When I hover over the time another little pop up appears and I see a real-time updating display of the time again in digital.
I would like an analog clock to pop up instead when I hover over the time.
There are lots of options out there, some very old and not sure if they work with Manjaro kde-plasma. Can anyone who is using an analog clock popup in their sys-tray offer a suggestion and maybe share a screenshot?
If I right click on the time in sys-tray and select “Show Alternatives” I can choose an Analog Clock which replaces the digital display in the tray that is so tiny I cannot see anything.
I was hoping for something the size of the calendar that pops up when you click on the time but instead appear when you hover over the time.
I installed trayclock which is an AUR package. I used the Pamac (Add/Remove Software) tool. Now I cannot un-install it?
Before I uninstalled it via Pamac I did pacman -Qm from the command line and it was there. After I uninstalled via Pamac pacman -Qm does not show it anymore but the icon is still there in the sys-tray telling me the time, even after a reboot.
It had a folder in ~/.config/ which I deleted.
It didn’t have anything in ~/.local/share/
