt_telemetry
poly1305_x86_64
polyval_clmulni
polyval_generic
pps_core
ptp
qrtr
raid6_pq
rapl
rfcomm
rfkill
roles
serio
serio_raw
sha1_ssse3
sha256_ssse3
sha512_ssse3
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_avs
snd_soc_core
snd_soc_hda_codec
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_hda_generic
snd_sof_intel_hda_mlink
snd_sof_pci
snd_sof_pci_intel_cnl
snd_sof_pci_intel_tgl
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
squashfs
thunderbolt
tls
ttm
typec
typec_ucsi
ucsi_acpi
udp_tunnel
usbhid
uvc
uvcvideo
v4l2_async
v4l2_fwnode
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wireguard
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xe
xor
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 4.981767] AES CTR mode by8 optimization enabled
[ 4.991919] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.992109] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.008945] hdaudio hdaudioC0D0: no AFG or MFG node found
[ 5.018280] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 5.029440] usbcore: registered new interface driver uvcvideo
[ 5.061208] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 5.061296] pps_core: LinuxPPS API ver. 1 registered
[ 5.073974] PTP clock support registered
[ 5.146938] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 5.146977] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 5.147006] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 5.156505] input: UNIW0001:00 093A:0255 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-13/i2c-UNIW0001:00/0018:093A:0255.0007/input/input23
How do I get my analog-stereo to be the default profile?
