Amdgpu: Setting new power limit is not supported and Bluetooth: hci0: packet for unknown connection handle
amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
Bluetooth: hci0: SCO packet for unknown connection handle 3584
08:39:08 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
08:39:25 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
08:39:55 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
08:40:09 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
08:40:30 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
08:43:16 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:06:55 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:07:69 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:07:33 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:09:14 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:11:24 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:16:26 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:17:38 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:20:58 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:45:29 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
09:47:58 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
10:02:23 cov bluetoothd[941]: src/profile.c:ext_to_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Tra>
10:02:23 Cov pipewire[3842]: pw.node: (bluez_output.FC_58_FA_20_9C_8D.1-78) running —> error (Received error event)
10:03:52 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
10:04:12 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
11:06:32 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
11:07:40 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
11:03:30 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
11116322 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
11:18:42 Cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
13:02:57 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
13:19:52 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
13:23:46 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
13:55:46 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
14:44:13 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
16:22:30 cov kernels amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
16:24:56 cov kernel: Bluetooth: hci0: ACL packet for unknown connection handle 3837
16:25:56 cov kernel: Bluetooth: hcio: ACL packet for unknown connection handle 3337
16:32:18 Cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
17:53:21 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
17:54:46 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power Lintt is not supported!
18:07:58 cov kernel: Bluetooth: hci0: ACL packet for unknown connection handle 3837
18:47:36 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
18:51:43 cov kernels amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
18:52:13 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
18:53:20 Cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
18:57:55 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
18:58:80 cov kernel: Bluetooth: hcio: ACL packet for unknown connection handle 3837
19:15:69 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power Lintt is not supported!
19:44:49 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
19:50:38 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
19:51:15 cov kernel: amdgpu 0000:03:00.0: amdgpu: Setting new power limit is not supported!
Mod edit (scotty65): converted uploaded screenshots to text using tesseract. I had to manually edit some text which was misread by tesseract - hopefully I haven’t missed anything. All error codes should be correct.
I checked some of the forum posts and they told me that some of the messages were harmless, which I understand, but there were so many of them that I couldn’t check the logs properly, and they started appearing heavily in the logs after one or two previous updates.
Abandoned.
