Amnezia vpn does not block only in Manjaro
Hi all, there is such a necessary program as Amnezia to use bypass locks GitHub - amnezia-vpn/amnezia-client: Amnezia VPN Client (Desktop+Mobile). So I tested it in Kubuntu GitHub - RAZEX0LOL/warp-config by installing for linux, and it connected and the internet was. In Manjaro, no matter how much I fought, I couldn’t force her. Judging by the logs, it is blocked and something with the DNS, I tried this No internet connection on Arch Linux · Issue #792 · amnezia-vpn/amnezia-client · GitHub it didn’t help. Maybe someone can tell me how to defeat this? Thanks
окт 13 00:55:02 angelMG systemd[1]: Started AmneziaVPN Service.
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Started as system service
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Daemon created"
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxDaemon" "Daemon created"
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "WireguardUtilsLinux created."
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "DnsUtilsLinux created."
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "IPUtilsLinux" "IPUtilsLinux created."
окт 13 00:55:02 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServer" "Server path: /var/run/amneziavpn/daemon.socket"
окт 13 00:55:18 angelMG AmneziaVPN-service.sh[3961]: LocalServer new connection
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: LocalServer new connection
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServer" "New connection received"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Connection created"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Read Data"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: status"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Status request"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: activate"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Activating interface"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Created wireguard interface amn0"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "LinuxRouteMonitor created."
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  iptables -C OUTPUT -j amnvpn.anchors 2> /dev/null"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Tearing down cgroup and routing rules"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  ip route flush table amnvpnrt"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is invalid"
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "LinuxFirewall::uninstall() complete"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit 1>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exi>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit 1>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else { exit>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Should be setting up cgroup in /sys/fs/cgroup/net_cls/amnvpnexclusions/ for traffic splitting"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions/ ] ; then mkdir /sys/fs/cgroup/net_cls/amnvpnexclusions/ ; sleep 0.1 ; echo 0x567 > /sys/fs/cgroup/net_cls/amnvpnexclusi>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/amnvpnexclusions/»: Нет такого файла или каталога\n/bin/bash: строка 1: /sys/fs/cgroup/net_cls/amnvpnexclusions//net_cls.>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  if ! ip rule list | grep -q 0x3211 ; then ip rule add from all fwmark 0x3211 lookup amnvpnrt pri 100 ; fi"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: invalid table ID"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "000.allowLoopback(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "000.allowLoopback(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "100.blockAll(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "100.blockAll(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "110.allowNets(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "120.blockNets(IPv4): OFF"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "200.allowVPN(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "250.blockIPv6(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "290.allowDHCP(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "290.allowDHCP(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "300.allowLAN(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "300.allowLAN(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "310.blockDNS(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "320.allowDNS(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if iptables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv4): ON' ; else echo '400.allowPIA(IPv4): OFF -> ON' ; ipta>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "400.allowPIA(IPv4): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables v1.8.10 (legacy): Couldn't load target `amnvpn.400.allowPIA':No such file or directory\n\nTry `iptables -h' or 'iptables --help' for more information."
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if ip6tables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv6): ON' ; else echo '400.allowPIA(IPv6): OFF -> ON' ; ip6>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "400.allowPIA(IPv6): OFF -> ON"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables v1.8.10 (legacy): Couldn't load target `amnvpn.400.allowPIA':No such file or directory\n\nTry `ip6tables -h' or 'ip6tables --help' for more information."
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding exclusion route for 162.159.193.5/32"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Gateway  10.10.10.1  for interface  wlp2s0
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Configuring peer bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo= via 162.159.193.5"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding exclusion route for /999999"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Invalid destination prefix"
lines 1-73...skipping...
If its the same as the others … the bit where the DNS server is listed are cut off.
But it is only one of the problems. It also fails to create a table, to set cgroup…i am not competent enough in iptables to say more.
It might help others to help you if you also say where did you get the installer from and how did you install and what service did you choose. Because i see options on the website, like openvpn, wireguard etc.
journalctl -u AmneziaVPN.service         ✔
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is in>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t fil>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables: Bad rule (does a matching rule exist in that chai>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t fi>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables: Bad rule (does a matching rule exist in that cha>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers ->
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t man>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t ma>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers ->
lines 1-40...skipping...
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/nul>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers -t nat 2> /dev/nu>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t raw 2> /dev/null>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers -t raw 2> /dev/nul>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Should be setting up cgroup in /sys/fs/cgroup/net_cls/amnvpnexclusions/ for >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions/ ] ; then mkdir />
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/amnvpnexclusions/»>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  if ! ip rule list | grep -q 0x3211 ; then ip rule add from all fw>
lines 1-48...skipping...
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 &&>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 &>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 &&>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 &&>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 &>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions/ ] ; then mkdir /sys/fs/cgroup/net_cls/a>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/amnvpnexclusions/»: Нет такого файла или >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  if ! ip rule list | grep -q 0x3211 ; then ip rule add from all fwmark 0x3211 lookup amnv>
lines 1-52...skipping...
lines 1-56...skipping...
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } el>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } e>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } el>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions/ ] ; then mkdir /sys/fs/cgroup/net_cls/amnvpnexclusions/ ; sleep 0.1 ; echo 0x567 > /sys/fs/cgroup/net_cls/amnv>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/amnvpnexclusions/»: Нет такого файла или каталога\n/bin/bash: строка 1: /sys/fs/cgroup/net_cls/amnvpnexclusions/>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if iptables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv4): ON' ; else echo '400.allowPIA(IPv4): OFF -> O>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if ip6tables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv6): ON' ; else echo '400.allowPIA(IPv6): OFF -> >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Adding DNS resolver 1.1.1.1 via amn0"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 0.0.0.0/1"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 128.0.0.0/1"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to ::/1"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 8000::/1"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Connection status: 1"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error received from the DBus service"
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error retrieving the DNS  domains from the DBus service"
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Checking for handshake..."
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "awaiting bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo="
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "DnsUtilsLinux created."
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Flush dns completed
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Critical, trying to add invalid route:  1.1.1.1
окт 13 00:55:36 angelMG AmneziaVPN-service.sh[3961]: Critical, trying to add invalid route:  1.0.0.1
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Flush dns completed
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Read Data"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: deactivate"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Deleting routes for InterfaceConfig::SingleHop"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 0.0.0.0/1"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 128.0.0.0/1"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to ::/1"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 8000::/1"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing exclusion route for 162.159.193.5/32"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Gateway  10.10.10.1  for interface  wlp2s0
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing exclusion route for /999999"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Invalid destination prefix"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "WireguardUtilsLinux destroyed."
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Tearing down cgroup and routing rules"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  ip route flush table amnvpnrt"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is invalid"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "LinuxFirewall::uninstall() complete"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error received from the DBus service"
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Connection released"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: LocalServer new connection
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServer" "New connection received"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Connection created"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Read Data"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: status"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Status request"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: activate"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Activating interface"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Created wireguard interface amn0"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "LinuxRouteMonitor created."
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  iptables -C OUTPUT -j amnvpn.anchors 2> /dev/null"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Tearing down cgroup and routing rules"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  ip route flush table amnvpnrt"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is invalid"
окт 13 00:56:26 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "LinuxFirewall::uninstall() complete"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } el>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } e>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t mangle 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers -t raw 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } el>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Should be setting up cgroup in /sys/fs/cgroup/net_cls/amnvpnexclusions/ for traffic splitting"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions/ ] ; then mkdir /sys/fs/cgroup/net_cls/amnvpnexclusions/ ; sleep 0.1 ; echo 0x567 > /sys/fs/cgroup/net_cls/amnv>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/amnvpnexclusions/»: Нет такого файла или каталога\n/bin/bash: строка 1: /sys/fs/cgroup/net_cls/amnvpnexclusions/>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  if ! ip rule list | grep -q 0x3211 ; then ip rule add from all fwmark 0x3211 lookup amnvpnrt pri 100 ; fi"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: invalid table ID"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "000.allowLoopback(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "000.allowLoopback(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "100.blockAll(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "100.blockAll(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "110.allowNets(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "120.blockNets(IPv4): OFF"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "200.allowVPN(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "250.blockIPv6(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "290.allowDHCP(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "290.allowDHCP(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "300.allowLAN(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "300.allowLAN(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "310.blockDNS(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "320.allowDNS(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if iptables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv4): ON' ; else echo '400.allowPIA(IPv4): OFF -> O>
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "400.allowPIA(IPv4): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables v1.8.10 (legacy): Couldn't load target `amnvpn.400.allowPIA':No such file or directory\n\nTry `iptables -h' or 'iptables --help' for more information."
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if ip6tables -C amnvpn.a.400.allowPIA -j amnvpn.400.allowPIA -t filter 2> /dev/null ; then echo '400.allowPIA(IPv6): ON' ; else echo '400.allowPIA(IPv6): OFF -> >
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "400.allowPIA(IPv6): OFF -> ON"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables v1.8.10 (legacy): Couldn't load target `amnvpn.400.allowPIA':No such file or directory\n\nTry `ip6tables -h' or 'ip6tables --help' for more information."
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding exclusion route for 162.159.193.5/32"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Gateway  10.10.10.1  for interface  wlp2s0
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Configuring peer bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo= via 162.159.193.5"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding exclusion route for /999999"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Invalid destination prefix"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Adding DNS resolver 1.1.1.1 via amn0"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 0.0.0.0/1"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 128.0.0.0/1"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to ::/1"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Adding route to 8000::/1"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Connection status: 1"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error received from the DBus service"
окт 13 00:56:27 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error retrieving the DNS  domains from the DBus service"
окт 13 00:56:28 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Checking for handshake..."
окт 13 00:56:28 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "awaiting bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51h2wPfgyo="
окт 13 00:56:28 angelMG AmneziaVPN-service.sh[3961]: Flush dns completed
окт 13 00:56:28 angelMG AmneziaVPN-service.sh[3961]: Critical, trying to add invalid route:  1.1.1.1
окт 13 00:56:28 angelMG AmneziaVPN-service.sh[3961]: Critical, trying to add invalid route:  1.0.0.1
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Flush dns completed
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Read Data"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: deactivate"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Deleting routes for InterfaceConfig::SingleHop"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 0.0.0.0/1"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 128.0.0.0/1"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to ::/1"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing route to 8000::/1"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing exclusion route for 162.159.193.5/32"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Gateway  10.10.10.1  for interface  wlp2s0
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Removing exclusion route for /999999"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "Invalid destination prefix"
окт 13 00:56:56 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "WireguardUtilsLinux destroyed."
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Tearing down cgroup and routing rules"
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  ip route flush table amnvpnrt"
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is invalid"
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "LinuxFirewall::uninstall() complete"
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DnsUtilsLinux" "Error received from the DBus service"
окт 13 00:56:57 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Connection released"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: LocalServer new connection
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServer" "New connection received"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Connection created"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Read Data"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: status"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Status request"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "DaemonLocalServerConnection" "Command received: activate"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "Daemon" "Activating interface"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Created wireguard interface amn0"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxRouteMonitor" "LinuxRouteMonitor created."
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  iptables -C OUTPUT -j amnvpn.anchors 2> /dev/null"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Tearing down cgroup and routing rules"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  ip route flush table amnvpnrt"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is invalid"
окт 13 00:57:00 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "LinuxFirewall::uninstall() complete"
окт 13 00:57:01 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } else>
окт 13 00:57:01 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:57:01 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t filter 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } els>
окт 13 00:57:01 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables: Bad rule (does a matching rule exist in that chain?)."
окт 13 00:57:01 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers -t nat 2> /dev/null | awk 'int($1) == 1 && $2 == \"amnvpn.anchors\" { found=1 } END { if(found==1) { exit 0 } el>
Hello my first post has all the links. I took different configuration files, for example, I raised the WG server, but I couldn’t connect. The essence of using Amnezia is that it makes it possible to use WARP
An alternative is Cloudflare WARP (for Linux).
Cheers.
Hello, it doesn’t assemble, I tried, error 404, maybe they’ll fix it later
Assemble?
Error 404 is usually associated with a missing resource; the page assuredly exists. You should perform your own research thereafter; or, perhaps that’s asking too much.
There is a binary package of Cloudflare-WARP available from the AUR;
You should be able to build it directly using `pamac’:
pamac build cloudflare-warp-bin
I hope this helps. Cheers.
Спасибо, но я хочу именно Amnezia). Everything connects perfectly in Kubuntu, we just have to understand why it’s not so in Manjaro
By the way, it doesn’t build because of 404 precisely because the link https://pkg.cloudflareclient.com/install on the page you provided leads to 404, just the same thing in the assembly package. Apparently they will fix it someday, but since the package has no maintainer, it probably won’t be soon)
@angel2035 you can try if installing and running of opennic-up helps your DNS resolution.
Thank you, how is that?), can you give me a link or something informative to help me understand? Thank you
Thank you, but it didn’t help (. What is there in Kubuntu, what is not in Manjaro, why is everything connected there, and not here?)
opennic-up         ✔  15s 
Selecting DNS among 192.3.165.37 147.182.243.49 137.184.12.79...
192.3.165.37
Using DNS 192.3.165.37 to retrieve api.opennicproject.org's IP
Using 116.203.98.109 as API host
https://api.opennicproject.org/geoip/?list&ipv=4&res=200&adm=0&bl&wl
Pinging 31 hosts to determine the top ones...resulting in 23 responsive hosts
Selected top 3 hosts:
65.21.1.106 # ns1.fi # 98.37%
185.181.61.24 # ns1.no # 99.91%
195.10.195.195 # ns31.de # 97.80%
195.10.195.195 # ns8.de # 56.65%
nameserver 65.21.1.106
nameserver 185.181.61.24
nameserver 195.10.195.195
Updating d2d2867a-a60d-4586-853d-6f6d52e0b117
Successful DNS update
Предупреждение: есть ещё 1 подключение с именем 'lo'. Ссылайтесь на подключение по его uuid '98cecbc6-b0d8-4389-9e72-bd47842ec962'
Updating 98cecbc6-b0d8-4389-9e72-bd47842ec962
    ~  journalctl -u AmneziaVPN.service         ✔  23s 
окт 13 00:55:34 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is i>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t fi>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables: Bad rule (does a matching rule exist in that cha>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t f>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables: Bad rule (does a matching rule exist in that ch>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L POSTROUTING -n --line-numbers >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L POSTROUTING -n --line-numbers>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L OUTPUT -n --line-numbers -t ma>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L OUTPUT -n --line-numbers -t m>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! iptables -L PREROUTING -n --line-numbers ->
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 123 ) $  if ! ip6tables -L PREROUTING -n --line-numbers >
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Should be setting up cgroup in /sys/fs/cgroup/net_cls/amnv>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 1 ) $  if [ ! -d /sys/fs/cgroup/net_cls/amnvpnexclusions>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "mkdir: невозможно создать каталог «/sys/fs/cgroup/net_cls/>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 255 ) $  if ! ip rule list | grep -q 0x3211 ; then ip ru>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if iptables -C amnvpn.a.400.allowPIA -j amnvpn.40>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "iptables v1.8.10 (legacy): Couldn't load target `amnvpn.40>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "( 2 ) $  if ip6tables -C amnvpn.a.400.allowPIA -j amnvpn.4>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "ip6tables v1.8.10 (legacy): Couldn't load target `amnvpn.4>
окт 13 00:55:35 angelMG AmneziaVPN-service.sh[3961]: Amnezia "WireguardUtilsLinux" "Configuring peer bmXOC+F1FxEMF9dyiK2H5/1SUtzH0JuVo51>
окт 13 00:56:20 angelMG AmneziaVPN-service.sh[3961]: Amnezia "LinuxFirewall" "Error: argument \"amnvpnrt\" is wrong: table id value is i>
The Cloudflare-WARP (AUR) package has just been updated (today) and builds as expected:
A reminder that you may also need the Cloudflare-WARP GUI:
pamac build warpgui-bin
Good luck.
Many thanks to everyone, installing (fixed) WARP and its graphical shell solved my problem, after several searches of the endpoint, it finally connected. Of course, it would be nice to launch Amnezia someday, since its mechanisms allow the use of tunnels under strict censorship, but apparently these are the following tasks. Thanks again everyone!
I solved the problem with the connection, namely Problem with DNS servers · Issue #708 · amnezia-vpn/amnezia-client · GitHub
Launched
sudo systemctl start systemd-resolved
It remains to understand why Manjaro doesn’t use it, and what he uses instead
First off you shouldnt use sudo when not needed.
Second … did no one mention systemd-resolved ?
I always do in these threads.
I would also suggest systemd-resolvconf package and openvpn-update-systemd-resolved if using openvpn, plus a few other files (though the config requires less manual files now).
Guess I missed it :sweat_smile:
Well heres a general guide from one time … guess I should make a real wiki post …
This is the very understanding of why Kubuntu has Internet with Amnezia, but Manjaro does not, it’s just that systemd-resolved is enabled by default in Ubuntu, and Manjaro uses /etc/resolv.conf settings like Debian 12 (I could be wrong) and Network manager
Manjaro defaults to openresolv.
